我的DSPIC33 EP64 MC202遇到了一些问题。我认为这是一个硬件问题,但我还不确定。我设计了硬件,设计了固件,调试模式下一切都很好。因此,我在调试模式下停止使用它,并且我确实编程了它。一个月后,它没有理由停止,所以我试图调试它,但是当我试图加载代码时,出现了一条消息,通知“无效ID”。我试过一切,很好,这意味着DSPIC死了,对吗?所以我把另一个DSPIC,同一个模型,它工作得很好,但是,最近的一个,同样的事情发生了,它停止了,当我试图调试,消息出现:“目标设备ID(0x1D39万)是一个无效的设备ID”WHELL,我将把我的示意图和规范放在数据表中。T。我可以看到VCAP中的连接不是推荐的,但是,如果我不把VCAP放在VDD中,调试不起作用。我能做什么?这会是DSPIC失败的原因吗?我的示意图和推荐的设计附图是在SigaTrdDSPICI的名义下的,这是因为
电源的缘故,我用LM317转换为138V到3.3V。这个设备需要24H的功能,这个电源是一个好的选择吗?我的设计的源代码是以PoNTE3.3V的名字附在这个帖子上的。任何帮助都是很棒的。以我最好的回报。丹尼尔。
以上来自于百度翻译
以下为原文
I'm having some problems with my dsPIC33EP64MC202. I believe it is a hardware problem, but I'm not sure yet.
I designed the hardware, designed the firmware, and everything was fine in debug mode. So, I stopped to use it in debug mode and I programmed it definitely. One month later it stopped with no reason, so I tried to debug it, but when I tried to load the code the a message appears to inform "Invalid ID" . I tried everything and well, it means the dsPIC died, am I right ? So I put another dsPIC, same model and it worked fine, but, aproximately one mounth later, the same thing happened, it stopped and when I tried to debug, the message appears: "Target Device ID (0x1d390000) is an Invalid Device ID"
Whell, I will put here my schema
tic and the specification in datasheet . I can see that the connection in vcap is not the recommended, but, if I do not put vcap in VDD, debug does not work. What can I do ? Would it be the responsible for the dsPIC fail ? The figure with my schematic and the recommended design is attached to this post under the name schematicDSPIC
I'm thinking it woul be because of the soure power, I use a LM317 to convert 13.8V to 3.3V. The device need to be functioning 24hs, is this source power a good choice ? The figure with my design of the source is attached to this post under the name fonte3.3V.
Any help would be great.
With my best regrads.
Daniel.
Attached Image(s)
