//*****************************************************************************//// mpu6050.c - Driver for the MPU6050 accelerometer and gyroscope.//// Copyright (c) 2013-2017 Texas Instruments Incorporated. All rights reserved.// Software License Agreement// // Texas Instruments (TI) is supplying this software for use solely and// exclusively on TI's microcontroller products. The software is owned by// TI and/or its suppliers, and is protected under applicable copyright// laws. You may not combine this software with "viral" open-source// software in order to form a larger program.// // THIS SOFTWARE IS PROVIDED "AS IS" AND WITH ALL FAULTS.// NO WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT// NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR// A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. TI SHALL NOT, UNDER ANY// CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR CONSEQUENTIAL// DAMAGES, FOR ANY REASON WHATSOEVER.// // This is part of revision 2.1.4.178 of the Tiva Firmware Development Package.////*****************************************************************************#include
#include "sensorlib/hw_mpu6050.h"#include "sensorlib/i2cm_drv.h"#include "sensorlib/mpu6050.h"//*****************************************************************************////! addtogroup mpu6050_api//! @[////*****************************************************************************//*****************************************************************************//// The states of the MPU6050 state machine.////*****************************************************************************#define MPU6050_STATE_IDLE 0 // State machine is idle#define MPU6050_STATE_INIT_RES 1 // Waiting for initialization#define MPU6050_STATE_INIT_WAIT 2 // Waiting for reset to complete#define MPU6050_STATE_READ 3 // Waiting for read#define MPU6050_STATE_WRITE 4 // Waiting for write#define MPU6050_STATE_RMW 5 // Waiting for read-modify-write//*****************************************************************************//// The factors used to convert the acceleration readings from the MPU6050 into// floating point values in meters per second squared.//// Values are obtained by taking the g conversion factors from the data sheet// and multiplying by 9.81 (1 g = 9.81 m/s^2).////*****************************************************************************static const float g_fMPU6050AccelFactors[] =[ 0.00059875, // Range = +/- 2 g (16384 l***/g) 0.00119751, // Range = +/- 4 g (8192 l***/g) 0.00239502, // Range = +/- 8 g (4096 l***/g) 0.00479004 // Range = +/- 16 g (2048 l***/g)];//*****************************************************************************//// The factors used to convert the acceleration readings from the MPU6050 into// floating point values in radians per second.//// Values are obtained by taking the degree per second conversion factors// from the data sheet and then converting to radians per sec (1 degree =// 0.0174532925 radians).////*****************************************************************************static const float g_fMPU6050GyroFactors[] =[ 1.3323124e-4f, // Range = +/- 250 dps (131.0 LSBs/DPS) 2.6646248e-4f, // Range = +/- 500 dps (65.5 LSBs/DPS) 5.3211258e-4f, // Range = +/- 1000 dps (32.8 LSBs/DPS) 0.0010642252f // Range = +/- 2000 dps (16.4 LSBs/DPS)];//*****************************************************************************//// The callback function that is called when I2C transations to/from the// MPU6050 have completed.////*****************************************************************************static voidMPU6050Callback(void *pvCallbackData, uint_fast8_t ui8Status)[ tMPU6050 *psInst; // // Convert the instance data into a pointer to a tMPU6050 structure. // psInst = pvCallbackData; // // If the I2C master driver encountered a failure, force the state machine // to the idle state (which will also result in a callback to propagate the // error). Except in the case that we are in the reset wait state and the // error is an address NACK. This error is handled by the reset wait // state. // if((ui8Status != I2CM_STATUS_SUCCESS) && !((ui8Status == I2CM_STATUS_ADDR_NACK) && (psInst->ui8State == MPU6050_STATE_INIT_WAIT))) [ psInst->ui8State = MPU6050_STATE_IDLE; ] // // Determine the current state of the MPU6050 state machine. // switch(psInst->ui8State) [ // // All states that trivially transition to IDLE, and all unknown // states. // case MPU6050_STATE_READ: default: [ // // The state machine is now idle. // psInst->ui8State = MPU6050_STATE_IDLE; // // Done. // break; ] // // MPU6050 Device reset was issued // case MPU6050_STATE_INIT_RES: [ // // Issue a read of the status register to confirm reset is done. // psInst->uCommand.pui8Buffer[0] = MPU6050_O_PWR_MGMT_1; I2CMRead(psInst->psI2CInst, psInst->ui8Addr, psInst->uCommand.pui8Buffer, 1, psInst->pui8Data, 1, MPU6050Callback, psInst); psInst->ui8State = MPU6050_STATE_INIT_WAIT; break; ] // // Status register was read, check if reset is done before proceeding. // case MPU6050_STATE_INIT_WAIT: [ // // Check the value read back from status to determine if device // is still in reset or if it is ready. Reset state for this // register is 0x40, which has sleep bit set. Device may also // respond with an address NACK during very early stages of the its // internal reset. Keep polling until we verify device is ready. // // if((psInst->pui8Data[0] != MPU6050_PWR_MGMT_1_SLEEP) || (ui8Status == I2CM_STATUS_ADDR_NACK)) [ // // Device still in reset so begin polling this register. // psInst->uCommand.pui8Buffer[0] = MPU6050_O_PWR_MGMT_1; I2CMRead(psInst->psI2CInst, psInst->ui8Addr, psInst->uCommand.pui8Buffer, 1, psInst->pui8Data, 1, MPU6050Callback, psInst); // // Intentionally stay in this state to create polling effect. // ] else [ // // Device is out of reset, move to the idle state. // psInst->ui8State = MPU6050_STATE_IDLE; ] break; ] // // A write just completed // case MPU6050_STATE_WRITE: [ // // Set the accelerometer and gyroscope ranges to the new values. // If the register was not modified, the values will be the same so // this has no effect. // psInst->ui8AccelAfsSel = psInst->ui8NewAccelAfsSel; psInst->ui8GyroFsSel = psInst->ui8NewGyroFsSel; // // The state machine is now idle. // psInst->ui8State = MPU6050_STATE_IDLE; // // Done. // break; ] // // A read-modify-write just completed // case MPU6050_STATE_RMW: [ // // See if the PWR_MGMT_1 register was just modified. // if(psInst->uCommand.sReadModifyWriteState.pui8Buffer[0] == MPU6050_O_PWR_MGMT_1) [ // // See if a soft reset has been issued. // if(psInst->uCommand.sReadModifyWriteState.pui8Buffer[1] & MPU6050_PWR_MGMT_1_DEVICE_RESET) [ // // Default range setting is +/- 2 g // psInst->ui8AccelAfsSel = 0; psInst->ui8NewAccelAfsSel = 0; // // Default range setting is +/- 250 degrees/s // psInst->ui8GyroFsSel = 0; psInst->ui8NewGyroFsSel = 0; ] ] // // See if the GYRO_CONFIG register was just modified. // if(psInst->uCommand.sReadModifyWriteState.pui8Buffer[0] == MPU6050_O_GYRO_CONFIG) [ // // Extract the FS_SEL from the GYRO_CONFIG register value. // psInst->ui8GyroFsSel = ((psInst->uCommand.sReadModifyWriteState.pui8Buffer[1] & MPU6050_GYRO_CONFIG_FS_SEL_M) >> MPU6050_GYRO_CONFIG_FS_SEL_S); ] // // See if the ACCEL_CONFIG register was just modified. // if(psInst->uCommand.sReadModifyWriteState.pui8Buffer[0] == MPU6050_O_ACCEL_CONFIG) [ // // Extract the FS_SEL from the ACCEL_CONFIG register value. // psInst->ui8AccelAfsSel = ((psInst->uCommand.sReadModifyWriteState.pui8Buffer[1] & MPU6050_ACCEL_CONFIG_AFS_SEL_M) >> MPU6050_ACCEL_CONFIG_AFS_SEL_S); ] // // The state machine is now idle. // psInst->ui8State = MPU6050_STATE_IDLE; // // Done. // break; ] ] // // See if the state machine is now idle and there is a callback function. // if((psInst->ui8State == MPU6050_STATE_IDLE) && psInst->pfnCallback) [ // // Call the application-supplied callback function. // psInst->pfnCallback(psInst->pvCallbackData, ui8Status); ]]//*****************************************************************************////! Initializes the MPU6050 driver.