Cypress技术论坛
直播中
刘倩
8年用户 191经验值
私信 关注
[问答]
在Windows 10上安装WICED Studio 6.2没有足够的可用磁盘空间
作为该线程的后续操作:Wice Studio 5.1在Windows 7上安装:没有足够的空闲磁盘空间
我也遇到了同样的问题在版本6.2。有超过600 GB的免费,所以这不是问题。这个问题是由于CMD.EXE路径引起的吗?
昨天我参加了一个箭头研讨会,几名来自柏树的人试图让SDK安装得不走运。他们尝试了前一个线程中提到的两个项目(Env变量,从一个拇指驱动器安装),和其他一些,但没有运气。
以上来自于百度翻译
     以下为原文
  As a follow on to this thread: WICED Studio 5.1 Install on Windows 7: Not enough free disk space
I am also encountered the same problem on version 6.2. There is more than 600GB free, so that is not the issue. Is the problem due to cmd.exe path?
I was at an Arrow seminar yesterday and several people from Cypress tries to get the SDK installed with no luck.  They tried both items mentioned in the previous thread (env variables, installing from a thumb drive), and a few others, but no luck.
回帖(7)
杨伟
2018-9-18 14:42:55
我的解决方法是将.exe解压缩到一个拇指驱动器…然后从拇指驱动器启动安装程序。然后你可以告诉它安装到C:用户 [你的名字] 文件..
以上来自于百度翻译
     以下为原文
  My workaround is to Unzip the .EXE to a thumb-drive... then launch the installer from the thumb drive.    You can then tell it to install to C:users[your name here]Documents..
举报
h1654155275.5741
2018-9-18 14:57:27
Sang-Culrs151536336
可以尝试再次安装,并从%%TMP%WICEDIGUTION安装日志文件夹中发送安装日志的最新版本。
取决于Windows下如何设置您的/TEMP环境变量,这可能是在tM\WICDEDY安装日志中。
我们需要最新的一个,因为听起来昨天人们试图安装成功,所以会有多个日志。
一旦提供,我将与ABDA合作,看看我们能否解决这个问题。
以上来自于百度翻译
     以下为原文
  sjohncollins_1568336
Could you attempt to install again and send the most recent version of the install log from the: %tmp%wiced_install_log folder.
Depending on how your /temp environment variable is setup under windows, this could be under temp[size=14.6667px]wiced_install_log
We need the latest one as it sounds like people were trying to install yesterday with limited success, so there will be multiple logs.
Once provided, I will work with abda to see if we can figure out the issue.
举报
刘倩
2018-9-18 15:03:06
引用: wonick 发表于 2018-9-18 18:15
Sang-Culrs151536336
你好
谢谢你收看这个节目。请从昨天找到日志文件。
约翰
星期五,2018年6月8日,上午9:17:04上午PDT,MIFO & LT;社区经理@ CyPress .com & Gt;写道:
#yiv4675239569 * #yiv4675239569 a #yiv4675239569 body {font-family:Helvetica, Arial, sans-serif;}#yiv4675239569 #yiv4675239569 h1, #yiv4675239569 h2, #yiv4675239569 h3, #yiv4675239569 h4, #yiv4675239569 h5, #yiv4675239569 h6, #yiv4675239569 p, #yiv4675239569 hr {}#yiv4675239569 .yiv4675239569buttonTD {}
γ
柏树开发者社区
γ
WISE Studio 6.2在Windows 10上安装:没有足够的空闲磁盘空间(CONT)
MIFO在WICE演播室Wi-Fi/Coubo论坛上的回复-查看完整的讨论
Sang-Culrs151536336
这取决于你的/ TEMP环境变量设置在Windows环境下,这可能是温度 wiced_install_log下
我们需要新的一个听起来像人们试图安装昨天有限的成功,所以会有多个日志。
一次,我将同方向看我们可以找出问题。
通过回复此邮件,此邮件的回复,或者去Cypress的开发者社区的消息
通过电子邮件或在柏树社区的开发商开始在WICED工作室Wi-Fi /组合论坛的新探讨
在Windows 10安装WICED Studio 6.2:没有足够的可用磁盘空间(不)在这些流:收件箱
此电子邮件发送由赛普拉斯开发者社区因为你是注册用户。
你可以订阅立即从柏树的开发者社区,或电子邮件在您的电子邮件偏好调整频率
WICED StudioOffice安装06201082018131302Y3L.Log.Zip
4.8 K
WICED StudioOpLoad 06Y0720120181253Y21.Log.Zip
4.8 K
WICED StudioOffice安装06Y072012018121227 20.Log.Zip
4.7 K
WICED StudioOpLoad 06Y07201201010949,14Log.Zip
4.8 K
以上来自于百度翻译
     以下为原文
  Hello
Thanks for looking in to this. Please find the log files from yesterday.
