简化,我用钻头与一个电阻和一个运放组合(缓冲区)到另一个可变电阻产生电压。Simultanouesly,我是测量电流通过可变电阻功耗的计算。
我想保持进一步调节恒电力过程。计算该规定的公差,我需要知道所有的漂移参数。
最好的问候,
罗宾
以上来自于百度翻译
以下为原文
Simplified, I am using the IDAC in combination with a resistor and an Opamp (Buffer) to generate a voltage over another variable resistor. Simultanouesly, I am measuring the current through the variable resistor to calculate the power dissipation.
I want to keep the electrical power constant for futher regulation processes. To calculate the tolerances of this regulation, I need to know all drift parameters.
Best regards,
Robin
最好的问候,
罗宾
以上来自于百度翻译
以下为原文
Best regards,
Robin
举报