//!//! param psInst is a pointer to the MPU6050 instance data.//! param psI2CInst is a pointer to the I2C master driver instance data.//! param ui8I2CAddr is the I2C address of the MPU6050 device.//! param pfnCallback is the function to be called when the initialization has//! completed (can be b NULL if a callback is not required).//! param pvCallbackData is a pointer that is passed to the callback function.//!//! This function initializes the MPU6050 driver, preparing it for operation.//!//! return Returns 1 if the MPU6050 driver was successfully initialized and 0//! if it was not.////*****************************************************************************uint_fast8_tMPU6050Init(tMPU6050 *psInst, tI2CMInstance *psI2CInst, uint_fast8_t ui8I2CAddr, tSensorCallback *pfnCallback, void *pvCallbackData)[ // // Initialize the MPU6050 instance structure. // psInst->psI2CInst = psI2CInst; psInst->ui8Addr = ui8I2CAddr; // // Save the callback information. // psInst->pfnCallback = pfnCallback; psInst->pvCallbackData = pvCallbackData; // // Default range setting is +/- 2 g // psInst->ui8AccelAfsSel = (MPU6050_ACCEL_CONFIG_AFS_SEL_2G >> MPU6050_ACCEL_CONFIG_AFS_SEL_S); psInst->ui8NewAccelAfsSel = (MPU6050_ACCEL_CONFIG_AFS_SEL_2G >> MPU6050_ACCEL_CONFIG_AFS_SEL_S); // // Default range setting is +/- 250 degrees/s // psInst->ui8GyroFsSel = (MPU6050_GYRO_CONFIG_FS_SEL_250 >> MPU6050_GYRO_CONFIG_FS_SEL_S); psInst->ui8NewGyroFsSel = (MPU6050_GYRO_CONFIG_FS_SEL_250 >> MPU6050_GYRO_CONFIG_FS_SEL_S); // // Set the state to show we are initiating a reset. // psInst->ui8State = MPU6050_STATE_INIT_RES; // // Load the buffer with command to perform device reset // psInst->uCommand.pui8Buffer[0] = MPU6050_O_PWR_MGMT_1; psInst->uCommand.pui8Buffer[1] = MPU6050_PWR_MGMT_1_DEVICE_RESET; if(I2CMWrite(psInst->psI2CInst, psInst->ui8Addr, psInst->uCommand.pui8Buffer, 2, MPU6050Callback, psInst) == 0) [ psInst->ui8State = MPU6050_STATE_IDLE; return(0); ] // // Success // return(1);]//*****************************************************************************////! Reads data from MPU6050 registers.//!//! param psInst is a pointer to the MPU6050 instance data.//! param ui8Reg is the first register to read.//! param pui8Data is a pointer to the location to store the data that is//! read.//! param ui16Count is the number of data bytes to read.//! param pfnCallback is the function to be called when the data has been read//! (can be b NULL if a callback is not required).//! param pvCallbackData is a pointer that is passed to the callback function.//!//! This function reads a sequence of data values from consecutive registers in//! the MPU6050.//!//! return Returns 1 if the write was successfully started and 0 if it was//! not.////*****************************************************************************uint_fast8_tMPU6050Read(tMPU6050 *psInst, uint_fast8_t ui8Reg, uint8_t *pui8Data, uint_fast16_t ui16Count, tSensorCallback *pfnCallback, void *pvCallbackData)[ // // Return a failure if the MPU6050 driver is not idle (in other words, // there is already an outstanding request to the MPU6050). // if(psInst->ui8State != MPU6050_STATE_IDLE) [ return(0); ] // // Save the callback information. // psInst->pfnCallback = pfnCallback; psInst->pvCallbackData = pvCallbackData; // // Move the state machine to the wait for read state. // psInst->ui8State = MPU6050_STATE_READ; // // Read the requested registers from the MPU6050. // psInst->uCommand.pui8Buffer[0] = ui8Reg; if(I2CMRead(psInst->psI2CInst, psInst->ui8Addr, psInst->uCommand.pui8Buffer, 1, pui8Data, ui16Count, MPU6050Callback, psInst) == 0) [ // // The I2C write failed, so move to the idle state and return a // failure. // psInst->ui8State = MPU6050_STATE_IDLE; return(0); ] // // Success. // return(1);]//*****************************************************************************////! Writes data to MPU6050 registers.//!//! param psInst is a pointer to the MPU6050 instance data.//! param ui8Reg is the first register to write.//! param pui8Data is a pointer to the data to write.//! param ui16Count is the number of data bytes to write.//! param pfnCallback is the function to be called when the data has been//! written (can be b NULL if a callback is not required).//! param pvCallbackData is a pointer that is passed to the callback function.//!//! This function writes a sequence of data values to consecutive registers in//! the MPU6050. The first byte of the e pui8Data buffer contains the value//! to be written into the e ui8Reg register, the second value contains the//! data to be written into the next register, and so on.//!//! return Returns 1 if the write was successfully started and 0 if it was//! not.////*****************************************************************************uint_fast8_tMPU6050Write(tMPU6050 *psInst, uint_fast8_t ui8Reg, const uint8_t *pui8Data, uint_fast16_t ui16Count, tSensorCallback *pfnCallback, void *pvCallbackData)[ // // Return a failure if the MPU6050 driver is not idle (in other words, // there is already an outstanding request to the MPU6050). // if(psInst->ui8State != MPU6050_STATE_IDLE) [ return(0); ] // // Save the callback information. // psInst->pfnCallback = pfnCallback; psInst->pvCallbackData = pvCallbackData; // // See if the PWR_MGMT_1 register is being written. // if((ui8Reg <= MPU6050_O_PWR_MGMT_1) && ((ui8Reg + ui16Count) > MPU6050_O_PWR_MGMT_1)) [ // // See if a soft reset is being requested. // if(pui8Data[ui8Reg - MPU6050_O_PWR_MGMT_1] & MPU6050_PWR_MGMT_1_DEVICE_RESET) [ // // Default range setting is +/- 2 g. // psInst->ui8NewAccelAfsSel = 0; // // Default range setting is +/- 250 degrees/s. // psInst->ui8NewGyroFsSel = 0; ] ] // // See if the GYRO_CONFIG register is being written. // if((ui8Reg <= MPU6050_O_GYRO_CONFIG) && ((ui8Reg + ui16Count) > MPU6050_O_GYRO_CONFIG)) [ // // Extract the FS_SEL from the GYRO_CONFIG register value. // psInst->ui8NewGyroFsSel = ((pui8Data[ui8Reg - MPU6050_O_GYRO_CONFIG] & MPU6050_GYRO_CONFIG_FS_SEL_M) >> MPU6050_GYRO_CONFIG_FS_SEL_S); ] // // See if the ACCEL_CONFIG register is being written. // if((ui8Reg <= MPU6050_O_ACCEL_CONFIG) && ((ui8Reg + ui16Count) > MPU6050_O_ACCEL_CONFIG)) [ // // Extract the AFS_SEL from the ACCEL_CONFIG register value. // psInst->ui8NewAccelAfsSel = ((pui8Data[ui8Reg - MPU6050_O_ACCEL_CONFIG] & MPU6050_ACCEL_CONFIG_AFS_SEL_M) >> MPU6050_ACCEL_CONFIG_AFS_SEL_S); ] // // Move the state machine to the wait for write state. // psInst->ui8State = MPU6050_STATE_WRITE; // // Write the requested registers to the MPU6050. // if(I2CMWrite8(&(psInst->uCommand.sWriteState), psInst->psI2CInst, psInst->ui8Addr, ui8Reg, pui8Data, ui16Count, MPU6050Callback, psInst) == 0) [ // // The I2C write failed, so move to the idle state and return a // failure. // psInst->ui8State = MPU6050_STATE_IDLE; return(0); ] // // Success. // return(1);]//*****************************************************************************////! Performs a read-modify-write of a MPU6050 register.