SPI_HandleTypeDef hspi1;
static void MX_SPI1_Init(void)
hspi1.Instance = SPI1;
hspi1.Init.Mode = SPI_MODE_MASTER;
hspi1.Init.Direction = SPI_DIRECTION_2LINES;
hspi1.Init.DataSize = SPI_DATASIZE_8BIT;
hspi1.Init.CLKPolarity = SPI_POLARITY_LOW;
hspi1.Init.CLKPhase = SPI_PHASE_1EDGE;
hspi1.Init.NSS = SPI_NSS_SOFT;
hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_32;
hspi1.Init.FirstBit = SPI_FIRSTBIT_MSB;
hspi1.Init.TIMode = SPI_TIMODE_DISABLE;
hspi1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
hspi1.Init.CRCPolynomial = 10;
if (HAL_SPI_Init(&hspi1) != HAL_OK)
_Error_Handler(__FILE__, __LINE__);
W25Q128代码:
#define CS_Pin GPIO_PIN_3
#define CS_GPIO_Port GPIOA
#define ChipSelect() HAL_GPIO_WritePin(CS_GPIO_Port, CS_Pin, GPIO_PIN_RESET)
#define ChipDeselect() HAL_GPIO_WritePin(CS_GPIO_Port, CS_Pin, GPIO_PIN_SET)
#define COMMAND_IDENTIFICATION 0x90
uint8_t buffer_tx[4];
uint8_t buffer_rx[2];
uint16_t GetIdentification()
buffer_tx[0] = COMMAND_IDENTIFICATION;
buffer_tx[1] = 0x0;
buffer_tx[2] = 0x0;
buffer_tx[3] = 0x0;
ChipSelect();
HAL_SPI_Transmit(&hspi1, buffer_tx, 4, 1000); // send 0x90, 0x0, 0x0, 0x0
HAL_SPI_Receive(&hspi1, buffer_rx, 2, 1000); // receive 0xFF, 0xFF
ChipDeselect();
return ((uint8_t)buffer_rx[0] << 8) | (uint8_t)buffer_rx[1];
int main(void)
MX_SPI1_Init();
HAL_Delay(1000);
uint16_t id = GetIdentification();
printf("Manufacturer ID: 0x%.4Xrn", id);
while
举报
举报
举报
举报
举报
更多回帖
