TI论坛
直播中
李雨充
7年用户 210经验值
私信 关注
[问答]
请教关于 IPNC-dm368 的 UBI 文件系统的制作与烧写
各位好:
        小弟在dm368上烧写UBI文件系统,发现启动不起来,制作方法和错误log请看附件,mtd-utils是SDK包(IPNC_RDK_DM36x_Version4.1.0)自带的,内核也已经配置好了UBI,我主要采用的是tftp烧写方式,ubiformat方式也用过,参数如下:ubiformat -q /dev/mtd3 -f ./target_nand.ubi  ;但是两种方式烧写完后重启都会发现:nand_bbt: ECC error while reading bad block table              UBI error: ubi_io_read: error -74 (ECC error) while reading。
       现在很纠结,不知道是哪一块的问题,工具我也file了一下,用的是32位机
       mkfs.ubifs: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.24, BuildID[sha1]=0x7cc3853d2d12e9ec019b7104e46ae13209254a32, not stripped
        ubinize: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.24, BuildID[sha1]=0x1723f88333980cb6798886a4f4a72e9efd294768, not stripped
回帖(5)
李雨充
2018-7-27 09:16:39
附件内容如下:
####UBIFS制作####
mkfs.ubifs -r filesys -m 2048 -F -e 126976 -c 1000 -o ubifs.img
ubinize -o ipnc_dm368_ubifs -m 2048 -p 131072  dm368_ubinize.cfg
cat dm368_ubinize.cfg
[ubifs]
mode=ubi
image=ubifs.img
vol_id=0
vol_size=40MiB
vol_type=dynamic
vol_name=rootfs
vol_flags=autoresize
resetting ...
DM365_432 DDR 340 initialization passed!
Booting TI User Boot Loader
    UBL Version: 1.65
    UBL Flashtype: NAND
Starting NAND Copy...
Valid magicnum, 0xA1ACED66, found in block 0x00000019.
   DONE
Jumping to entry point at 0x81080000.
U-Boot 2010.12-rc2 (Nov 28 2013 - 21:19:40)
Cores: ARM 432 MHz
DDR:   340 MHz
I2C:   ready
DRAM:  128 MiB
NAND:  In nand_get_flash_type,*maf_id is 0xec,dev_idis 0xf1.
128 MiB
MMC:   davinci: 0, davinci: 1
Bad block table found at page 65472, version 0x01
Bad block table found at page 65408, version 0x01
Net:   Ethernet PHY: GENERIC @ 0x01
DaVinci-EMAC
Hit any key to stop autoboot:  0
Loading from nand0, offset 0x500000
   Image Name:   Linux-2.6.37_IPNC_DM365_4.1.0
   Created:      2014-02-09   8:43:38 UTC
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    3842496 Bytes = 3.7 MiB
   Load Address: 80008000
   Entry Point:  80008000
## Booting kernel from Legacy Image at 80700000 ...
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
[    0.000000] Linux version 2.6.37_IPNC_DM365_4.1.0 (ipnc@zziron) (gcc version 4.3.3 (GCC) ) #2 PREEMPT Thu Jan 9 11:10:29 CST 2014
[    0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
[    0.000000] CPU: VIVT data cache, VIVT instruction cache
[    0.000000] Machine: DaVinci DM36x IPNC
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] DaVinci dm36x_rev1.2 variant 0x8
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 12192
[    0.000000] Kernel command line: mem=48M console=ttyS0,115200n8 noinitrd ip=dhcp rw ubi.mtd=3,2048 rootfstype=ubifs root=ubi0:rootfs cmemk.phys_start=0x83000000 cmemk.phys_end=0x88000000 cmemk.phys_start_1=0x00001000 cmemk.phys_end_1=0x00008000 cmemk.pools_1=1x28672 cmemk.allowOverlap=1 cmemk.useHeapIfPoolUnavailable=1 nohz=off highres=off clocksource=acpi_pm lpj=1077248 eth=00:0c:0c:a0:09:EC
[    0.000000] TI DaVinci EMAC: kernel boot params Ethernet address: 00:0c:0c:a0:09:EC
[    0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[    0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Memory: 48MB = 48MB total
[    0.000000] Memory: 44772k/44772k available, 4380k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     DMA     : 0xff000000 - 0xffe00000   (  14 MB)
[    0.000000]     vmalloc : 0xc3800000 - 0xfea00000   ( 946 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xc3000000   (  48 MB)
[    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[    0.000000]       .init : 0xc0008000 - 0xc002a000   ( 136 kB)
[    0.000000]       .text : 0xc002a000 - 0xc038b000   (3460 kB)
[    0.000000]       .data : 0xc038c000 - 0xc03b21c0   ( 153 kB)
[    0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] Preemptable hierarchical RCU implementation.