//!//! param psInst is a pointer to the MPU6050 instance data.//! param ui8Reg is the register to modify.//! param ui8Mask is the bit mask that is ANDed with the current register//! value.//! param ui8Value is the bit mask that is ORed with the result of the AND//! operation.//! param pfnCallback is the function to be called when the data has been//! changed (can be b NULL if a callback is not required).//! param pvCallbackData is a pointer that is passed to the callback function.//!//! This function changes the value of a register in the MPU6050 via a//! read-modify-write operation, allowing one of the fields to be changed//! without disturbing the other fields. The e ui8Reg register is read, ANDed//! with e ui8Mask, ORed with e ui8Value, and then written back to the//! MPU6050.//!//! return Returns 1 if the read-modify-write was successfully started and 0//! if it was not.////*****************************************************************************uint_fast8_tMPU6050ReadModifyWrite(tMPU6050 *psInst, uint_fast8_t ui8Reg, uint_fast8_t ui8Mask, uint_fast8_t ui8Value, tSensorCallback *pfnCallback, void *pvCallbackData)[ // // Return a failure if the MPU6050 driver is not idle (in other words, // there is already an outstanding request to the MPU6050). // if(psInst->ui8State != MPU6050_STATE_IDLE) [ return(0); ] // // Save the callback information. // psInst->pfnCallback = pfnCallback; psInst->pvCallbackData = pvCallbackData; // // Move the state machine to the wait for read-modify-write state. // psInst->ui8State = MPU6050_STATE_RMW; // // Submit the read-modify-write request to the MPU6050. // if(I2CMReadModifyWrite8(&(psInst->uCommand.sReadModifyWriteState), psInst->psI2CInst, psInst->ui8Addr, ui8Reg, ui8Mask, ui8Value, MPU6050Callback, psInst) == 0) [ // // The I2C read-modify-write failed, so move to the idle state and // return a failure. // psInst->ui8State = MPU6050_STATE_IDLE; return(0); ] // // Success. // return(1);]//*****************************************************************************////! Reads the accelerometer and gyroscope data from the MPU6050.//!//! param psInst is a pointer to the MPU6050 instance data.//! param pfnCallback is the function to be called when the data has been read//! (can be b NULL if a callback is not required).//! param pvCallbackData is a pointer that is passed to the callback function.//!//! This function initiates a read of the MPU6050 data registers. When the//! read has completed (as indicated by calling the callback function), the new//! readings can be obtained via://!//! - MPU6050DataAccelGetRaw()//! - MPU6050DataAccelGetFloat()//! - MPU6050DataGyroGetRaw()//! - MPU6050DataGyroGetFloat()//!//! return Returns 1 if the read was successfully started and 0 if it was not.////*****************************************************************************uint_fast8_tMPU6050DataRead(tMPU6050 *psInst, tSensorCallback *pfnCallback, void *pvCallbackData)[ // // Return a failure if the MPU6050 driver is not idle (in other words, // there is already an outstanding request to the MPU6050). // if(psInst->ui8State != MPU6050_STATE_IDLE) [ return(0); ] // // Save the callback information. // psInst->pfnCallback = pfnCallback; psInst->pvCallbackData = pvCallbackData; // // Move the state machine to the wait for data read state. // psInst->ui8State = MPU6050_STATE_READ; // // Read the data registers from the MPU6050. // psInst->pui8Data[0] = MPU6050_O_ACCEL_XOUT_H; if(I2CMRead(psInst->psI2CInst, psInst->ui8Addr, psInst->pui8Data, 1, psInst->pui8Data, 14, MPU6050Callback, psInst) == 0) [ // // The I2C read failed, so move to the idle state and return a failure. // psInst->ui8State = MPU6050_STATE_IDLE; return(0); ] // // Success. // return(1);]//*****************************************************************************////! Gets the raw accelerometer data from the most recent data read.//!//! param psInst is a pointer to the MPU6050 instance data.//! param pui16AccelX is a pointer to the value into which the raw X-axis//! accelerometer data is stored.//! param pui16AccelY is a pointer to the value into which the raw Y-axis//! accelerometer data is stored.//! param pui16AccelZ is a pointer to the value into which the raw Z-axis//! accelerometer data is stored.//!//! This function returns the raw accelerometer data from the most recent data//! read. The data is not manipulated in any way by the driver. If any of the//! output data pointers are b NULL, the corresponding data is not provided.//!//! return None.////*****************************************************************************voidMPU6050DataAccelGetRaw(tMPU6050 *psInst, uint_fast16_t *pui16AccelX, uint_fast16_t *pui16AccelY, uint_fast16_t *pui16AccelZ)[ // // Return the raw accelerometer values. // if(pui16AccelX) [ *pui16AccelX = (psInst->pui8Data[0] << 8) | psInst->pui8Data[1]; ] if(pui16AccelY) [ *pui16AccelY = (psInst->pui8Data[2] << 8) | psInst->pui8Data[3]; ] if(pui16AccelZ) [ *pui16AccelZ = (psInst->pui8Data[4] << 8) | psInst->pui8Data[5]; ]]//*****************************************************************************////! Gets the accelerometer data from the most recent data read.//!//! param psInst is a pointer to the MPU6050 instance data.//! param pfAccelX is a pointer to the value into which the X-axis//! accelerometer data is stored.//! param pfAccelY is a pointer to the value into which the Y-axis//! accelerometer data is stored.//! param pfAccelZ is a pointer to the value into which the Z-axis//! accelerometer data is stored.//!//! This function returns the accelerometer data from the most recent data//! read, converted into meters per second squared (m/s^2). If any of the//! output data pointers are b NULL, the corresponding data is not provided.//!//! return None.////*****************************************************************************voidMPU6050DataAccelGetFloat(tMPU6050 *psInst, float *pfAccelX, float *pfAccelY, float *pfAccelZ)[ float fFactor; // // Get the acceleration conversion factor for the current data format. // fFactor = g_fMPU6050AccelFactors[psInst->ui8AccelAfsSel]; // // Convert the Accelerometer values into floating-point gravity values. // if(pfAccelX) [ *pfAccelX = (float)((int16_t)((psInst->pui8Data[0] << 8) | psInst->pui8Data[1]) * fFactor); ] if(pfAccelY) [ *pfAccelY = (float)((int16_t)((psInst->pui8Data[2] << 8) | psInst->pui8Data[3]) * fFactor); ] if(pfAccelZ) [ *pfAccelZ = (float)((int16_t)((psInst->pui8Data[4] << 8) | psInst->pui8Data[5]) * fFactor); ]]//*****************************************************************************////! Gets the raw gyroscope data from the most recent data read.//!//! param psInst is a pointer to the MPU6050 instance data.//! param pui16GyroX is a pointer to the value into which the raw X-axis//! gyroscope data is stored.//! param pui16GyroY is a pointer to the value into which the raw Y-axis//! gyroscope data is stored.