大家好,
我们在带有Tesla P4的dell R740服务器中使用linux。
我们正在使用GPU对ffmpeg进行一些测试,没有使用GPU,我们得到了相当多的FPS,我们觉得很奇怪。
没有GPU
ffmpeg -i Samsung_UHD_Soccer_Barcelona_Atle
tico_Madrid.ts -threads 0 -map 0:0 -b 500k -c:v libx264 -s 320x240 -y test.h264
frame = 1068 fps = 77 q = -1.0 Lsize = 1282kB time = 00:00:21.32 bitrate = 492.5kbits / s speed = 1.53x
用GPU
ffmpeg -hwaccel cuvid -c:v hevc_cuvid -i Samsung_UHD_Soccer_Barcelona_Atletico_Madrid.ts -map 0:0 -b:v 500k -c:v h264_nvenc -pixel_format yuv420p -r 25 -vf scale_npp = 320:240 -y test1.h264
frame = 415 fps = 66 q = 39.0 Lsize = 1044kB time = 00:00:16.60 bitrate = 515.4kbits / s dup = 0 drop = 411 speed = 2.62x
另一个奇怪的事情是,即使我同时运行不同的进程,GPU的使用总是相同的....大约9%
utilization.gpu [%]
9%
utilization.gpu [%]
10%
utilization.gpu [%]
9%
utilization.gpu [%]
10%
utilization.gpu [%]
有没有人有ffmpeg来解释这个?
最好的问候和提前感谢
以上来自于谷歌翻译
以下为原文
Hi all,
We are using linux in a dell R740 server with a Tesla P4. We are doing some test with ffmpeg using the GPU and without, we get quite much FPS without using the GPU, what we find weird.
Without GPU
ffmpeg -i Samsung_UHD_Soccer_Barcelona_Atletico_Madrid.ts -threads 0 -map 0:0 -b 500k -c:v libx264 -s 320x240 -y test.h264
frame= 1068 fps= 77 q=-1.0 Lsize= 1282kB time=00:00:21.32 bitrate= 492.5kbits/s speed=1.53x
with GPU
ffmpeg -hwaccel cuvid -c:v hevc_cuvid -i Samsung_UHD_Soccer_Barcelona_Atletico_Madrid.ts -map 0:0 -b:v 500k -c:v h264_nvenc -pixel_format yuv420p -r 25 -vf scale_npp=320:240 -y test1.h264
frame= 415 fps= 66 q=39.0 Lsize= 1044kB time=00:00:16.60 bitrate= 515.4kbits/s dup=0 drop=411 speed=2.62x
The other strange thing is that even if i put to run different processes at the same time, the GPU usage is always the same.... around 9%
utilization.gpu [%]
9 %
utilization.gpu [%]
10 %
utilization.gpu [%]
9 %
utilization.gpu [%]
10 %
utilization.gpu [%]
Anybody has experience with ffmpeg to explain this?
Best regards and thanks in advance
