赛灵思
直播中
赵军
8年用户 174经验值
私信 关注
[问答]
资源需求超出可用资源
尝试运行CORDIC代码时遇到错误,该代码表示​​:
error1:Pack:2309  - 找到太多类型为“IBUF”的绑定组件适合此设备。
error2:Pack:18  - 对于给定的设备和包,设计太大。
请查看“设计摘要”部分,了解设计的哪个资源要求超出了设备中可用的资源。
我看到了设计摘要:“保税IOB数量”的利用率为121%,其他低于100%。
这是什么意思,我该如何纠正呢?
我附上了我所指的论文,代码如下
模块cordic(z0,x0,y0,xn,yn,en);输入有符号[15:0] z0,x0,y0;输入en;输出有符号[15:0] xn,yn; reg [15:0] xn
,yn;参数[3:0] iter = 4'd14; reg签署[15:0] thetai; reg [3:0] ii = 0; reg [3:0] i; reg签署[15:0] zi
,xi,yi,xtemp,ytemp; reg di; reg [15:0] pi = 16'b0110010010000111; reg [15:0] pi2 = 16'b0011001001000011;总是@(en)beginif(z0 [15] == 0
)beginif(z0 [14:13]> 2'd1)beginxi = 0-y0; yi = x0; zi = z0-pi2; endelsebeginxi = x0; yi = y0; zi = z0; endendelse if(z0 [15] =
= 1)beginif(Z0 [14:13]> 2'd1)beginxi = Y0; YI = 0-X0;滋= Z0 + PI2; endelsebeginxi = X0; YI = Y0;滋= Z0; endendxn = 0;炔=
0;对于(II = 0; iibeginytemp =(YI >>>ⅱ); xtemp =(XI >>>ⅱ);如果(ZI [15] == 0)beginxn = XI-ytemp;炔=义+ xtemp;
滋=滋thetai [II]; endelsebeginxn = XI + ytemp;炔=苡xtemp;滋=滋+ thetai [II]; endxi = XN; YI =炔; //结束XN = XN /一种; //炔
= YN / AN; endendmodule
可扩展流水线CORDIC架构设计.pdf 667 KB
以上来自于谷歌翻译
以下为原文
I got an error while trying to run CORDIC code which said:
error1: Pack:2309 - Too many bonded comps of type "IBUF" found to fit this device.
error2: Pack:18 - The design is too large for the given device and package.
   Please check the Design Summary section to see which resource requirement for
   your design exceeds the resources available in the device.
I saw the Design summary: the percentage utilization of "number of bonded IOBs" is 121%, others are below 100%. what does this mean and how can I correct it?
I have attached the paper I am referring and the code  is as follows
module cordic(z0,x0,y0,xn,yn,en);
input signed [15:0]z0,x0,y0;
input en;
output signed [15:0]xn,yn;
reg [15:0]xn,yn;
parameter [3:0]iter=4'd14;
reg signed [15:0]thetai;
reg [3:0]ii=0;
reg [3:0]i;
reg signed [15:0]zi,xi,yi,xtemp,ytemp;
reg di;
reg [15:0]pi=16'b0110010010000111;
reg [15:0]pi2=16'b0011001001000011;
always @(en)
begin
if(z0[15]==0)
begin
if(z0[14:13]>2'd1)
begin
xi=0-y0;
yi=x0;
zi=z0-pi2;
end
else
begin
xi=x0;
yi=y0;
zi=z0;
end
end
else if(z0[15]==1)
begin
if(z0[14:13]>2'd1)
begin
xi=y0;
yi=0-x0;
zi=z0+pi2;
end
else
begin
xi=x0;
yi=y0;
zi=z0;
end
end
xn=0;
yn=0;
for(ii=0;ii begin
ytemp=(yi>>>ii);
xtemp=(xi>>>ii);
if(zi[15]==0)
begin
xn=xi-ytemp;
yn=yi+xtemp;
zi=zi-thetai[ii];
end
else
begin
xn=xi+ytemp;
yn=yi-xtemp;
zi=zi+thetai[ii];
end
xi=xn;
yi=yn;
end
//xn=xn/An;
//yn=yn/An;
end
endmodule
            Scalable Pipelined CORDIC Architecture Design.pdf ‏667 KB
回帖(6)
杨玲
2018-10-12 14:25:37
这是什么意思,我该如何纠正呢?