[    0.000000]     RCU-based detection of stalled CPUs is disabled.
[    0.000000]     Verbose stalled-CPUs detection is disabled.
[    0.000000] NR_IRQS:245
[    0.000000] Console: colour dummy device 80x30
[    0.000295] Calibrating delay loop (skipped) preset value.. 215.44 BogoMIPS (lpj=1077248)
[    0.000354] pid_max: default: 32768 minimum: 301
[    0.000633] Mount-cache hash table entries: 512
[    0.001423] CPU: Testing write buffer coherency: ok
[    0.005902] DaVinci: 8 gpio irqs
[    0.006515] NET: Registered protocol family 16
[    0.099478] bio: create slab at 0
[    0.104427] SCSI subsystem initialized
[    0.108182] u***core: registered new interface driver u***fs
[    0.109509] u***core: registered new interface driver hub
[    0.110752] u***core: registered new device driver u***
[    0.113939] vpss vpss: dm365_vpss vpss probed
[    0.113999] vpss vpss: dm365_vpss vpss probe success
[    0.115851] Advanced Linux Sound Architecture Driver Version 1.0.23.
[    0.117758] Switching to clocksource timer0_1
[    0.179691] NET: Registered protocol family 2
[    0.180001] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.181103] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[    0.181245] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[    0.181334] TCP: Hash tables configured (established 2048 bind 2048)
[    0.181365] TCP reno registered
[    0.181404] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.181469] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.181965] NET: Registered protocol family 1
[    0.182982] RPC: Registered udp transport module.
[    0.183025] RPC: Registered tcp transport module.
[    0.183052] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.255829] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    0.256566] JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    0.260503] msgmni has been set to 87
[    0.264356] io scheduler noop registered (default)
[    0.265892] CSL: Module install successful, device major num = 254
[    0.265937] CSL: Module version 0.10.00, built on Jan  9 2014 00:23:29
[    0.265991] I2C: Module install successful, device major num = 253
[    0.266033] DMA: Module install successful, device major num = 252
[    0.266060] DRV: Module install successful
[    0.266084] DRV: Module built on Jan  9 2014 00:23:30
[    0.266110] DRV: EDMACC.QUEPRI  = 00002777
[    0.266133] DRV: SYSTEM.MSTPRI0 = 00440011
[    0.266155] DRV: SYSTEM.MSTPRI1 = 00000444
[    0.266176] DRV: ISP.BCR        = 00000002
[    0.266198] DRV: SYSTEM.MISC    = 00000399
[    0.266221] EDMAK module: built on Jan  9 2014 at 00:23:18
[    0.266250]   Reference Linux version 2.6.37
[    0.266275]   File /home/ipnc/yourapp/Source/dvsdk_ipnctools/linuxutils_2_26_02_05/packages/ti/sdo/linuxutils/edma/src/module/edmak.c
[    0.267689] IRQK module: built on Jan  9 2014 at 00:23:18
[    0.267737]   Reference Linux version 2.6.37
[    0.267764]   File /home/ipnc/yourapp/Source/dvsdk_ipnctools/linuxutils_2_26_02_05/packages/ti/sdo/linuxutils/irq/src/module/irqk.c
[    0.269192] irqk initialized
[    0.269263] CMEMK module: built on Jan  9 2014 at 00:23:16
[    0.269301]   Reference Linux version 2.6.37
[    0.269326]   File /home/ipnc/yourapp/Source/dvsdk_ipnctools/linuxutils_2_26_02_05/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
[    0.274351] allocated heap buffer 0xc4000000 of size 0x5000000
[    0.274395] heap fallback enabled - will try heap if pool buffer is not available
[    0.274435] CMEM Range Overlaps Kernel Physical - allowing overlap
[    0.274470] CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x83000000)
[    0.274613] cmemk initialized
[    0.274670] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
[    0.298568] serial8250.0: ttyS0 at MMIO 0x1c20000 (irq = 40) is a 16550A
[    0.827941] console [ttyS0] enabled
[    0.853410] serial8250.0: ttyS1 at MMIO 0x1d06000 (irq = 41) is a 16550A
[    0.863557] brd: module loaded
[    0.875299] NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung )
[    0.891933] nand_bbt: ECC error while reading bad block table
[    0.897895] Creating 7 MTD partitions on "davinci_nand.0":
[    0.903568] 0x000000000000-0x000000300000 : "bootloader"
[    0.912879] 0x000000300000-0x000000500000 : "params"
[    0.921894] 0x000000500000-0x000000900000 : "kernel"
[    0.931061] 0x000000900000-0x000003100000 : "filesystem1"
[    0.940846] 0x000003100000-0x000003300000 : "data1"
[    0.949845] 0x000003300000-0x000005b00000 : "filesystem2"
[    0.959735] 0x000005b00000-0x000008000000 : "data2"
[    0.969066] davinci_nand davinci_nand.0: controller rev. 2.3
[    0.977875] UBI: attaching mtd3 to ubi0
[    0.982049] UBI: physical eraseblock size:   131072 bytes (128 KiB)
[    0.988340] UBI: logical eraseblock size:    126976 bytes
[    0.993912] UBI: smallest flash I/O unit:    2048
[    0.998632] UBI: sub-page size:              512
[    1.003354] UBI: VID header offset:          2048 (aligned 2048)
[    1.009378] UBI: data offset:                4096
[    1.030798] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 3:0, read 64 bytes
[    1.043057] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 3:2048, read 512 bytes
[    1.055761] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 4:0, read 64 bytes
[    1.068033] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 4:2048, read 512 bytes
[    1.080807] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 5:0, read 64 bytes
[    1.093070] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 5:2048, read 512 bytes
[    1.124381] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 10:0, read 64 bytes
[    1.136742] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 10:2048, read 512 bytes
[    1.158858] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 13:0, read 64 bytes
[    1.171273] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 13:2048, read 512 bytes
[    1.184073] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 14:0, read 64 bytes
[    1.196435] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 14:2048, read 512 bytes
[    1.209234] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 15:0, read 64 bytes
[    1.221647] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 15:2048, read 512 bytes
