是德科技
直播中
朱利华
7年用户 167经验值
私信 关注
[问答]
基于Windows的VNA中安装的任何防病毒程序?
我有一个E5071C-2K5 ENA(基于Windows)。
多年前,安捷伦不鼓励用户在ENA中安装任何防病毒程序:[http://application-notes.digchip.com/018/18-22614.pdf]在第16页,它说,“不要试图使用
除了本手册中描述的方式之外的系统或者为普通PC安装基于Windows的软件(包括防病毒软件)可能会导致故障。“
现在,强烈建议安装防病毒程序:[http://literature.cdn.keysight.c ... 90140.pdf?id=868737](第18页)[http://www.keysight。
com / main / editorial.jspx?cc = PK& lc = eng& ckey = 1281464]我的同事也拥有E5071C。
他不喜欢防病毒程序(也许他怀疑数据可能会延迟?),所以他避免任何互联网连接或USB闪存驱动器插入ENA以防止病毒感染。
(他只允许从另一台计算机连接GPIB。)我的ENA没有互联网连接,但我使用了USB闪存驱动器。
我使用旧的“do-not-install-antivirus-programs”规则进行了大脑冲洗,现在我犹豫是否在我的ENA中安装了防病毒程序。
(但最终我上周安装了卡巴斯基。)我想听听用户关于他们的Keysight(安捷伦)VNA中安装的防病毒程序的任何经验。
Keysight仅确认Symantec AntiVirus程序。
有没有人使用赛门铁克以外的防病毒程序(例如卡巴斯基)并且没有发现任何错误(数据延迟,奇怪的行为......等)?
您是否希望停止自动扫描以防止可能干扰数据?
谢谢。
以上来自于谷歌翻译
     以下为原文
  I have an E5071C-2K5 ENA (Windows-based). Many years ago, Agilent discouraged users to install any antivirus program in an ENA:
On page 16, it says, "do not attempt to use the system in ways other than those described in this manual or to install Windows-based software (including anti-virus software) for ordinary PCs as doing so may cause malfunctions."
Now, installing an antivirus program is strongly recommended:
[http://literature.cdn.keysight.c ... 90140.pdf?id=868737] (page 18)
[http://www.keysight.com/main/edi ... ng&ckey=1281464]
My colleague also owns an E5071C. He does not like antivirus programs (maybe he suspects possible delays in data taking?), so he avoids any internet connection or USB flash drive insertion to the ENA in order to prevent virus infection. (He allows only GPIB connection from another computer.)
My ENA does not have internet connection, but I uses USB flash drives on it. I was brain-washed with the old "do-not-install-antivirus-programs" rule and now I hesitated to install an antivirus-program in my ENA. (But eventually I installed Kaspersky last week.)
I would like to hear any experiences from the users about their antivirus programs installed in their Keysight (Agilent) VNAs. Only Symantec AntiVirus program is confirmed by Keysight. Does anyone use an antivirus program other than Symantec (Kaspersky for example) and find nothing wrong (data delay, weird behavior, ...etc.)? Do you prefer to stop autoscan to prevent possible interference with the data taking?
Thank you.
回帖(1)
陈建华
2018-10-9 15:05:17
虽然我无法与ENA通话,但PNA没有附带任何防病毒功能,但如果您将其连接到开放式LAN或担心USB驱动器,我们建议您使用防病毒程序。
请参阅:http://na.support.keysight.com/pna/FAQ1.html#N10当然,我们无法保证一旦安装了防病毒(或其他非Keysight程序)就没有副作用。
一些防病毒程序会将无害的PNA程序视为威胁。
有一段时间,ESET防病毒实际上阻止了PNA的运行,尽管我最近没有听说过。
我们没有看到Microsoft Security Essential或Symantec的任何问题。
我认为其他人也会工作得很好。
不安装其他Windows程序的请求似乎过于严格,并且消除了使用Windows的许多优点。
最有可能的是“CYA”试图阻止支持问题。
是德科技无法测试世界上每个程序的兼容性问题,所以他们基本上只是说不。
我不会过分关注这一点,但请记住,如果你有速度问题,你就是靠自己。
以上来自于谷歌翻译
     以下为原文
  While I can't speak to the ENA, the PNA does not come with any antivirus, but we do recommend using an antivirus program if you connect it to an open LAN or are worried about USB drives. See: http://na.support.keysight.com/pna/FAQ1.html#N10
Of course, we cannot guarantee that there will be no side effect once an antivirus (or other non-Keysight program) is installed.  Some antivirus programs will detect harmless PNA programs as a threat.  At one time, the ESET antivirus actually prevented the PNA from functioning, although I have not heard of that lately.  We have not seen any issues with Microsoft Security Essential or with Symantec.  I assume others will also work just fine.
The request to not install other windows programs seems overly restrictive and eliminates much of the advantages in using Windows. Most likely it is a "CYA" attempt to head off support problems.  Keysight cannot test every program in the world for compatibility issues, so they basically just say no.  I would not pay too much attention to this, but keep in mind, if you have issues with speed, you are on your own.
举报
更多回帖
