工程资源中心
直播中
刘凯
8年用户 189经验值
私信 关注
[电机控制]
双极步进驱动的75V/10A保护型全桥功率级设计包括BOM及层图
            Stepper drives are used in many applications operating typically from 12VDC to 48VDC. TI offers a rich family of stepper motor driver solutions with industry standard step/direction and parallel control interfaces.
For applications which require higher torque and power, often voltages above 48VDC  (...)
主要特色
  • Protected full-bridge power stage with input voltage up to 100VDC (75VDC nominal) and 10ARMs phase current.
  • BOM reduction using SM72295 100V full-bridge gate driver with integrated amplifiers used for high-side bipolar phase current sensing, supporting up to 256 micro steps.
  • 95% efficiency at 16 kHz  (...)
更多回帖
