目前我们不支持Server 2016,因为它是未发布的产品。
您可以使用最新的驱动程序对其进行评估,但不保证性能,我们无法提供帮助。
目前,在“裸机”部署中,M60或M6都不受支持。
虽然我无法提供Dell刀片的具体详细信息,但未来可能会提供对此功能的支持。
根据服务器2012 R2 RemoteFX会话,只要您具有端到端的完整RemoteFX连接,您就可以从硬件加速中受益。
您将受益多少取决于应用程序以及它是否将利用GPU进行视频加速。
一般而言,大多数组织都受益于GPU,从而降低了CPU开销。
以上来自于谷歌翻译
以下为原文
Currently we do not support Server 2016 as it is an unreleased product. You can evaluate it with the latest drivers, but there's no guarantee of performance and we cannot provide assistance.
At present neither the M60 or the M6 are supported in "bare metal" deployments. Support for this functionality may be available in the future though I can't provide specific details for the Dell blade.
As per server 2012 R2 RemoteFX sessions, as long as you have a full RemoteFX connection end to end then you will benefit from hardware acceleration. How much you'll benefit by depends on the application and whether it will utilise the GPU for video acceleration. Generally speaking though, most organisations benefit from the GPU leading to a reduction in CPU overhead.
以上来自于谷歌翻译
以下为原文
举报
