ST意法半导体
直播中
章伟
7年用户 176经验值
私信 关注
[问答]
EVAL6229PD应用笔记哪里有
你好。我正在尝试查找与EVAL6229PD直接相关的应用笔记。我能找到的只是EVAL6235N的应用笔记,它们与6229没有直接关系,因为它有不同的布局。任何帮助,将不胜感激。
#eval6229pd #application-notes
以上来自于谷歌翻译
以下为原文
Hi. I'm trying to find application notes that relate directly to the EVAL6229PD. All I have been able to find is application notes for the EVAL6235N and they do not relate directly to the 6229 as it has a different layout. Any help would be appreciated.
回帖(3)
刘璐
2018-10-23 17:07:00
L6229与L6235的电流额定值相同,因此您可以使用应用笔记AN1625作为器件操作的参考。
 在AN中,列出的唯一电路板是EVAL6235N,但在这种情况下,电路板与EVAL6229PD非常相似。
以上来自于谷歌翻译
以下为原文
The L6229 is the same of the L6235 but the current rating, so you can use the application note AN1625 as reference for the device operation.
In the AN the only board listed is the EVAL6235N, but also in this case the board is very similar to the EVAL6229PD.
举报
章伟
2018-10-23 17:18:04
嗨恩里科。感谢那。那么EVAL6235N的额定电流是否高于EVAL6229PD?应用笔记似乎表明最大电流为2.8A RMS和5.6A峰值,但是当我们运行软件时,我们限制在大约1.5A。
 谢谢
以上来自于谷歌翻译
以下为原文
Hi Enrico. Thanks for that. So does the EVAL6235N have a higher current rating than the EVAL6229PD? The application note seems to indicate that the maximum current is 2.8A RMS and 5.6A peak but when we run the software we are limited to about 1.5A.
Thanks
举报
刘璐
2018-10-23 17:29:01
正确。 L6229是L6235的“低功耗”版本,但它们共用相同的控制电路。
以上来自于谷歌翻译
以下为原文
Correct. The L6229 is the ''low power'' version of the L6235 but they share the same control circuitry.
举报
更多回帖
