你好Jeremiah,
案例是,该服务器被出售给客户并且运行了几个月。
开始给出这些错误。
我们更新了RAID控制器的FW,但它没有帮助。
所以我们决定将RAID控制器更改为新的。
但它没有解决问题。
RAID控制器是RS3DC040并安装了最新的FW。
我们没有机会在另一个平台上测试它,因为我们必须将它发送到AWR。
主板FW不是最新的。
我们可以尝试升级它,但我很确定它不会解决问题。
是的,我们在最近开放的机票上有熟悉的问题,但仍然没有解决方案(还有另一个问题)
问题以相同的方式启动,但在连接RAID BBU模块后服务器开始连续发出蜂鸣声,但没有任何错误记录
但是有相同的控制器型号,但主板是不同的。
所以是的,我们遇到了另一个董事会的同样问题。
谢尔盖
以上来自于谷歌翻译
以下为原文
Hello Jeremiah,
The case is, that server was sold to customer and worked well for few months.
The started to give these errors. We updated FW of RAID controller, but it didn't help. so we decided to change the RAID controller to a new one.
But it didn't solve the issue. The RAID controller is RS3DC040 and latest FW installed.
We didn't have an opportunity to test it in another platform as we had to send it to AWR.
Motherboard FW is not the latest. We can try to upgrade it, but I am quite sure that it will not fix the issue.
Yes we had familiar issue in ticket that was opened recently but still not solution (there another issue occuered as well)
Problem started in the same way but after that server started to beep continiously when RAID BBU module connected, but no error nowhere logged
But there is the same controller model, but motherboard is different. So yes, we met identical problem with another board.
Sergei
你好Jeremiah,
开始给出这些错误。
但它没有解决问题。
主板FW不是最新的。
谢尔盖
以上来自于谷歌翻译
以下为原文
Hello Jeremiah,
Sergei
举报
