啊,那是你的问题。
您需要先许可XenServer才能使用vGPU配置文件,是的,Enterprise会为您解锁。
在获得许可之前,您将只能使用GPU Passthrough,而不能使用vGPU。
因此,使用单个K2,每个卡最多2个用户。
XenServer获得许可后,一切都将开始工作:-)
Passthrough不需要管理程序中的驱动程序,这就是为什么这没有许可证的原因。
只是让你准备好在许可证出现时,你提到你已经尝试了一些不同的驱动程序,所以为了确保你安装了正确的驱动程序,你应该使用这个:NVIDIA-vGPU-kepler-xenserver
-6.5-367.64.x86_64.rpm
使用XenServer,您还可以使用驱动程序下载中包含的.ISO来安装vGPU驱动程序。
只需使用XenCenter中的更新功能安装它,使用SSH保存:-)
问候
本
以上来自于谷歌翻译
以下为原文
Ah, that's your problem. You need to license XenServer before you can use vGPU profiles, and yes, Enterprise will unlock it for you.
Until it's licensed, you will only be able to use GPU Passthrough, and not vGPU. So with a single K2, that's 2 users maximum per Card. Soon as XenServer is licensed, everything will start working :-)
Passthrough does not require the driver in the hypervisor, which is why this works without licensing.
Just so you're ready for when the licenses turn up, you mention you've tried a few different drivers, so just to make sure you have the right one installed, you should be using this one:
NVIDIA-vGPU-kepler-xenserver-6.5-367.64.x86_64.rpm
With XenServer, you can also use the .ISO included in the driver downoad to install the vGPU drivers. Just install it using the update feature in XenCenter, saves using SSH :-)
Regards
Ben
啊,那是你的问题。
问候
本
以上来自于谷歌翻译
以下为原文
Regards
Ben
举报
