ADI 技术
直播中
连涣艺
8年用户 183经验值
私信 关注
[问答]
hmc838 phase noise and loop filter BW
The loop filter's BW is so strange on my HMC838 board, The BW gets so large at lower frequency(1.62GHz) and get smaller at high frequency(1.67Ghz). and also the phase noise get worse at low frequency, and actually it is not good enough at high frequency. the settings of the design are: Fref:19.2MHz, PFD:19.2MHz, Fout:16.GHz~1.7GHz, BW:50KHz. there are two plots were attached. Any suggestions? Thanks!
回帖(2)
顾天天
2018-7-30 08:10:59
您好,请将您的问题直接发布在英文社区的RF专区吧,点击以下链接即可发布
https://ez.analog.com/community/rf
举报
h1654155275.5950
2018-7-30 08:22:11
I think you asked the same question in Chinese. The loop bandwidth will not vary a lot over different freq since the VCO inside the part is really narrow band. We suggest you double check your loop filter or use the loop in the datasheet with 50MHz Ref.
举报
更多回帖