//! param pui16GyroZ is a pointer to the value into which the raw Z-axis//! gyroscope data is stored.//!//! This function returns the raw gyroscope data from the most recent data//! read. The data is not manipulated in any way by the driver. If any of the//! output data pointers are b NULL, the corresponding data is not provided.//!//! return None.////*****************************************************************************voidMPU6050DataGyroGetRaw(tMPU6050 *psInst, uint_fast16_t *pui16GyroX, uint_fast16_t *pui16GyroY, uint_fast16_t *pui16GyroZ)[ // // Return the raw gyroscope values. // if(pui16GyroX) [ *pui16GyroX = (psInst->pui8Data[8] << 8) | psInst->pui8Data[9]; ] if(pui16GyroY) [ *pui16GyroY = (psInst->pui8Data[10] << 8) | psInst->pui8Data[11]; ] if(pui16GyroZ) [ *pui16GyroZ = (psInst->pui8Data[12] << 8) | psInst->pui8Data[13]; ]]//*****************************************************************************////! Gets the gyroscope data from the most recent data read.//!//! param psInst is a pointer to the MPU6050 instance data.//! param pfGyroX is a pointer to the value into which the X-axis//! gyroscope data is stored.//! param pfGyroY is a pointer to the value into which the Y-axis//! gyroscope data is stored.//! param pfGyroZ is a pointer to the value into which the Z-axis//! gyroscope data is stored.//!//! This function returns the gyroscope data from the most recent data read,//! converted into radians per second. If any of the output data pointers are//! b NULL, the corresponding data is not provided.//!//! return None.////*****************************************************************************voidMPU6050DataGyroGetFloat(tMPU6050 *psInst, float *pfGyroX, float *pfGyroY, float *pfGyroZ)[ float fFactor; // // Get the conversion factor for the current data format. // fFactor = g_fMPU6050GyroFactors[psInst->ui8GyroFsSel]; // // Convert the gyroscope values into rad/sec // if(pfGyroX) [ *pfGyroX = ((float)(int16_t)((psInst->pui8Data[8] << 8) | psInst->pui8Data[9]) * fFactor); ] if(pfGyroY) [ *pfGyroY = ((float)(int16_t)((psInst->pui8Data[10] << 8) | psInst->pui8Data[11]) * fFactor); ] if(pfGyroZ) [ *pfGyroZ = ((float)(int16_t)((psInst->pui8Data[12] << 8) | psInst->pui8Data[13]) * fFactor); ]]//*****************************************************************************//// Close the Doxygen group.//! @]////*****************************************************************************//*****************************************************************************//// mpu6050.h - Prototypes for the MPU6050 accelerometer and gyroscope driver.//// Copyright (c) 2013-2017 Texas Instruments Incorporated. All rights reserved.// Software License Agreement// // Texas Instruments (TI) is supplying this software for use solely and// exclusively on TI's microcontroller products. The software is owned by// TI and/or its suppliers, and is protected under applicable copyright// laws. You may not combine this software with "viral" open-source// software in order to form a larger program.// // THIS SOFTWARE IS PROVIDED "AS IS" AND WITH ALL FAULTS.// NO WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT// NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR// A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. TI SHALL NOT, UNDER ANY// CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR CONSEQUENTIAL// DAMAGES, FOR ANY REASON WHATSOEVER.// // This is part of revision 2.1.4.178 of the Tiva Firmware Development Package.////*****************************************************************************#ifndef __SENSORLIB_MPU6050_H__#define __SENSORLIB_MPU6050_H__//*****************************************************************************//// If building with a C++ compiler, make all of the definitions in this header// have a C binding.////*****************************************************************************#ifdef __cplusplusextern "C"[#endif//*****************************************************************************//// The structure that defines the internal state of the MPU6050 driver.////*****************************************************************************typedef struct[ // // The pointer to the I2C master interface instance used to communicate // with the MPU6050. // tI2CMInstance *psI2CInst; // // The I2C address of the MPU6050. // uint8_t ui8Addr; // // The state of the state machine used while accessing the MPU6050. // uint8_t ui8State; // // The current accelerometer afs_sel setting. // uint8_t ui8AccelAfsSel; // // The new accelerometer afs_sel setting, which is used when a register // write succeeds. // uint8_t ui8NewAccelAfsSel; // // The current gyroscope fs_sel setting. // uint8_t ui8GyroFsSel; // // The new gyroscope fs_sel setting, which is used when a register write // succeeds. // uint8_t ui8NewGyroFsSel; // // The data buffer used for sending/receiving data to/from the MPU6050. // uint8_t pui8Data[16]; // // The function that is called when the current request has completed // processing. // tSensorCallback *pfnCallback; // // The callback data provided to the callback function. // void *pvCallbackData; // // A union of structures that are used for read, write and // read-modify-write operations. Since only one operation can be active at // a time, it is safe to re-use the memory in this manner. // union [ // // A buffer used to store the write portion of a register read. // uint8_t pui8Buffer[2]; // // The write state used to write register values. // tI2CMWrite8 sWriteState; // // The read-modify-write state used to modify register values. // tI2CMReadModifyWrite8 sReadModifyWriteState; ] uCommand;]tMPU6050;//*****************************************************************************//// Function prototypes.////*****************************************************************************extern uint_fast8_t MPU6050Init(tMPU6050 *psInst, tI2CMInstance *psI2CInst, uint_fast8_t ui8I2CAddr, tSensorCallback *pfnCallback, void *pvCallbackData);extern uint_fast8_t MPU6050Read(tMPU6050 *psInst, uint_fast8_t ui8Reg, uint8_t *pui8Data, uint_fast16_t ui16Count, tSensorCallback *pfnCallback, void *pvCallbackData);extern uint_fast8_t MPU6050Write(tMPU6050 *psInst, uint_fast8_t ui8Reg, const uint8_t *pui8Data, uint_fast16_t ui16Count, tSensorCallback *pfnCallback, void *pvCallbackData);extern uint_fast8_t MPU6050ReadModifyWrite(tMPU6050 *psInst, uint_fast8_t ui8Reg, uint_fast8_t ui8Mask, uint_fast8_t ui8Value, tSensorCallback *pfnCallback, void *pvCallbackData);extern uint_fast8_t MPU6050DataRead(tMPU6050 *psInst, tSensorCallback *pfnCallback, void *pvCallbackData);extern void MPU6050DataAccelGetRaw(tMPU6050 *psInst, uint_fast16_t *pui16AccelX, uint_fast16_t *pui16AccelY, uint_fast16_t *pui16AccelZ);extern void MPU6050DataAccelGetFloat(tMPU6050 *psInst, float *pfAccelX, float *pfAccelY, float *pfAccelZ);extern void MPU6050DataGyroGetRaw(tMPU6050 *psInst, uint_fast16_t *pui16GyroX, uint_fast16_t *pui16GyroY, uint_fast16_t *pui16GyroZ);extern void MPU6050DataGyroGetFloat(tMPU6050 *psInst, float *pfGyroX, float *pfGyroY, float *pfGyroZ);//*****************************************************************************//// Mark the end of the C bindings section for C++ compilers.////*****************************************************************************#ifdef __cplusplus]#endif#endif // __SENSORLIB_MPU6050_H__
关于mpu6050的驱动,TI是提供了第三方的库的
