Microchip
直播中
贺若龙
7年用户 167经验值
私信 关注
[问答]
PIC18F在MPLAB X IDE V4.05中工作但在MPLAB IDE V8.89中不工作
亲爱的各位,在使用P18编译器IDE V4.05与C18编译器进行PIC18F25K80微控制器的程序时,我有一个特殊的问题,但是程序使用MPLAB IDE V889C和高技术C编译器运行得很好。两者都是评价版,有没有影响呢?附上两个代码供参考。代码之间唯一的区别是所用的延迟函数。它与ADXL345加速度计进行了I2C通信。当我用MPLAB IDV889Flash进行闪存时,效果很好,但是在MPLAB X IDE中不起作用。我请求有人帮我解决这个问题。问候,X. Ignatius。
MPLAPIDE V889C(11.38 KB)-下载3次
以上来自于百度翻译
      以下为原文
    Dear All,
I have a peculiar problem in making the program executed in PIC18F25K80 micro controller using MPLAB X IDE V4.05 with C18 compiler but the program runs very well using MPALB IDE V8.89 with HI-TECH C compiler. Both of them are evaluation version, did that affect? Attached both the codes for reference.
The only difference between the codes is the delay function used. It has I2C communication with ADXL345 accelerometer. Works very well when I flash it using MPLAB IDE V8.89 but doesn't work in MPLAB X IDE.
I request someone to help me troubleshoot this problem.
Regards,
X. Ignatius
   Attachment(s)
MALAPXIDE 4.05.c (11.22 KB) - downloaded 7 times
MPLAPIDE V8.89.c (11.38 KB) - downloaded 3 times
回帖(6)
王雪
2018-9-27 15:12:46
所以你有一个问题,但唯一的症状是“它不起作用”。什么根本不起作用?你是怎么期待它的工作和实际发生的?此外,尝试使用XC8工具链而不是C18。如果我没弄错的话,我相信高科技编译器是我的Microchip买的,它变成了XC8。我相信你也可以在MPLAX X中使用高科技C编译器。
以上来自于百度翻译
      以下为原文
    So you have a problem but the only symptom is "It doesn't work".  What exactly doesn't work?  How are you expecting it to work and what actually happens?
Also, Try using the XC8 toolchain rather than C18.  If I'm not mistaken, I believe the HI-TECH compiler was bought my microchip and it became XC8.
I believe you could just use the HI-TECH C compiler in MPLAB X too.
举报
陈晨
2018-9-27 15:26:43
C18和HiTeCH有很大的不同。什么是C18上的MPLABX和不是XC8从高科技下降?我认为高科技仍然可以与MPLABX一起工作。
以上来自于百度翻译
      以下为原文
    C18 and hitech are very different.
What C18 on MPLabX and not XC8 which descended from hi-tech?
I think Hi-tech May still work with MPLabX.
举报
尹星
2018-9-27 15:34:23
你没有弄错。
以上来自于百度翻译
      以下为原文
You are not mistaken.
举报
李龙
2018-9-27 15:46:31
嗨,评估版除了限制使用天数之外还有一些限制吗?问候,X. Ignatius
以上来自于百度翻译
      以下为原文
    Hi,
Does evaluation version has some restriction apart from using it for restricted no. of days.
Regards,
X. Ignatius
举报
更多回帖
