TI论坛
直播中
张恒
8年用户 161经验值
私信 关注
[问答]
TMS320F28035 PGIO脚不受控
GPACTRL 0x00000000 GPIO A Control Register (GPIO0 to 31) [Memory Mapped]
GPAQSEL1 0x00000000 GPIO A Qualifier Select 1 Register (GPIO0 to 15) [Memory Mapped]
GPAQSEL2 0x30000000 GPIO A Qualifier Select 2 Register (GPIO16 to 31) [Memory Mapped]
GPAMUX1 0x00555555 GPIO A MUX 1 Register (GPIO0 to 15) [Memory Mapped]
GPAMUX2 0x50000000 GPIO A MUX 2 Register (GPIO16 to 31) [Memory Mapped]
GPADIR 0x3FF7E000 GPIO A Direction Register (GPIO0 to 31) [Memory Mapped]
GPAPUD 0x00000FFF GPIO A Pull Up Disable Register (GPIO0 to 31) [Memory Mapped]
GPBCTRL 0x00000000 GPIO B Control Register (GPIO32 to 44) [Memory Mapped]
GPBQSEL1 0x00000000 GPIO B Qualifier Select 1 Register (GPIO32 to 44) [Memory Mapped]
GPBMUX1 0x00050000 GPIO B MUX 1 Register (GPIO32 to 44) [Memory Mapped]
GPBDIR 0x00001C83 GPIO B Direction Register (GPIO32 to 44) [Memory Mapped]
GPBPUD 0x00000300 GPIO B Pull Up Disable Register (GPIO32 to 44) [Memory Mapped]
AIOMUX1 0xAAAAAAAA Analog I/O MUX1 Register [Memory Mapped]
AIODIR 0x00000000 Analog I/O Direction Register [Memory Mapped]
GPADAT 0xC0003AAA GPIO A Data Register (GPIO0 to 31) [Memory Mapped]
GPASET 0x00000000 GPIO A Data Set Register (GPIO0 to 31) [Memory Mapped]
GPACLEAR 0x00000000 GPIO A Data Clear Register (GPIO0 to 31) [Memory Mapped]
GPATOGGLE 0x00000000 GPIO A Data Toggle Register (GPIO0 to 31) [Memory Mapped]
GPBDAT 0x0000067D GPIO B Data Register (GPIO32 to 44) [Memory Mapped]
GPBSET 0x00000000 GPIO B Data Set Register (GPIO32 to 44) [Memory Mapped]
GPBCLEAR 0x00000000 GPIO B Data Clear Register (GPIO32 to 44) [Memory Mapped]
GPBTOGGLE 0x00000000 GPIO B Data Toggle Register (GPIO32 to 44) [Memory Mapped]
AIODAT 0x00000000 Analog I/O Data Register [Memory Mapped]
AIOSET 0x00000000 Analog I/O Data Set Register [Memory Mapped]
AIOCLEAR 0x00000000 Analog I/O Data Clear Register [Memory Mapped]
AIOTOGGLE 0x00000000 Analog I/O Data Toggle Register [Memory Mapped]
GPIOXINT1SEL 0x0000 XINT1 GPIO Input Select Register (GPIO0 to 31) [Memory Mapped]
GPIOXINT2SEL 0x0000 XINT2 GPIO Input Select Register (GPIO0 to 31) [Memory Mapped]
GPIOXINT3SEL 0x0000 XINT3 GPIO Input Select Register (GPIO0 to 31) [Memory Mapped]
GPIOLPMSEL 0x00000000 LPM GPIO Select Register (GPIO0 to 31) [Memory Mapped]
目前上面是我的GPIO配置结果,
void SetGpioLevel(unsigned int pin, unsigned int data)
if (pin < 32)
if (data > 0)
//GpioDataRegs.GPADAT.all |= (1 << pin);
GpioDataRegs.GPASET.all |= (1 << pin);
else
//GpioDataRegs.GPADAT.all &= ~(1 << pin);
GpioDataRegs.GPACLEAR.all |= (1 << pin);
else if (pin < 64)
pin = pin-32;
if (data > 0)
//GpioDataRegs.GPBDAT.all |= (1 << pin);
GpioDataRegs.GPBSET.all |= (1 << pin);
else
        //GpioDataRegs.GPBDAT.all &= ~(1 << pin);
          GpioDataRegs.GPBCLEAR.all |= (1 << pin);
asm(" NOP");
asm(" NOP");
asm(" NOP");
使用这个函数进行控制
int i;
for(i = 0; i < 7; i++)
           SetGpioLevel(LedStatusGpioPin, 1);
其中
volatile Uint16 LedStatusGpioPin[] = [ USER_GPIO42,
USER_GPIO32,
USER_GPIO21,
USER_GPIO13,
USER_GPIO16,
USER_GPIO17,
USER_GPIO29 ];
其中USER_GPIO42   USER_GPIO32  USER_GPIO13可以控制,   USER_GPIO21和GPIO16确不受控, 我想输入为高电平, GPADAT 里面确实也为0,不知道为什么,    初始化的时候已经全部配置成  上拉、输出、GPIO功能,但是无作用。
回帖(4)
周静
2018-9-13 09:48:56
您好,
奇怪,建议您单个测试gpio21,gpio16,看是不是硬件有问题。
举报
张恒
2018-9-13 09:59:08
引用: euagh1985 发表于 2018-9-13 08:09
您好,
根据社区会员提供的方法:可以尝试把1< 解决了问题. 非常感谢
举报
张恒
2018-9-13 10:15:13
您好,
举报
张恒
2018-9-13 10:24:39
您好,
根据社区会员提供的方法:可以尝试把1<
更多回帖