我附上了我所指的论文,代码如下
以上来自于谷歌翻译
以下为原文
input en;
reg [15:0]xn,yn;
reg [3:0]ii=0;
reg [3:0]i;
reg di;
always @(en)
begin
if(z0[15]==0)
begin
if(z0[14:13]>2'd1)
begin
xi=0-y0;
yi=x0;
zi=z0-pi2;
end
else
begin
xi=x0;
yi=y0;
zi=z0;
end
end
else if(z0[15]==1)
begin
if(z0[14:13]>2'd1)
begin
xi=y0;
yi=0-x0;
zi=z0+pi2;
end
else
begin
xi=x0;
yi=y0;
zi=z0;
end
end
xn=0;
yn=0;
for(ii=0;ii begin
ytemp=(yi>>>ii);
xtemp=(xi>>>ii);
if(zi[15]==0)
begin
xn=xi-ytemp;
yn=yi+xtemp;
zi=zi-thetai[ii];
end
else
begin
xn=xi+ytemp;
yn=yi-xtemp;
zi=zi+thetai[ii];
end
xi=xn;
yi=yn;
end
//xn=xn/An;
//yn=yn/An;
end
endmodule
举报
赵文平
2018-10-12 14:31:09
首先 -  CORDIC核心是您的顶级设计模块是不寻常的。
为什么是
你通过地图运行这个?
第二 - 错误似乎很清楚,你所针对的设备不够用
用于处理所有输入和输出的引脚。
我统计了81个顶级端口。
什么设备
你正在瞄准目标,是否有81个IO可用?
-  Gabor
-  Gabor
以上来自于谷歌翻译
以下为原文
First - it is unusual that a CORDIC core would be your top level design module.  Why are
you running this through map?
Second - the error seems clear enough, the device you targetted does not have enough
pins to handle all of your inputs and outputs.  I counted 81 top level ports.  What device
and package are you targetting, and does it have 81 IO's available?
-- Gabor
-- Gabor
举报
张萍
2018-10-12 14:41:55
我相信你会使用一个小型S3衍生设备,只有IBUF类型的打击垫。
我相信你的设备中的可用输入已经用尽,但仍有可用的输出。
还只是日志,看看是否其他东西实际上失败了。
有时,当发生错误时,工具将无法完成对设备的打包,并且通常不会为IO提供错误的错误。
要测试核心,您可以在综合期间禁用IO插入,然后在NGDBUILD和MAP中使用-u选项来修剪掉未使用的逻辑(不附加到IO),也就是说,如果您只是想看一下
错误是。
或者你可以选择更大的设备。
以上来自于谷歌翻译
以下为原文
I believe you would be using a small S3 derivative device where there are IBUF only type pads.
I believe you have run out of the available inputs in the device while there still may be available outputs.
Also just the log to see if something else actually failed.
Sometimes the tools will not finish packing the device when an error occurs and will give you a false error though not usually for IOs.
To test the core you can disable IO insertion during synthesis and then use the -u option in NGDBUILD and MAP to not trim out the unused logic (not attached to an IO), that is if you just want to get a look at what the error is.
Or you can choose a bigger device.
举报
张萍
2018-10-12 14:59:43
设备是斯巴达3E XC3S100E。错误是什么意思?
我怎么能纠正它?
这实际上用于电机控制中的停车改造。
但是现在我只想尝试实现cordic模块。
以上来自于谷歌翻译
以下为原文
device is spartan 3E XC3S100E. what does the error mean? how can I correct it? this is actually used for park transformation in motor control. but right now i am just trying to implement cordic module.
举报
更多回帖
