为什么我不能为3000A型号(不是X3000A)保存到USB记忆棒?
首先,你需要有N2685A USB主机模块(这是它的好处)。
您应该已经使用3000系列示波器接收了一个。
确保模块完全就位。
当启动屏幕闪烁时,示波器的电源循环将告诉您它是否正确安装。
示波器打开时,您可以将模块固定,如果检测到,则“USB模块已安装”字样将在屏幕上闪烁。
此外,您可以按下“Utility”硬键,然后按下“I / O Setup”软键。
如果您看到USB图标旁边的复选标记,则应正确安装模块。
现在,如果您有多个这些示波器和模块,请查看是否可以将故障隔离到一个或两个特定模块或示波器。
另一件要尝试的是清除棒上的所有数据。
这似乎适用于“文件实用程序失败”错误。
如果一切都失败了,请尝试使用其他USB记忆棒(
以上来自于谷歌翻译
以下为原文
Why can’t I save to a USB stick for the 3000A model (not X3000A)?
First, you need to have the N2685A USB host module (this is all it is good for). You should have received one with your 3000 series oscilloscope. Make sure that the module is fully seated. Power cycling the oscilloscope will tell you if it is installed properly when the start up screen flashes. You can seat the module while the oscilloscope is on, and the words “USB module installed” will flash on the screen if it is detected. Additionally, you can hit the “Utility” hard key, then the “I/O Setup” softkey. If you see a checkmark next to the USB icon, the module should be installed properly. Now, if you have several of these oscilloscopes and modules, see if you can isolate the trouble to one or two specific modules or oscilloscopes. Another thing to try is to clear all the data off of the stick. This seems to work for the "File Utility fail" error. If all else fails, try a different USB stick (< 2 GB).
确保模块完全就位。
另一件要尝试的是清除棒上的所有数据。
这似乎适用于“文件实用程序失败”错误。
以上来自于谷歌翻译
以下为原文
举报