//*****************************************************************************//// mpu6050.c - Driver for the MPU6050 accelerometer and gyroscope.//// Copyright (c) 2013-2017 Texas Instruments Incorporated. All rights reserved.// Software License Agreement// // Texas Instruments (TI) is supplying this software for use solely and// exclusively on TI's microcontroller products. The software is owned by// TI and/or its suppliers, and is protected under applicable copyright// laws. You may not combine this software with "viral" open-source// software in order to form a larger program.// // THIS SOFTWARE IS PROVIDED "AS IS" AND WITH ALL FAULTS.// NO WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT// NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR// A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. TI SHALL NOT, UNDER ANY// CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR CONSEQUENTIAL// DAMAGES, FOR ANY REASON WHATSOEVER.// // This is part of revision 2.1.4.178 of the Tiva Firmware Development Package.////*****************************************************************************#include #include "sensorlib/hw_mpu6050.h"#include "sensorlib/i2cm_drv.h"#include "sensorlib/mpu6050.h"//*****************************************************************************////! addtogroup mpu6050_api//! @[////*****************************************************************************//*****************************************************************************//// The states of the MPU6050 state machine.////*****************************************************************************#define MPU6050_STATE_IDLE 0 // State machine is idle#define MPU6050_STATE_INIT_RES 1 // Waiting for initialization#define MPU6050_STATE_INIT_WAIT 2 // Waiting for reset to complete#define MPU6050_STATE_READ 3 // Waiting for read#define MPU6050_STATE_WRITE 4 // Waiting for write#define MPU6050_STATE_RMW 5 // Waiting for read-modify-write//*****************************************************************************//// The factors used to convert the acceleration readings from the MPU6050 into// floating point values in meters per second squared.//// Values are obtained by taking the g conversion factors from the data sheet// and multiplying by 9.81 (1 g = 9.81 m/s^2).////*****************************************************************************static const float g_fMPU6050AccelFactors[] =[ 0.00059875, // Range = +/- 2 g (16384 l***/g) 0.00119751, // Range = +/- 4 g (8192 l***/g) 0.00239502, // Range = +/- 8 g (4096 l***/g) 0.00479004 // Range = +/- 16 g (2048 l***/g)];//*****************************************************************************//// The factors used to convert the acceleration readings from the MPU6050 into// floating point values in radians per second.//// Values are obtained by taking the degree per second conversion factors// from the data sheet and then converting to radians per sec (1 degree =// 0.0174532925 radians).////*****************************************************************************static const float g_fMPU6050GyroFactors[] =[ 1.3323124e-4f, // Range = +/- 250 dps (131.0 LSBs/DPS) 2.6646248e-4f, // Range = +/- 500 dps (65.5 LSBs/DPS) 5.3211258e-4f, // Range = +/- 1000 dps (32.8 LSBs/DPS) 0.0010642252f // Range = +/- 2000 dps (16.4 LSBs/DPS)];//*****************************************************************************//// The callback function that is called when I2C transations to/from the// MPU6050 have completed.////*****************************************************************************static voidMPU6050Callback(void *pvCallbackData, uint_fast8_t ui8Status)[ tMPU6050 *psInst; // // Convert the instance data into a pointer to a tMPU6050 structure. // psInst = pvCallbackData; // // If the I2C master driver encountered a failure, force the state machine // to the idle state (which will also result in a callback to propagate the // error). Except in the case that we are in the reset wait state and the // error is an address NACK. This error is handled by the reset wait // state. // if((ui8Status != I2CM_STATUS_SUCCESS) && !((ui8Status == I2CM_STATUS_ADDR_NACK) && (psInst->ui8State == MPU6050_STATE_INIT_WAIT))) [ psInst->ui8State = MPU6050_STATE_IDLE; ] // // Determine the current state of the MPU6050 state machine. // switch(psInst->ui8State) [ // // All states that trivially transition to IDLE, and all unknown // states. // case MPU6050_STATE_READ: default: [ // // The state machine is now idle. // psInst->ui8State = MPU6050_STATE_IDLE; // // Done. // break; ] // // MPU6050 Device reset was issued // case MPU6050_STATE_INIT_RES: [ // // Issue a read of the status register to confirm reset is done. // psInst->uCommand.pui8Buffer[0] = MPU6050_O_PWR_MGMT_1; I2CMRead(psInst->psI2CInst, psInst->ui8Addr, psInst->uCommand.pui8Buffer, 1, psInst->pui8Data, 1, MPU6050Callback, psInst); psInst->ui8State = MPU6050_STATE_INIT_WAIT; break; ] // // Status register was read, check if reset is done before proceeding. // case MPU6050_STATE_INIT_WAIT: [ // // Check the value read back from status to determine if device // is still in reset or if it is ready. Reset state for this // register is 0x40, which has sleep bit set. Device may also // respond with an address NACK during very early stages of the its // internal reset. Keep polling until we verify device is ready. // // if((psInst->pui8Data[0] != MPU6050_PWR_MGMT_1_SLEEP) || (ui8Status == I2CM_STATUS_ADDR_NACK)) [ // // Device still in reset so begin polling this register. // psInst->uCommand.pui8Buffer[0] = MPU6050_O_PWR_MGMT_1; I2CMRead(psInst->psI2CInst, psInst->ui8Addr, psInst->uCommand.pui8Buffer, 1, psInst->pui8Data, 1, MPU6050Callback, psInst); // // Intentionally stay in this state to create polling effect. // ] else [ // // Device is out of reset, move to the idle state. // psInst->ui8State = MPU6050_STATE_IDLE; ] break; ] // // A write just completed // case MPU6050_STATE_WRITE: [ // // Set the accelerometer and gyroscope ranges to the new values. // If the register was not modified, the values will be the same so // this has no effect. // psInst->ui8AccelAfsSel = psInst->ui8NewAccelAfsSel; psInst->ui8GyroFsSel = psInst->ui8NewGyroFsSel; // // The state machine is now idle. // psInst->ui8State = MPU6050_STATE_IDLE; // // Done. // break; ] // // A read-modify-write just completed // case MPU6050_STATE_RMW: [ // // See if the PWR_MGMT_1 register was just modified. // if(psInst->uCommand.sReadModifyWriteState.pui8Buffer[0] == MPU6050_O_PWR_MGMT_1) [ // // See if a soft reset has been issued. // if(psInst->uCommand.sReadModifyWriteState.pui8Buffer[1] & MPU6050_PWR_MGMT_1_DEVICE_RESET) [ // // Default range setting is +/- 2 g // psInst->ui8AccelAfsSel = 0; psInst->ui8NewAccelAfsSel = 0; // // Default range setting is +/- 250 degrees/s // psInst->ui8GyroFsSel = 0; psInst->ui8NewGyroFsSel = 0; ] ] // // See if the GYRO_CONFIG register was just modified. // if(psInst->uCommand.sReadModifyWriteState.pui8Buffer[0] == MPU6050_O_GYRO_CONFIG) [ // // Extract the FS_SEL from the GYRO_CONFIG register value. // psInst->ui8GyroFsSel = ((psInst->uCommand.sReadModifyWriteState.pui8Buffer[1] & MPU6050_GYRO_CONFIG_FS_SEL_M) >> MPU6050_GYRO_CONFIG_FS_SEL_S); ] // // See if the ACCEL_CONFIG register was just modified. // if(psInst->uCommand.sReadModifyWriteState.pui8Buffer[0] == MPU6050_O_ACCEL_CONFIG) [ // // Extract the FS_SEL from the ACCEL_CONFIG register value. // psInst->ui8AccelAfsSel = ((psInst->uCommand.sReadModifyWriteState.pui8Buffer[1] & MPU6050_ACCEL_CONFIG_AFS_SEL_M) >> MPU6050_ACCEL_CONFIG_AFS_SEL_S); ] // // The state machine is now idle. // psInst->ui8State = MPU6050_STATE_IDLE; // // Done. // break; ] ] // // See if the state machine is now idle and there is a callback function. // if((psInst->ui8State == MPU6050_STATE_IDLE) && psInst->pfnCallback) [ // // Call the application-supplied callback function. // psInst->pfnCallback(psInst->pvCallbackData, ui8Status); ]]//*****************************************************************************////! Initializes the MPU6050 driver.