是的,如果外部参考被丢弃到ESG,则内部参考被接入并将输出到您的MXA。
我不记得MXA是否只是像PSA一样手动切换,但如果是,那么如果您的测试允许非GPS时基,那么您当前的配置将是一个优势。
以上来自于谷歌翻译
以下为原文
Yes, if the external reference is dropped to the ESG the internal reference is switched in and will be outputted to your MXA. I don't remember if the MXA is only manually switched like the PSA, but if it is then your current configuration would be an advantage if your testing allows for a non-GPS timebase.
以上来自于谷歌翻译
以下为原文
举报