John
    On Friday, June 8, 2018, 9:17:04 AM PDT, mifo <community-manager@cypress.com> wrote:
  #yiv4675239569 * #yiv4675239569 a #yiv4675239569 body {font-family:Helvetica, Arial, sans-serif;}#yiv4675239569 #yiv4675239569 h1, #yiv4675239569 h2, #yiv4675239569 h3, #yiv4675239569 h4, #yiv4675239569 h5, #yiv4675239569 h6, #yiv4675239569 p, #yiv4675239569 hr {}#yiv4675239569 .yiv4675239569button td {}
  Cypress Developer Community
WICED Studio 6.2 Install on Windows 10: Not enough free disk space (con't)
reply from mifo in WICED Studio Wi-Fi/Combo Forums - View the full discussion
Depending on how your /temp environment variable is setup under windows, this could be under tempwiced_install_log
Reply to this message by replying to this email, or go to the message on Cypress Developer Community
Start a new discussion in WICED Studio Wi-Fi/Combo Forums by email or at Cypress Developer Community
Following WICED Studio 6.2 Install on Windows 10: Not enough free disk space (con't) in these streams: Inbox
This email was sent by Cypress Developer Community because you are a registered user.
You may unsubscribe instantly from Cypress Developer Community, or adjust email frequency in your email preferences
举报
刘倩
2018-9-18 15:09:00
Sang-Culrs151536336
它与环境变量点一起工作到Stass32文件夹。问题解决了。
谢谢你的努力
约翰
星期五,2018年6月8日,上午9:56:56 PDT,john collins & lt;ShanCluls@ @雅虎.com写道:
你好
约翰
TiCa,Arial,SAN-serif;} YV6633 17314 H1,YYV68033 17314 H2,YYV68033 17314 H3,YYV68033 17314 H4,YYV68033 17314 H5,Y YV68033 17314 H6,Y YV6633 173314 P,YIV68033 17314 HR {} yIV68017314Butt TD{} YYV680317314** YIV68033 17314 A YYV68033 17314机身{字体系列:Helv.
γ
柏树开发者社区
γ
Sang-Culrs151536336
你可以尝试重新安装,将安装日志从最新版本:% % wiced_install_log TMP文件夹。
一次,我将同方向看我们可以找出问题。
以上来自于百度翻译
     以下为原文
  It works with environment variable point to Systems32 folder. Problem solved.
Thanks for your efforts
John
    On Friday, June 8, 2018, 9:56:56 AM PDT, john collins <sjohncollins@yahoo.com> wrote:
  Hello
John
  #yiv6803317314 * #yiv6803317314 a #yiv6803317314 body {font-family:Helvetica, Arial, sans-serif;}#yiv6803317314 h1, #yiv6803317314 h2, #yiv6803317314 h3, #yiv6803317314 h4, #yiv6803317314 h5, #yiv6803317314 h6, #yiv6803317314 p, #yiv6803317314 hr {}#yiv6803317314 .yiv6803317314button td {}
举报
更多回帖