//!//! param psInst is a pointer to the MPU6050 instance data.//! param psI2CInst is a pointer to the I2C master driver instance data.//! param ui8I2CAddr is the I2C address of the MPU6050 device.//! param pfnCallback is the function to be called when the initialization has//! completed (can be b NULL if a callback is not required).//! param pvCallbackData is a pointer that is passed to the callback function.//!//! This function initializes the MPU6050 driver, preparing it for operation.//!//! return Returns 1 if the MPU6050 driver was successfully initialized and 0//! if it was not.////*****************************************************************************uint_fast8_tMPU6050Init(tMPU6050 *psInst, tI2CMInstance *psI2CInst, uint_fast8_t ui8I2CAddr, tSensorCallback *pfnCallback, void *pvCallbackData)[ // // Initialize the MPU6050 instance structure. // psInst->psI2CInst = psI2CInst; psInst->ui8Addr = ui8I2CAddr; // // Save the callback information. // psInst->pfnCallback = pfnCallback; psInst->pvCallbackData = pvCallbackData; // // Default range setting is +/- 2 g // psInst->ui8AccelAfsSel = (MPU6050_ACCEL_CONFIG_AFS_SEL_2G >> MPU6050_ACCEL_CONFIG_AFS_SEL_S); psInst->ui8NewAccelAfsSel = (MPU6050_ACCEL_CONFIG_AFS_SEL_2G >> MPU6050_ACCEL_CONFIG_AFS_SEL_S); // // Default range setting is +/- 250 degrees/s // psInst->ui8GyroFsSel = (MPU6050_GYRO_CONFIG_FS_SEL_250 >> MPU6050_GYRO_CONFIG_FS_SEL_S); psInst->ui8NewGyroFsSel = (MPU6050_GYRO_CONFIG_FS_SEL_250 >> MPU6050_GYRO_CONFIG_FS_SEL_S); // // Set the state to show we are initiating a reset. // psInst->ui8State = MPU6050_STATE_INIT_RES; // // Load the buffer with command to perform device reset // psInst->uCommand.pui8Buffer[0] = MPU6050_O_PWR_MGMT_1; psInst->uCommand.pui8Buffer[1] = MPU6050_PWR_MGMT_1_DEVICE_RESET; if(I2CMWrite(psInst->psI2CInst, psInst->ui8Addr, psInst->uCommand.pui8Buffer, 2, MPU6050Callback, psInst) == 0) [ psInst->ui8State = MPU6050_STATE_IDLE; return(0); ] // // Success // return(1);]//*****************************************************************************////! Reads data from MPU6050 registers.//!//! param psInst is a pointer to the MPU6050 instance data.//! param ui8Reg is the first register to read.//! param pui8Data is a pointer to the location to store the data that is//! read.//! param ui16Count is the number of data bytes to read.//! param pfnCallback is the function to be called when the data has been read//! (can be b NULL if a callback is not required).//! param pvCallbackData is a pointer that is passed to the callback function.//!//! This function reads a sequence of data values from consecutive registers in//! the MPU6050.//!//! return Returns 1 if the write was successfully started and 0 if it was//! not.////*****************************************************************************uint_fast8_tMPU6050Read(tMPU6050 *psInst, uint_fast8_t ui8Reg, uint8_t *pui8Data, uint_fast16_t ui16Count, tSensorCallback *pfnCallback, void *pvCallbackData)[ // // Return a failure if the MPU6050 driver is not idle (in other words, // there is already an outstanding request to the MPU6050). // if(psInst->ui8State != MPU6050_STATE_IDLE) [ return(0); ] // // Save the callback information. // psInst->pfnCallback = pfnCallback; psInst->pvCallbackData = pvCallbackData; // // Move the state machine to the wait for read state. // psInst->ui8State = MPU6050_STATE_READ; // // Read the requested registers from the MPU6050. // psInst->uCommand.pui8Buffer[0] = ui8Reg; if(I2CMRead(psInst->psI2CInst, psInst->ui8Addr, psInst->uCommand.pui8Buffer, 1, pui8Data, ui16Count, MPU6050Callback, psInst) == 0) [ // // The I2C write failed, so move to the idle state and return a // failure. // psInst->ui8State = MPU6050_STATE_IDLE; return(0); ] // // Success. // return(1);]//*****************************************************************************////! Writes data to MPU6050 registers.//!//! param psInst is a pointer to the MPU6050 instance data.//! param ui8Reg is the first register to write.//! param pui8Data is a pointer to the data to write.//! param ui16Count is the number of data bytes to write.//! param pfnCallback is the function to be called when the data has been//! written (can be b NULL if a callback is not required).//! param pvCallbackData is a pointer that is passed to the callback function.//!//! This function writes a sequence of data values to consecutive registers in//! the MPU6050. The first byte of the e pui8Data buffer contains the value//! to be written into the e ui8Reg register, the second value contains the//! data to be written into the next register, and so on.//!//! return Returns 1 if the write was successfully started and 0 if it was//! not.////*****************************************************************************uint_fast8_tMPU6050Write(tMPU6050 *psInst, uint_fast8_t ui8Reg, const uint8_t *pui8Data, uint_fast16_t ui16Count, tSensorCallback *pfnCallback, void *pvCallbackData)[ // // Return a failure if the MPU6050 driver is not idle (in other words, // there is already an outstanding request to the MPU6050). // if(psInst->ui8State != MPU6050_STATE_IDLE) [ return(0); ] // // Save the callback information. // psInst->pfnCallback = pfnCallback; psInst->pvCallbackData = pvCallbackData; // // See if the PWR_MGMT_1 register is being written. // if((ui8Reg <= MPU6050_O_PWR_MGMT_1) && ((ui8Reg + ui16Count) > MPU6050_O_PWR_MGMT_1)) [ // // See if a soft reset is being requested. // if(pui8Data[ui8Reg - MPU6050_O_PWR_MGMT_1] & MPU6050_PWR_MGMT_1_DEVICE_RESET) [ // // Default range setting is +/- 2 g. // psInst->ui8NewAccelAfsSel = 0; // // Default range setting is +/- 250 degrees/s. // psInst->ui8NewGyroFsSel = 0; ] ] // // See if the GYRO_CONFIG register is being written. // if((ui8Reg <= MPU6050_O_GYRO_CONFIG) && ((ui8Reg + ui16Count) > MPU6050_O_GYRO_CONFIG)) [ // // Extract the FS_SEL from the GYRO_CONFIG register value. // psInst->ui8NewGyroFsSel = ((pui8Data[ui8Reg - MPU6050_O_GYRO_CONFIG] & MPU6050_GYRO_CONFIG_FS_SEL_M) >> MPU6050_GYRO_CONFIG_FS_SEL_S); ] // // See if the ACCEL_CONFIG register is being written. // if((ui8Reg <= MPU6050_O_ACCEL_CONFIG) && ((ui8Reg + ui16Count) > MPU6050_O_ACCEL_CONFIG)) [ // // Extract the AFS_SEL from the ACCEL_CONFIG register value. // psInst->ui8NewAccelAfsSel = ((pui8Data[ui8Reg - MPU6050_O_ACCEL_CONFIG] & MPU6050_ACCEL_CONFIG_AFS_SEL_M) >> MPU6050_ACCEL_CONFIG_AFS_SEL_S); ] // // Move the state machine to the wait for write state. // psInst->ui8State = MPU6050_STATE_WRITE; // // Write the requested registers to the MPU6050. // if(I2CMWrite8(&(psInst->uCommand.sWriteState), psInst->psI2CInst, psInst->ui8Addr, ui8Reg, pui8Data, ui16Count, MPU6050Callback, psInst) == 0) [ // // The I2C write failed, so move to the idle state and return a // failure. // psInst->ui8State = MPU6050_STATE_IDLE; return(0); ] // // Success. // return(1);]//*****************************************************************************////! Performs a read-modify-write of a MPU6050 register.