[    1.234449] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 16:0, read 64 bytes
[    1.246806] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 16:2048, read 512 bytes
[    1.259609] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 17:0, read 64 bytes
[    1.272021] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 17:2048, read 512 bytes
[    1.284825] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 18:0, read 64 bytes
[    1.297186] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 18:2048, read 512 bytes
[    1.309990] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 19:0, read 64 bytes
[    1.322401] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 19:2048, read 512 bytes
[    1.335202] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 20:0, read 64 bytes
[    1.347562] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 20:2048, read 512 bytes
[    1.360427] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 21:0, read 64 bytes
[    1.375113] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 22:0, read 64 bytes
[    1.387474] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 22:2048, read 512 bytes
[    1.400338] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 23:0, read 64 bytes
[    1.412688] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 23:2048, read 512 bytes
[    1.425491] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 24:0, read 64 bytes
[    1.437851] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 24:2048, read 512 bytes
[    1.450709] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 25:0, read 64 bytes
[    1.463058] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 25:2048, read 512 bytes
[    1.475862] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 26:0, read 64 bytes
[    1.488220] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 26:2048, read 512 bytes
[    1.501082] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 27:0, read 64 bytes
[    1.513436] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 27:2048, read 512 bytes
[    1.526239] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 28:0, read 64 bytes
[    1.538597] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 28:2048, read 512 bytes
[    1.551459] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 29:0, read 64 bytes
[    1.563805] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 29:2048, read 512 bytes
[    1.576613] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 30:0, read 64 bytes
[    1.588970] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 30:2048, read 512 bytes
[    1.601835] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 31:0, read 64 bytes
[    1.614185] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 31:2048, read 512 bytes
[    1.626989] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 32:0, read 64 bytes
[    1.639347] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 32:2048, read 512 bytes
[    1.652211] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 33:0, read 64 bytes
[    1.664569] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 33:2048, read 512 bytes
[    1.677375] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 34:0, read 64 bytes
[    1.689736] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 34:2048, read 512 bytes
[    1.702538] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 35:0, read 64 bytes
[    1.714896] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 35:2048, read 512 bytes
[    1.727703] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 36:0, read 64 bytes
[    1.740118] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 36:2048, read 512 bytes
[    1.752915] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 37:0, read 64 bytes
[    1.765269] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 37:2048, read 512 bytes
[    1.778075] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 38:0, read 64 bytes
[    1.790492] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 38:2048, read 512 bytes
[    1.803294] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 39:0, read 64 bytes
[    1.815651] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 39:2048, read 512 bytes
[    1.828455] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 40:0, read 64 bytes
[    1.840869] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 40:2048, read 512 bytes
[    1.853672] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 41:0, read 64 bytes
[    1.866029] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 41:2048, read 512 bytes
[    1.878835] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 42:0, read 64 bytes
[    1.891256] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 42:2048, read 512 bytes
[    1.904056] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 43:0, read 64 bytes
[    1.916417] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 43:2048, read 512 bytes
[    1.929225] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 44:0, read 64 bytes
[    1.941633] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 44:2048, read 512 bytes
[    1.954439] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 45:0, read 64 bytes
[    1.966793] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 45:2048, read 512 bytes
[    1.979596] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 46:0, read 64 bytes
[    1.992008] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 46:2048, read 512 bytes
[    2.004809] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 47:0, read 64 bytes
[    2.017168] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 47:2048, read 512 bytes
[    2.029971] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 48:0, read 64 bytes
[    2.042377] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 48:2048, read 512 bytes
[    2.055179] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 49:0, read 64 bytes
[    2.067536] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 49:2048, read 512 bytes
[    2.080396] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 50:0, read 64 bytes
[    2.092741] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 50:2048, read 512 bytes
[    2.105549] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 51:0, read 64 bytes
