Microchip
直播中
h1654155275.5835
8年用户 210经验值
私信 关注
[问答]
explorer 16/32开发板是否支持dsPIC33EP512MU814
嗨,伙计们,感谢阅读MyP贴,我是新的16位微控制器,我正在使用DSSPICEP512MU814 16BIT和144PIN控制器。探索16/32开发是否支持我正在使用的PIC,我问这个是因为我读Debug DB只支持100个PIN控制器,而我使用144Pin。我们能用MCC生成代码吗????给这个控制器,告诉我我可以用哪一个开发板来工作。
以上来自于百度翻译
      以下为原文
    HI guys,
Thanks for reading my post I am new to the 16-bit microcontroller and I am using dsPIC33EP512MU814 16Bit & 144PIN controller. does the explore 16/32 development supports the pic which I am using, I am asking this because I read explore DB supports only 100 pin controller and I am using 144PIN. can we generate the code using MCC??? for this controller.
And tell me which devlopment board i can use to work with.
回帖(1)
王璨
2018-10-19 16:28:48
Explorer 16/32对“814”的评估模块的支持有限(814)(http://www. McCux.com)……ASPX?PATNONO=MA3300 25-3不再可用,但您可以创建自己的副本,因为DoCuMeJTIN仍然可用。包括引脚没有连接到基板的信息。仍然可用的是D332525-1承载DSPIC33 EP512MU810衍生物。这是否能满足你的需要?我们不知道。
以上来自于百度翻译
      以下为原文
    Explorer 16/32 has limited support for the '814.
The evaluation module for the '814 ( http://www.microchip.com/...aspx?PartNO=MA330025-3 ) is no longer available, but you could create your own copy as the documejtation is still available. Including the information which pins are not connected to the base board.
What is still available is the DM330025-1 - hosting the dsPIC33EP512MU810 derivative. Whether this might serve your needs? We can't know.
举报
更多回帖
