The tiDM-MINI-DC reference design implements a light-weight powerline communication (PLC) data concentrator (DC) solution integrated with an Ethernet Repeater feature. A power grid network is static, which means that once end-nodes are installed the number of nodes to be supported by a DC is fixed (...)
主要特色
Supports a network up to 32 nodes with a light-weight data concentrator solution using the same platform as PLC service nodes
Extends network coverage with PLC/ethernet repeater (or edge router) feature interconnecting ethernet and PLC networks
TM4C1294 is a single-chip MCU device integrated with (...)