[    2.117911] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 51:2048, read 512 bytes
[    2.130773] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 52:0, read 64 bytes
[    2.143122] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 52:2048, read 512 bytes
[    2.155926] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 53:0, read 64 bytes
[    2.168284] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 53:2048, read 512 bytes
[    2.181147] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 54:0, read 64 bytes
[    2.193497] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 54:2048, read 512 bytes
[    2.206307] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 55:0, read 64 bytes
[    2.218667] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 55:2048, read 512 bytes
[    2.231533] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 56:0, read 64 bytes
[    2.243884] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 56:2048, read 512 bytes
[    2.256692] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 57:0, read 64 bytes
[    2.269050] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 57:2048, read 512 bytes
[    2.281908] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 58:0, read 64 bytes
[    2.294260] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 58:2048, read 512 bytes
[    2.307067] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 59:0, read 64 bytes
[    2.319420] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 59:2048, read 512 bytes
[    2.332266] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 60:0, read 64 bytes
[    2.344618] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 60:2048, read 512 bytes
[    2.357424] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 61:0, read 64 bytes
[    2.369779] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 61:2048, read 512 bytes
[    2.382615] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 62:0, read 64 bytes
[    2.394979] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 62:2048, read 512 bytes
[    2.407787] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 63:0, read 64 bytes
[    2.420212] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 63:2048, read 512 bytes
[    2.433014] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 64:0, read 64 bytes
[    2.445372] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 64:2048, read 512 bytes
[    2.458174] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 65:0, read 64 bytes
[    2.470588] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 65:2048, read 512 bytes
[    2.483391] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 66:0, read 64 bytes
[    2.495751] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 66:2048, read 512 bytes
[    2.508554] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 67:0, read 64 bytes
[    2.520967] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 67:2048, read 512 bytes
[    2.533766] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 68:0, read 64 bytes
[    2.546126] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 68:2048, read 512 bytes
[    2.558934] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 69:0, read 64 bytes
[    2.571349] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 69:2048, read 512 bytes
[    2.584148] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 70:0, read 64 bytes
[    2.596506] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 70:2048, read 512 bytes
[    2.609312] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 71:0, read 64 bytes
[    2.621725] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 71:2048, read 512 bytes
[    2.634522] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 72:0, read 64 bytes
[    2.646880] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 72:2048, read 512 bytes
[    2.659688] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 73:0, read 64 bytes
[    2.672102] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 73:2048, read 512 bytes
[    2.684903] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 74:0, read 64 bytes
[    2.697262] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 74:2048, read 512 bytes
[    2.710131] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 75:0, read 64 bytes
[    2.722480] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 75:2048, read 512 bytes
[    2.735282] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 76:0, read 64 bytes
[    2.747644] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 76:2048, read 512 bytes
[    2.760511] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 77:0, read 64 bytes
[    2.772863] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 77:2048, read 512 bytes
[    2.785669] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 78:0, read 64 bytes
[    2.798027] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 78:2048, read 512 bytes
[    2.810893] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 79:0, read 64 bytes
[    2.823246] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 79:2048, read 512 bytes
[    2.836051] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 80:0, read 64 bytes
[    2.848411] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 80:2048, read 512 bytes
[    2.861276] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 81:0, read 64 bytes
[    2.873628] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 81:2048, read 512 bytes
[    2.886432] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 82:0, read 64 bytes
[    2.898792] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 82:2048, read 512 bytes
[    2.911659] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 83:0, read 64 bytes
[    2.924013] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 83:2048, read 512 bytes
[    2.936816] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 84:0, read 64 bytes
[    2.949174] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 84:2048, read 512 bytes
[    2.962037] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 85:0, read 64 bytes
[    2.974390] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 85:2048, read 512 bytes
[    2.987193] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 86:0, read 64 bytes
