是德科技
直播中
张蕾
8年用户 176经验值
私信 关注
[问答]
.mes文件解释疑问
各位大家好,我们对* .mes *文件的解释有疑问,其中包含以下信息:B506051607 | 2017 ***** 567892 | + 2.694281E + 03 | T | P我们假设第一个字段在
字符串表示日期和小时。
然后第二个字段显示电路板的序列号。
第三个字段指的是测试的测量,但在第四个字段中我们不知道它的意思(管道中间的T字母)。
有人可以帮我们解决这个问题吗?
谢谢。
以上来自于谷歌翻译
     以下为原文
  Hi everybody,
We have a question about the interpretation of a *.mes* file that contains the following information:
B506051607|2017*****567892|+2.694281E+03|T|P
We assume that the first field in the string says the date and hour. Then the second field says the serial number of the board. The third field refers to the measurement of the test, but in the fourth field we don't have idea what it mean (the T letter in middle of the pipelines).
Can someone help us with this question?. Thanks.
回帖(1)
戚银燕
2018-9-21 11:40:01
嗨Carlos,你看过手册了吗? - 这些mes文件被创建并附加到核心数据记录工具Qstat使用,实际的原始数据可以提取为ASCII格式,如果你阅读有关日志记录格式的更多细节,
这可能会有所帮助 - 我认为这个文件是Qstat的yield函数的一部分,如果没有测试板/组件,则通知T,P表示结果是通过
以上来自于谷歌翻译
     以下为原文
  Hi Carlos, did you look to the manuals ?- these mes files are created and appended to for use by the core data logging tool Qstat, the actual raw data can be extracted to ASCII  format and if you read more details about log record format, this might help - i think this file is part of the yield function for Qstat and is notifying the T if board/component was tested not, and P is indicating result was a pass
举报
更多回帖
