6n137具有显着的辐射二极管电容,这使得导通延迟,并且还允许其在释放电压后发光。
有必要为二极管提供双向电流。为此,将电阻器并联连接到二极管的触点,并计算流过它的工作电流。该电流的加倍值必须流过淬火电阻,并连接到低功率的换向场效应晶体管。
偏移由第三电阻器设置,并联到换向晶体管。当二极管开关电压最小时,初始偏移量在最高温度下计算。
这里有很多单词,但你会有更多的纸张计算。祝你好运。
以上来自于谷歌翻译
以下为原文
6n137 has a significant capacitance of a radiating diode, which makes the on-delay, and also allows it to glow after relieving the voltage.
It is necessary to provide a bi-directional current flow for the diode. To do this, connect the resistor in parallel to the contacts of the diode, with the calculation of the operating current flowing through it. The doubled value of this current must flow through the quenching resistor, with connection to a commutating field-effect transistor of low power.
The offset is set by a third resistor, with a parallel connection to the commutating transistor. The initial offset is calculated at the maximum temperature when the diode on-off voltage is at a minimum.
There are many words here, but you will have even more paper calculations. Good luck.
以上来自于谷歌翻译
以下为原文
举报