//!//! param psInst is a pointer to the MPU6050 instance data.//! param ui8Reg is the register to modify.//! param ui8Mask is the bit mask that is ANDed with the current register//! value.//! param ui8Value is the bit mask that is ORed with the result of the AND//! operation.//! param pfnCallback is the function to be called when the data has been//! changed (can be b NULL if a callback is not required).//! param pvCallbackData is a pointer that is passed to the callback function.//!//! This function changes the value of a register in the MPU6050 via a//! read-modify-write operation, allowing one of the fields to be changed//! without disturbing the other fields. The e ui8Reg register is read, ANDed//! with e ui8Mask, ORed with e ui8Value, and then written back to the//! MPU6050.//!//! return Returns 1 if the read-modify-write was successfully started and 0//! if it was not.////*****************************************************************************uint_fast8_tMPU6050ReadModifyWrite(tMPU6050 *psInst, uint_fast8_t ui8Reg, uint_fast8_t ui8Mask, uint_fast8_t ui8Value, tSensorCallback *pfnCallback, void *pvCallbackData)[ // // Return a failure if the MPU6050 driver is not idle (in other words, // there is already an outstanding request to the MPU6050). // if(psInst->ui8State != MPU6050_STATE_IDLE) [ return(0); ] // // Save the callback information. // psInst->pfnCallback = pfnCallback; psInst->pvCallbackData = pvCallbackData; // // Move the state machine to the wait for read-modify-write state. // psInst->ui8State = MPU6050_STATE_RMW; // // Submit the read-modify-write request to the MPU6050. // if(I2CMReadModifyWrite8(&(psInst->uCommand.sReadModifyWriteState), psInst->psI2CInst, psInst->ui8Addr, ui8Reg, ui8Mask, ui8Value, MPU6050Callback, psInst) == 0) [ // // The I2C read-modify-write failed, so move to the idle state and // return a failure. // psInst->ui8State = MPU6050_STATE_IDLE; return(0); ] // // Success. // return(1);]//*****************************************************************************////! Reads the accelerometer and gyroscope data from the MPU6050.//!//! param psInst is a pointer to the MPU6050 instance data.//! param pfnCallback is the function to be called when the data has been read//! (can be b NULL if a callback is not required).//! param pvCallbackData is a pointer that is passed to the callback function.//!//! This function initiates a read of the MPU6050 data registers. When the//! read has completed (as indicated by calling the callback function), the new//! readings can be obtained via://!//! - MPU6050DataAccelGetRaw()//! - MPU6050DataAccelGetFloat()//! - MPU6050DataGyroGetRaw()//! - MPU6050DataGyroGetFloat()//!//! return Returns 1 if the read was successfully started and 0 if it was not.////*****************************************************************************uint_fast8_tMPU6050DataRead(tMPU6050 *psInst, tSensorCallback *pfnCallback, void *pvCallbackData)[ // // Return a failure if the MPU6050 driver is not idle (in other words, // there is already an outstanding request to the MPU6050). // if(psInst->ui8State != MPU6050_STATE_IDLE) [ return(0); ] // // Save the callback information. // psInst->pfnCallback = pfnCallback; psInst->pvCallbackData = pvCallbackData; // // Move the state machine to the wait for data read state. // psInst->ui8State = MPU6050_STATE_READ; // // Read the data registers from the MPU6050. // psInst->pui8Data[0] = MPU6050_O_ACCEL_XOUT_H; if(I2CMRead(psInst->psI2CInst, psInst->ui8Addr, psInst->pui8Data, 1, psInst->pui8Data, 14, MPU6050Callback, psInst) == 0) [ // // The I2C read failed, so move to the idle state and return a failure. // psInst->ui8State = MPU6050_STATE_IDLE; return(0); ] // // Success. // return(1);]//*****************************************************************************////! Gets the raw accelerometer data from the most recent data read.//!//! param psInst is a pointer to the MPU6050 instance data.//! param pui16AccelX is a pointer to the value into which the raw X-axis//! accelerometer data is stored.//! param pui16AccelY is a pointer to the value into which the raw Y-axis//! accelerometer data is stored.//! param pui16AccelZ is a pointer to the value into which the raw Z-axis//! accelerometer data is stored.//!//! This function returns the raw accelerometer data from the most recent data//! read. The data is not manipulated in any way by the driver. If any of the//! output data pointers are b NULL, the corresponding data is not provided.//!//! return None.////*****************************************************************************voidMPU6050DataAccelGetRaw(tMPU6050 *psInst, uint_fast16_t *pui16AccelX, uint_fast16_t *pui16AccelY, uint_fast16_t *pui16AccelZ)[ // // Return the raw accelerometer values. // if(pui16AccelX) [ *pui16AccelX = (psInst->pui8Data[0] << 8) | psInst->pui8Data[1]; ] if(pui16AccelY) [ *pui16AccelY = (psInst->pui8Data[2] << 8) | psInst->pui8Data[3]; ] if(pui16AccelZ) [ *pui16AccelZ = (psInst->pui8Data[4] << 8) | psInst->pui8Data[5]; ]]//*****************************************************************************////! Gets the accelerometer data from the most recent data read.//!//! param psInst is a pointer to the MPU6050 instance data.//! param pfAccelX is a pointer to the value into which the X-axis//! accelerometer data is stored.//! param pfAccelY is a pointer to the value into which the Y-axis//! accelerometer data is stored.//! param pfAccelZ is a pointer to the value into which the Z-axis//! accelerometer data is stored.//!//! This function returns the accelerometer data from the most recent data//! read, converted into meters per second squared (m/s^2). If any of the//! output data pointers are b NULL, the corresponding data is not provided.//!//! return None.////*****************************************************************************voidMPU6050DataAccelGetFloat(tMPU6050 *psInst, float *pfAccelX, float *pfAccelY, float *pfAccelZ)[ float fFactor; // // Get the acceleration conversion factor for the current data format. // fFactor = g_fMPU6050AccelFactors[psInst->ui8AccelAfsSel]; // // Convert the Accelerometer values into floating-point gravity values. // if(pfAccelX) [ *pfAccelX = (float)((int16_t)((psInst->pui8Data[0] << 8) | psInst->pui8Data[1]) * fFactor); ] if(pfAccelY) [ *pfAccelY = (float)((int16_t)((psInst->pui8Data[2] << 8) | psInst->pui8Data[3]) * fFactor); ] if(pfAccelZ) [ *pfAccelZ = (float)((int16_t)((psInst->pui8Data[4] << 8) | psInst->pui8Data[5]) * fFactor); ]]//*****************************************************************************////! Gets the raw gyroscope data from the most recent data read.//!//! param psInst is a pointer to the MPU6050 instance data.//! param pui16GyroX is a pointer to the value into which the raw X-axis//! gyroscope data is stored.//! param pui16GyroY is a pointer to the value into which the raw Y-axis//! gyroscope data is stored.