英特尔
直播中
谢赛
7年用户 276经验值
私信 关注
[问答]
NUC7PJYH没有视频和音频
我已经购买了带有UHD605显卡的NUC7PJYH,因为我们的新50“UHD电视对于我的旧Acer Revo 3610来说非常大,而Nvidia ION是Mythtv的前端。
我在NUC上安装了Xubuntu 18.04和Mythtv-frontend,并通过HDMI-1连接电视。
1,错误是,当我启动NUC时,电视说HDMI端口没有输入。
如果我拔出HDMI并重新插入,我就会得到桌面。
我得到了POST屏幕,但是在电视上说“没有输入”之后。
我试图通过在grub引导中设置“nomodeset”来修复丢失的桌面。
它修正了丢失的桌面,但是当我在GRUB中设置的nomodeset时,我没有声音通过HDMI。
Pavucontrol表示有一个HDMI输出,但即使插上它也不插电。
如果我删除grub中的nomodeset参数我有声音通过HDMI但我需要在每次启动后拔下并重新插入HDMI以获得电视上的桌面。
我在3680x2160和1024x768之间尝试了许多不同的屏幕分辨率,但问题仍然存在。
我还尝试使用命令video = 1920x1080在grub中设置分辨率。
Grub命令为ind / etc / default / grub,在GRUB_CMDLINE_LINUX_DEFAULT =下,然后运行update-grub。
我需要在grub中设置什么参数来同时拥有图片和声音。
有什么好建议吗?
电视是飞利浦50PUS6262
以上来自于谷歌翻译
以下为原文
I have bought a NUC7PJYH with UHD605 graphics because our new 50" UHD tv was to big a mouthfull for my old Acer Revo 3610 with Nvidia ION as a Mythtv frontend.
I installed Xubuntu 18.04 and Mythtv-frontend on the NUC and connected the TV via HDMI-1.
1,st error was, when I boot the NUC the tv says no input at the HDMI port. If I pull out the HDMI and plug it in again, I get the desktop. I get the POST screen though but after taht the TV says "no input".
I startet out trying to fix the missing desktop by setting the "nomodeset" in the grub boot. It corrected the missing desktop but when nomodeset i set in GRUB I have no sound through HDMI. Pavucontrol states that there is a HDMI output but it is unplugged even though it is plugged in.
If I remove the nomodeset parameter in grub i have sound over HDMI but I need to unplug and replug the HDMI after every boot to get a desktop on the TV.
I have tried many different screen resolutions between 3680x2160 and 1024x768 but the problem persists. I have also tried to set the resolution in grub with the command video=1920x1080.
Grub commands as ind /etc/default/grub and under GRUB_CMDLINE_LINUX_DEFAULT= and running update-grub afterwards.
What parameter do I need to set in grub to have both picture and sound. Any good suggestions?
The TV is a Philips 50PUS6262
回帖(12)
汤宇
2018-10-18 14:36:28
Hellojknuc感谢您加入英特尔®社区。虽然英特尔尚未在您的Linux版本上测试和验证英特尔®NUC,但我们知道其他客户已成功安装它。英特尔建议您检查您的Linux发行版网站和论坛:// www
.ubuntu.com / support / community-支持同行协助解决这个问题。
您也可以参考https://01.org/linuxgraphics/downloads获取潜水员帮助。
希望这可以帮助。
此致Leonardo C.Intel客户支持技术人员与英特尔公司签订合同
以上来自于谷歌翻译
以下为原文
Hello jknuc
Thank you for joining the Intel® community.
While Intel has not tested and validated Intel® NUC on your Linux version, we know that other customers have successfully installed it.
Intel suggests you check your Linux distro's website and forums at https://www.ubuntu.com/support/community-support for peer assistance with this the issue.
You could also refer to https://01.org/linuxgraphics/downloads for diver assistance.
Hope this helps.
Regards,
Leonardo C.
