你好
除了上面提到的单一显示器和显示器分辨率限制之外,您的客户是否考虑了他们将从哪里获得M10驱动程序,如何在发布新驱动程序时升级/维护这些驱动程序以及他们如何监控和支持GPU?
目前,M10驱动程序似乎无法从可公开访问的Nvidia驱动程序下载页面获得,这显然使得入门有点棘手。
他们是否会在某个时刻,我不确定。
我在论坛上看到了无数的线程,询问他们在哪里得到了早期版本GPU的支持,原因有多种,通常是K1 / K2卡。
答案总是“回到你从哪里购买”,这通常是合作伙伴/转售商,可能没有客户解决问题所需的深入知识和技能,即使他们这样做
,他们是24x7吗?
我知道你的客户显然是在努力降低成本,但是SUMs值得拥有。
由于这些GPU将在Passthrough中运行,因此Hypervisor无法真正看到它们,并且由于您的客户端不会在Hypervisor中安装驱动程序,因此他们必须从各个VM中监视它们,而不是通过
虚拟机管理程序。
跟踪GPU利用率以获得规模/性能虽然显然可行,但并不容易。
只是出于兴趣,是您的客户不喜欢的物理GPU的成本,还是许可模式的成本?
问候
本
以上来自于谷歌翻译
以下为原文
Hi
Apart from the single monitor and display resolution limitations mentioned above, has your client considered where they will get the M10 drivers from, how they will upgrade / maintain those drivers when new ones are released and also how they will monitor and support the GPUs?
Currently, the M10 drivers do not appear to be available from the publicly accessible Nvidia drivers download page, this obviously makes getting started a little tricky. Whether they will be at some point, I'm unsure.
I have seen
countless threads on forums asking where they get support for earlier version GPUs for a wide variety of reasons, usually these are the K1 / K2 cards. And the answer is always, "Go back to where you purchased them from", which is typically a partner / re-seller who may not have the in-depth knowledge and skills your client needs to resolve their issue, and even if they do, are they 24x7? I know your client is obviously trying to reduce costs, but SUMs is worth having.
As these GPUs will be run in Passthrough, the Hypervisor can't
really see them, and as your client won't be installing a driver in the Hypervisor, they'll have to monitor them from within the individual VMs, rather than through the Hypervisor. Tracking GPU utilisation for scale / performance, although obviously possible, won't be so easy.
Just out of interest, is it the cost of the physical GPUs your client doesn't like, or the cost of the licensing model?
Regards
Ben
你好
他们是否会在某个时刻,我不确定。
,他们是24x7吗?
虚拟机管理程序。
问候
本
以上来自于谷歌翻译
以下为原文
Hi
I have seen
Regards
Ben
举报