//! param pui16GyroZ is a pointer to the value into which the raw Z-axis//! gyroscope data is stored.//!//! This function returns the raw gyroscope data from the most recent data//! read. The data is not manipulated in any way by the driver. If any of the//! output data pointers are b NULL, the corresponding data is not provided.//!//! return None.////*****************************************************************************voidMPU6050DataGyroGetRaw(tMPU6050 *psInst, uint_fast16_t *pui16GyroX, uint_fast16_t *pui16GyroY, uint_fast16_t *pui16GyroZ)[ // // Return the raw gyroscope values. // if(pui16GyroX) [ *pui16GyroX = (psInst->pui8Data[8] << 8) | psInst->pui8Data[9]; ] if(pui16GyroY) [ *pui16GyroY = (psInst->pui8Data[10] << 8) | psInst->pui8Data[11]; ] if(pui16GyroZ) [ *pui16GyroZ = (psInst->pui8Data[12] << 8) | psInst->pui8Data[13]; ]]//*****************************************************************************////! Gets the gyroscope data from the most recent data read.//!//! param psInst is a pointer to the MPU6050 instance data.//! param pfGyroX is a pointer to the value into which the X-axis//! gyroscope data is stored.//! param pfGyroY is a pointer to the value into which the Y-axis//! gyroscope data is stored.//! param pfGyroZ is a pointer to the value into which the Z-axis//! gyroscope data is stored.//!//! This function returns the gyroscope data from the most recent data read,//! converted into radians per second. If any of the output data pointers are//! b NULL, the corresponding data is not provided.//!//! return None.////*****************************************************************************voidMPU6050DataGyroGetFloat(tMPU6050 *psInst, float *pfGyroX, float *pfGyroY, float *pfGyroZ)[ float fFactor; // // Get the conversion factor for the current data format. // fFactor = g_fMPU6050GyroFactors[psInst->ui8GyroFsSel]; // // Convert the gyroscope values into rad/sec // if(pfGyroX) [ *pfGyroX = ((float)(int16_t)((psInst->pui8Data[8] << 8) | psInst->pui8Data[9]) * fFactor); ] if(pfGyroY) [ *pfGyroY = ((float)(int16_t)((psInst->pui8Data[10] << 8) | psInst->pui8Data[11]) * fFactor); ] if(pfGyroZ) [ *pfGyroZ = ((float)(int16_t)((psInst->pui8Data[12] << 8) | psInst->pui8Data[13]) * fFactor); ]]//*****************************************************************************//// Close the Doxygen group.//! @]////*****************************************************************************//*****************************************************************************//// mpu6050.h - Prototypes for the MPU6050 accelerometer and gyroscope driver.//// Copyright (c) 2013-2017 Texas Instruments Incorporated. All rights reserved.// Software License Agreement// // Texas Instruments (TI) is supplying this software for use solely and// exclusively on TI's microcontroller products. The software is owned by// TI and/or its suppliers, and is protected under applicable copyright// laws. You may not combine this software with "viral" open-source// software in order to form a larger program.// // THIS SOFTWARE IS PROVIDED "AS IS" AND WITH ALL FAULTS.// NO WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT// NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR// A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. TI SHALL NOT, UNDER ANY// CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR CONSEQUENTIAL// DAMAGES, FOR ANY REASON WHATSOEVER.// // This is part of revision 2.1.4.178 of the Tiva Firmware Development Package.////*****************************************************************************#ifndef __SENSORLIB_MPU6050_H__#define __SENSORLIB_MPU6050_H__//*****************************************************************************//// If building with a C++ compiler, make all of the definitions in this header// have a C binding.////*****************************************************************************#ifdef __cplusplusextern "C"[#endif//*****************************************************************************//// The structure that defines the internal state of the MPU6050 driver.////*****************************************************************************typedef struct[ // // The pointer to the I2C master interface instance used to communicate // with the MPU6050. // tI2CMInstance *psI2CInst; // // The I2C address of the MPU6050. // uint8_t ui8Addr; // // The state of the state machine used while accessing the MPU6050. // uint8_t ui8State; // // The current accelerometer afs_sel setting. // uint8_t ui8AccelAfsSel; // // The new accelerometer afs_sel setting, which is used when a register // write succeeds. // uint8_t ui8NewAccelAfsSel; // // The current gyroscope fs_sel setting. // uint8_t ui8GyroFsSel; // // The new gyroscope fs_sel setting, which is used when a register write // succeeds. // uint8_t ui8NewGyroFsSel; // // The data buffer used for sending/receiving data to/from the MPU6050. // uint8_t pui8Data[16]; // // The function that is called when the current request has completed // processing. // tSensorCallback *pfnCallback; // // The callback data provided to the callback function. // void *pvCallbackData; // // A union of structures that are used for read, write and // read-modify-write operations. Since only one operation can be active at // a time, it is safe to re-use the memory in this manner. // union [ // // A buffer used to store the write portion of a register read. // uint8_t pui8Buffer[2]; // // The write state used to write register values. // tI2CMWrite8 sWriteState; // // The read-modify-write state used to modify register values. // tI2CMReadModifyWrite8 sReadModifyWriteState; ] uCommand;]tMPU6050;//*****************************************************************************//// Function prototypes.////*****************************************************************************extern uint_fast8_t MPU6050Init(tMPU6050 *psInst, tI2CMInstance *psI2CInst, uint_fast8_t ui8I2CAddr, tSensorCallback *pfnCallback, void *pvCallbackData);extern uint_fast8_t MPU6050Read(tMPU6050 *psInst, uint_fast8_t ui8Reg, uint8_t *pui8Data, uint_fast16_t ui16Count, tSensorCallback *pfnCallback, void *pvCallbackData);extern uint_fast8_t MPU6050Write(tMPU6050 *psInst, uint_fast8_t ui8Reg, const uint8_t *pui8Data, uint_fast16_t ui16Count, tSensorCallback *pfnCallback, void *pvCallbackData);extern uint_fast8_t MPU6050ReadModifyWrite(tMPU6050 *psInst, uint_fast8_t ui8Reg, uint_fast8_t ui8Mask, uint_fast8_t ui8Value, tSensorCallback *pfnCallback, void *pvCallbackData);extern uint_fast8_t MPU6050DataRead(tMPU6050 *psInst, tSensorCallback *pfnCallback, void *pvCallbackData);extern void MPU6050DataAccelGetRaw(tMPU6050 *psInst, uint_fast16_t *pui16AccelX, uint_fast16_t *pui16AccelY, uint_fast16_t *pui16AccelZ);extern void MPU6050DataAccelGetFloat(tMPU6050 *psInst, float *pfAccelX, float *pfAccelY, float *pfAccelZ);extern void MPU6050DataGyroGetRaw(tMPU6050 *psInst, uint_fast16_t *pui16GyroX, uint_fast16_t *pui16GyroY, uint_fast16_t *pui16GyroZ);extern void MPU6050DataGyroGetFloat(tMPU6050 *psInst, float *pfGyroX, float *pfGyroY, float *pfGyroZ);//*****************************************************************************//// Mark the end of the C bindings section for C++ compilers.////*****************************************************************************#ifdef __cplusplus]#endif#endif // __SENSORLIB_MPU6050_H__
举报
