Cypress技术论坛
直播中
王军
7年用户 1766经验值
私信 关注
[问答]
请问有没有办法禁用PSOC3引脚上的ESD保护二极管?
这听起来像是一个愚蠢的想法,但是当你试图将热电偶多路复用到Delsig中时,你需要任何类型的通道来隔离,这些二极管妨碍了你!有人有什么建议吗?我们真的很接近释放这个产品,所以董事会的设计变更是不可能的。
迈克。
以上来自于百度翻译
        以下为原文
                                            This may sound like a dumb idea, but when you are trying to multiplex Thermocouples into the DelSig and you want any kind of channel to channel isolation, those diodes get in the way!  Anyone have any suggestions?  We are really close to releasing this product so a board design change is not possible.
Mike.
回帖(5)
华意仆
2018-8-20 03:58:14
你好,
这可能会有帮助。HTTP://www. CyPress .COM/FIL/123806/下载
以上来自于百度翻译
        以下为原文
                                            Hi,
This might be helpful. http://www.cypress.com/file/123806/download
举报
王军
2018-8-20 04:08:27
引用: 非常perfect 发表于 2018-8-20 03:58
你好,
不幸的是,App Note根本没有解决通道到通道隔离的问题。
迈克。
以上来自于百度翻译
        以下为原文
                                            Unfortunately that App note does not address channel to channel isolation at all.
Mike.
举报
胡书琴
2018-8-20 04:26:55
你好,迈克,
不幸的是,这是不可能的。不能禁用ESD DIDO。多通道输入是影响其他频道吗?
最佳问候
以上来自于百度翻译
        以下为原文
                                            Hello Mike,
Unfortunately it will not be possible. The ESD didoes cannot be disabled. How  much one channel input is influencing the other channel ?
Best Regards,
VSRS
举报
王军
2018-8-20 04:40:43
引用: EnjoyL 发表于 2018-8-20 04:26
你好,迈克,
最佳问候
好的,我很清楚是什么答案都是消极的一面(二极管,内部接地),但积极的一面去VDDIO。如果我们不需要任何引脚驱动高,那么如果VDDIO是悬空的二极管可以有效(虽然没有共有他们一起回到频道)。
这不是一个一个通道的影响在其他情况下,除非他们之间有电压差(普通模式),使二极管导通。这可以从60Hz交流耦合到线路长工业工厂中发生。
迈克。
以上来自于百度翻译
        以下为原文
                                            Well, I was pretty sure that was what the answer would be for the negative side (diodes that are internally grounded), but the positive side goes to Vddio.  If we didn't need to drive any pins high, then if Vddio was left unconnected those diodes would be effectively not there (although commoned together they are back to back from channel to channel).
This is not a case of one channel influencing the other UNLESS there is a voltage difference between them (common mode) that then causes the diodes to conduct.  This can happen from 60Hz AC being coupled to long lines in an industrial plant.
Mike.
举报
更多回帖
