英伟达
直播中
李果
8年用户 180经验值
私信 关注
[问答]
Hyper-V,RDS会话主机和特斯拉M10许可
我需要确认此设置的许可要求:
具有单个Tesla M10的单个物理Server 2016 Hyper-V主机。
两个2016远程桌面会话主机客户OSE,它们通过DDA分配给它们。
需要在RDS服务器上运行应用的75个用户。
- 其中10个是使用需要GPU加速的应用的高级用户
我从阅读许可指南中了解到,我需要75个GRID虚拟应用程序(vApp)CCU订阅,但我想验证。
先谢谢了,
以上来自于谷歌翻译
以下为原文
I need confirmation on the licensing requirements for this setup:
A single physical Server 2016 Hyper-V host with a single Tesla M10.
Two 2016 Remote Desktop Session Host guest OSEs that have a GPU assigned to them via DDA.
75 total users who need to run apps on the RDS servers.
-- 10 of which are power users who use apps that required GPU acceleration
My understanding from the reading the licensing guide is that I need 75 GRID Virtual Applications (vApp) CCU subscriptions, but I would like to verify.
Thanks in advanced,
Ben
回帖(4)
蔡鼎瑾
2018-9-7 16:58:30
嗨本,
正确。
如果您已经分配了GPU,那么用户是否需要GPU加速并不重要,因此只要这些用户同时连接,您就需要许可所有75个用户。
如果您只有60个并发用户,则需要60个vApp许可证。
问候
西蒙
以上来自于谷歌翻译
以下为原文
Hi Ben,
Correct. As you have the GPU assigned it doesn't really matter if a user would require GPU acceleration or not so you need to license all 75 users as long as these users connect concurrently. If you have only 60 concurrent users as example you would need 60 vApps licenses.
Regards
Simon
举报
倪驰銮
2018-9-7 17:04:02
感谢您的快速回复,还有一个问题。
NVIDIA是否实时定义“同时”?
换句话说,用户断开连接后是否立即发布许可证?
或者他们是否必须签署RDS会话?
我问,因为我们的RDS利用率从未高于我们总用户的50%,但许多用户只会断开会话,因此他们可以在以后更快地重新加入。
以上来自于谷歌翻译
以下为原文
Thanks for the prompt response, one more question. Does NVIDIA define "concurrently" in real time? In other words, is a license released immediately after a user disconnects? Or do they have to sign off the RDS session?
I ask because our RDS utilization has never been higher than 50% of our total users, but many users will simply disconnect a session, so they can re-join it more quickly later.
举报
马慧霞
2018-9-7 17:17:59
并发包括断开连接的用户,因为这些用户仍然使用GPU。
您需要暂停VM以释放RDSH不可行的许可证,但作为VDI的示例。
以上来自于谷歌翻译
以下为原文
Concurrent includes disconnected users as these users still consume GPU. You would need to suspend a VM to release the license which is not feasible for RDSH but works as example for VDI.
举报
王春梅
2018-9-7 17:36:40
Nvidia是否使用硬许可?
如果您使用所有并发许可证会发生什么?
你能用GPU开启新的VM吗?
你能无限期地过度使用用户许可吗?
问候。
以上来自于谷歌翻译
以下为原文
Does Nvidia use hard licensing? What happens if you use all your concurrent licenses? Will you be able to power on new VMs with GPU? Can you indefinitely overcommit the user licensing?
Regards.
举报
更多回帖