[    2.999550] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 86:2048, read 512 bytes
[    3.012412] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 87:0, read 64 bytes
[    3.024768] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 87:2048, read 512 bytes
[    3.037570] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 88:0, read 64 bytes
[    3.049928] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 88:2048, read 512 bytes
[    3.062728] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 89:0, read 64 bytes
[    3.075087] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 89:2048, read 512 bytes
[    3.087894] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 90:0, read 64 bytes
[    3.100306] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 90:2048, read 512 bytes
[    3.113105] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 91:0, read 64 bytes
[    3.125462] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 91:2048, read 512 bytes
[    3.138266] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 92:0, read 64 bytes
[    3.150678] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 92:2048, read 512 bytes
[    3.163481] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 93:0, read 64 bytes
[    3.175844] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 93:2048, read 512 bytes
[    3.188645] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 94:0, read 64 bytes
[    3.201057] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 94:2048, read 512 bytes
[    3.213865] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 95:0, read 64 bytes
[    3.226228] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 95:2048, read 512 bytes
[    3.239034] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 96:0, read 64 bytes
[    3.251455] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 96:2048, read 512 bytes
[    3.264255] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 97:0, read 64 bytes
[    3.276615] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 97:2048, read 512 bytes
[    3.289417] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 98:0, read 64 bytes
[    3.301830] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 98:2048, read 512 bytes
[    3.314628] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 99:0, read 64 bytes
[    3.326989] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 99:2048, read 512 bytes
[    3.339793] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 100:0, read 64 bytes
[    3.352298] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 100:2048, read 512 bytes
[    3.365187] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 101:0, read 64 bytes
[    3.377635] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 101:2048, read 512 bytes
[    3.390591] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 102:0, read 64 bytes
[    3.403028] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 102:2048, read 512 bytes
[    3.415917] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 103:0, read 64 bytes
[    3.428364] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 103:2048, read 512 bytes
[    3.441313] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 104:0, read 64 bytes
[    3.453747] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 104:2048, read 512 bytes
[    3.466638] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 105:0, read 64 bytes
[    3.479087] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 105:2048, read 512 bytes
[    3.492036] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 106:0, read 64 bytes
[    3.504478] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 106:2048, read 512 bytes
[    3.517373] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 107:0, read 64 bytes
[    3.529821] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 107:2048, read 512 bytes
[    3.542711] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 108:0, read 64 bytes
[    3.555158] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 108:2048, read 512 bytes
[    3.568043] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 109:0, read 64 bytes
[    3.582885] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 110:0, read 64 bytes
[    3.595333] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 110:2048, read 512 bytes
[    3.608226] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 111:0, read 64 bytes
[    3.620726] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 111:2048, read 512 bytes
[    3.633616] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 112:0, read 64 bytes
[    3.646065] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 112:2048, read 512 bytes
[    3.658956] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 113:0, read 64 bytes
[    3.671453] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 113:2048, read 512 bytes
[    3.684345] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 114:0, read 64 bytes
[    3.696795] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 114:2048, read 512 bytes
[    3.709688] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 115:0, read 64 bytes
[    3.722185] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 115:2048, read 512 bytes
[    3.735073] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 116:0, read 64 bytes
[    3.747521] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 116:2048, read 512 bytes
[    3.760478] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 117:0, read 64 bytes
[    3.772914] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 117:2048, read 512 bytes
[    3.785804] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 118:0, read 64 bytes
[    3.798249] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 118:2048, read 512 bytes
[    3.811208] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 119:0, read 64 bytes
[    3.823645] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 119:2048, read 512 bytes
[    3.836542] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 120:0, read 64 bytes
[    3.848988] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 120:2048, read 512 bytes
[    3.861942] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 121:0, read 64 bytes
[    3.874378] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 121:2048, read 512 bytes