Intel Customer Support Technician
Under Contract to Intel Corporation
举报
李玉鑫
2018-10-18 14:47:03
嗨莱昂纳多
谢谢您的回复。
我已通过此ppa更新到最新的201801版本的intel图形驱动程序/ set:
更新的开放图形驱动程序:Oibaf
当我通过HDMI连接到我的飞利浦电视时,我仍然可以选择视频或声音
我看到问题与manyl用户在这些主题中提到的相同:
NUC7PJYH:HDMI 2.0支持不佳。
寻找兼容的电视(4K-60Hz-4:4:4)。
NUC7PJYH - 当HDMI UHD颜色为ON时,三星4K电视上没有信号
NUC7PJYH HDMI在特定显示屏上出现问题。
NUC7CJYH Linux / HDMI问题
英特尔NUC7PJYH:没有视频信号
所有这些线程都表明在NUC7xJYH系列中有一个带有HDMI 2.0a实现的设计缺陷,并且在将电视显示器连接到NUC7xJYH系列时会出现此错误。
此观察与OS(Windows或Linux)无关。
你/英特尔能否用bios版本来解决这个问题?
问候
Jens K.
以上来自于谷歌翻译
以下为原文
Hi Leonardo
Thank you for your reply.
I have updated to the latest 201801 version of the intel graphics drivers/set through this ppa:
Updated Open Graphics Drivers : Oibaf
Still i can choose to have either video or sound when i connect to my Philips TV through HDMI
I see that the issue is the same as mentioned by manyl users in these threads:
NUC7PJYH:  Poor HDMI 2.0 support. In search of a compatible TV (4K-60Hz-4:4:4).
NUC7PJYH - No signal on Samsung 4K TV when HDMI UHD Color is ON
NUC7PJYH HDMI Issue on particular display.
NUC7CJYH Linux/HDMI issues
Intel NUC7PJYH: no video signal
All of these threads indicate that there is a designflaw with the HDMI 2.0a implementation in the NUC7xJYH series and that this error is showing itself when connecting a TV display to the NUC7xJYH series. This observation is independent of the OS (Windows or Linux).
Could you/Intel please address the error with a bios release to fix it?
Regards
Jens K
举报
谢赛
2018-10-18 14:55:59
嗨PeterNUC。
我想你是对的。
我决定将我的UHD电视设置为非UHD模式 - 现在运行1920x1080非UHD。
我认为英特尔营销和销售的产品无法利用英特尔自己为客户指定的规格,这是一种耻辱。
如果英特尔发布了尽快修复此问题的BIOS更新,那将是适当的
以上来自于谷歌翻译
以下为原文
Hi PeterNUC.
I think you are right.
I have resolved to setting my UHD TV to non UHD mode - now running 1920x1080 non UHD.
I think it's a shame that Intel markets and sells a product that is not able to utilize the specification that Intel it self has specified to the customer.
It would be apropriate if Intel released a BIOS update that fixed this problem ASAP
举报
张桂芳
2018-10-18 15:07:32
引用: 子璇ALICE 发表于 2018-10-18 17:09
嗨PeterNUC。
我想你是对的。
我发现了一个新错误。
如果我在失败的模块后看起来我dmesg:
dmesg |
grep失败了
我发现
[2.160352] i915 0000:00:02.0:i915 / glk_dmc_ver1_04.bin的直接固件加载失败,错误-2
我已经找到了Gemini lake blob,它应该在哪里 - 在/ lib / firmware / i915中为glk_dmc_ver1_04.bin
所以文件在那里但由于某种原因它不会在启动时加载。
也许构建blob的英特尔工程师可以解决这个问题
以上来自于谷歌翻译
以下为原文
I have found a new error.
If i looked i dmesg after failed modules:
dmesg | grep failed
i find
[2.160352] i915 0000:00:02.0: Direct firmware load for i915/glk_dmc_ver1_04.bin failed with error -2
I have looked for the Gemini lake blob and it is where it should be - in /lib/firmware/i915 as glk_dmc_ver1_04.bin
so the file is there but for some reason it does not load under boot.
Maybe the Intel engineers who have build the blob can solve this issue
举报
更多回帖
