你好,
看看这些评论:
https://community.st.com/thread/41628-temperature-sensor-on-lis2hh12-accelerometer?commentID=160558&sharpcomment
https://community.st.com/thread/41628-temperature-sensor-on-lis2hh12-accelerometer?commentID=160610&sharpcomment
集成温度传感器(如果它不是温度计)仅适用于相对温度测量。如果您只有几个设备原型,可以随意“校准”它们,并获得具有可靠输出的温度计。
大卫
注意:原始帖子包含大量线程对话,只能迁移到第9级
以上来自于谷歌翻译
以下为原文
Hello,
Have a look at these comments:
Integrated temperature sensors (if it's not a thermometer) are suitable only for relative temperature measurement. If you have only a few device prototypes, feel free to 'calibrate' them and you get a thermometer with a reliable output.
David
Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level
你好,
看看这些评论:
大卫
以上来自于谷歌翻译
以下为原文
Hello,
David
举报
