英伟达
直播中
李桢
8年用户 146经验值
私信 关注
[问答]
在具有tegra k1芯片的chromebook运行Horizon View性能会提升吗
您好,我只是想问一下,如果我在具有tegra k1芯片的chromebook上运行它,是否有任何性能提升?
我问这是因为nvidia说tegra k1是一些特殊的硬件,用于解码爆炸流,使体验尽可能顺畅。
或者,与仅使用客户端软件(PCOIP)而非使用爆炸协议(浏览器)的非铬OS笔记本电脑相比,性能是否有所增加?
亲切的问候
以上来自于谷歌翻译
以下为原文
Hello, I just want to ask, if there is any performance increase in horizon view if I run it on a chromebook with a tegra k1 chip?
I ask this is because nvidia says that in the tegra k1 is some special hardware for decoding the blast stream to make the experience as smooth as possible. Or is there no performance increase compared to a non chrome os based notebook which just uses the client software(PCOIP) instead of the blast protocol(browser)?
Kind regards
Joe
回帖(3)
武彩霞
2018-9-12 16:25:36
嗨乔,
在以h264编码时,TK1供电的Chromebook确实能够对BLAST协议进行硬件解码,这已经由NVIDIA,VMware& Co.
谷歌(见下面的视频)。
对于HTML访问(BLAST),您可以在Chrome中使用硬件加速,
为了确认这是否已经利用了TK1的扩展功能,我会要求VMware确认,因为我还没有看到这个已发布。
以上来自于谷歌翻译
以下为原文
Hi Joe,
The TK1 powered Chromebooks do have the capability to undertake hardware decode of the BLAST protocol when encoded in h264, and this has been jointly demonstrated by NVIDIA, VMware & Google (see video below).
For HTML access (BLAST) you can utilise hardware acceleration in Chrome,
For confirmation of whether this already takes advantage of the extended capabilities of the TK1 I would ask for confirmation from VMware as I've not seen this published yet.
举报
李晔皓
2018-9-12 16:36:29
如何使用Tegra K1芯片的瘦客户端或零客户端?
谢谢
以上来自于谷歌翻译
以下为原文
How about thin clients or zero clients that use the Tegra K1 chip?
Thank you
举报
张昂笙
2018-9-12 16:49:33
我不知道任何基于TK1的Android瘦客户端,所以我没有任何东西可以参考我害怕。
以上来自于谷歌翻译
以下为原文
I don't know of any TK1 based Android thin clients, so I don't have anything to reference I'm afraid.
举报
更多回帖
