嗨,
我在新的VDI项目上遇到了同样的问题(所以完全是最新的系统)。
几乎每次直接在双屏模式下启动时都会冻结,所以在窗口或单一全屏模式下连接时,它的出现频率要低得多。
当通过窗口或单个全屏模式连接,然后扩展到双屏模式时,可用于剩余的会话。
将VDA降级为7.9解决了单屏和双屏模式的问题,但这不是一个可接受的解决方案,因为我无法使用NVENC等。
自VDA 7.11以来,视频内存预留发生了变化,但即使更改了值也无效(甚至不确定在使用Nvidia卡时是否需要更改此设置)
https://support.citrix.com/article/CTX218217
我不认为安装Citrix补丁ICAWS760WX64029会有所帮助,因为它似乎包含在较新的VDA中:https://gridforums.nvidia.com/default/topic/426/nvidia-grid-vgpu/xendesktop-7-6
-grid会话冻结/ 2 /
为此创建了一个Citrix支持案例但是到目前为止支持无法提供帮助(在问题发生时创建内存转储/网络/ CDF跟踪之后)。
客户正在使用XA VDA 7.12并附带vGPU,我们没有任何问题。
那么也许它与HDX3DPRO有关?
以上来自于谷歌翻译
以下为原文
Hi,
I'm having the same issue on a new VDI project (so fully up-to-date system).
Having the freezes almost every time when starting directly in a Dual-Screen mode, so when connecting in a Window or Single Full-Screen mode it appears far less frequent.
When connected via a Window- or Single Full-screen mode and then extending to Dual-Screen mode works for the rest of the session.
Downgrading the VDA to 7.9 fixes the issue, for Single and Dual-Screen mode but this isn't a acceptable solution as I can't use NVENC etc.
Since VDA 7.11 there has been a change in the Video-Memory reservation but even after changing the value it doesn't help (even not sure if you need to change this when working with a Nvidia card)
I don't think installing Citrix patch ICAWS760WX64029 will help has as it appears to be included in the newer VDA's: https://gridforums.nvidia.com/default/topic/426/nvidia-grid-vgpu/xendesktop-7-6-grid-session-freeze/2/
Created a Citrix-support case for this but Support hasn't been able to help so far (after creating memory-dumps/network/CDF traces when the issue occurs).
Customer is using XA VDA 7.12 with a vGPU attached too and there we don't have any issue. So maybe it's related to the HDX3DPRO?
嗨,
-grid会话冻结/ 2 /
那么也许它与HDX3DPRO有关?
以上来自于谷歌翻译
以下为原文
Hi,
举报
