引用: mmvjsuds2 发表于 2018-9-17 08:53
BrianCam Hitachi当你说“非真正的差分模式”时,这是因为没有巴伦,(巴伦是一种将平衡阻抗转换为不平衡的设备,反之亦然。此外,巴伦也能提供阻抗变换,因此称为巴伦变形金刚
)在PXIe VNA M937xA中?
因此,“有效的测量方法(使用叠加原理)。”
> {quote:title = briancamhitachi写道:} {quote}> BrianCam Hitachi >>当你说“非真正的差分模式”时,这是因为没有巴伦,(巴伦是一种将平衡阻抗转换为不平衡的设备,反之亦然
此外,平衡 - 不平衡变压器还可以在PXIe VNA M937xA中提供阻抗变换,因此命名为Balun变压器。
>当您没有_多端口网络分析仪时,Baluns用于进行差分测量。
例如,如果您只有2个端口VNA,并且想要测量差分滤波器的s参数,则可以在VNA的每个端口上使用平衡 - 不平衡转换器将每个单端端口转换为差分端口。
在这样的设置中,您必须从最终测量中去嵌入平衡 - 不平衡变换器的s参数,以获得滤波器的真实响应。
但是,如果你有一个4端口VNA,则不需要巴伦。
我会推荐这个_ *应用笔记* _。
它解释了进行多端口/平衡测量的单端和真差分方法,并描述了这两种技术之间的差异。
以上来自于谷歌翻译
以下为原文
> {quote:title=briancamhitachi wrote:}{quote}
> BrianCam Hitachi
> When you say "not True Differential mode", is this because there is no Balun, (Balun is a device which converts balanced impedance to unbalanced and vice versa. In addition, baluns can also provide impedance transformation, hence the name Balun Transformers) in the PXIe VNA M937xA's ??
Baluns are used in making differential measurements when you _don't have_ a multiport network analyzer. for example if you only have 2 port VNA and you want to measure the s-parameters of a differential filter, you could use a balun on each port of the VNA to convert each single-ended port to a differential port. in such a setup, you would have to de-embed the s-parameters of the balun from your final measurement to get the true response of the filter. However, if you have a 4-port VNA, there is no need for a balun.
I would recommend this
_*Application Note*_. it explains both the single-ended and true differential approach to making multiport/balanced measurements and describes the differences between the two techniques.
)在PXIe VNA M937xA中?
我会推荐这个_ *应用笔记* _。
以上来自于谷歌翻译
以下为原文
> BrianCam Hitachi
举报