[    3.887270] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 122:0, read 64 bytes
[    3.899718] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 122:2048, read 512 bytes
[    3.912612] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 123:0, read 64 bytes
[    3.925059] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 123:2048, read 512 bytes
[    3.937948] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 124:0, read 64 bytes
[    3.950448] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 124:2048, read 512 bytes
[    3.963340] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 125:0, read 64 bytes
[    3.975788] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 125:2048, read 512 bytes
[    3.988707] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 126:0, read 64 bytes
[    4.001216] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 126:2048, read 512 bytes
[    4.014112] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 127:0, read 64 bytes
[    4.026559] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 127:2048, read 512 bytes
[    4.039451] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 128:0, read 64 bytes
[    4.051952] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 128:2048, read 512 bytes
[    4.064843] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 129:0, read 64 bytes
[    4.077285] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 129:2048, read 512 bytes
[    4.090237] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 130:0, read 64 bytes
[    4.102670] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 130:2048, read 512 bytes
[    4.115561] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 131:0, read 64 bytes
[    4.128011] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 131:2048, read 512 bytes
[    4.140956] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 132:0, read 64 bytes
[    4.153393] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 132:2048, read 512 bytes
[    4.166283] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 133:0, read 64 bytes
[    4.178730] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 133:2048, read 512 bytes
[    4.191678] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 134:0, read 64 bytes
[    4.204111] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 134:2048, read 512 bytes
[    4.216999] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 135:0, read 64 bytes
[    4.229444] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 135:2048, read 512 bytes
[    4.242392] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 136:0, read 64 bytes
[    4.254832] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 136:2048, read 512 bytes
[    4.267730] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 137:0, read 64 bytes
[    4.280239] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 137:2048, read 512 bytes
[    4.293126] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 138:0, read 64 bytes
[    4.305572] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 138:2048, read 512 bytes
[    4.318465] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 139:0, read 64 bytes
[    4.330967] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 139:2048, read 512 bytes
[    4.343856] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 140:0, read 64 bytes
[    4.356301] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 140:2048, read 512 bytes
[    4.369193] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 141:0, read 64 bytes
[    4.381695] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 141:2048, read 512 bytes
[    4.394584] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 142:0, read 64 bytes
[    4.407028] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 142:2048, read 512 bytes
[    4.419922] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 143:0, read 64 bytes
[    4.432414] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 143:2048, read 512 bytes
[    4.445305] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 144:0, read 64 bytes
[    4.457753] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 144:2048, read 512 bytes
[    4.470711] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 145:0, read 64 bytes
[    4.483146] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 145:2048, read 512 bytes
[    4.496041] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 146:0, read 64 bytes
[    4.508488] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 146:2048, read 512 bytes
[    4.521445] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 147:0, read 64 bytes
[    4.533885] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 147:2048, read 512 bytes
[    4.546775] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 148:0, read 64 bytes
[    4.559223] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 148:2048, read 512 bytes
[    4.572170] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 149:0, read 64 bytes
[    4.584608] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 149:2048, read 512 bytes
[    4.597503] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 150:0, read 64 bytes
[    4.609946] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 150:2048, read 512 bytes
[    4.622838] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 151:0, read 64 bytes
[    4.635281] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 151:2048, read 512 bytes
[    4.648178] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 152:0, read 64 bytes
[    4.660677] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 152:2048, read 512 bytes
[    4.673564] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 153:0, read 64 bytes
[    4.686009] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 153:2048, read 512 bytes
[    4.698905] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 154:0, read 64 bytes
[    4.711408] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 154:2048, read 512 bytes
[    4.724299] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 155:0, read 64 bytes
[    4.736742] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 155:2048, read 512 bytes
[    4.749635] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 156:0, read 64 bytes
[    4.762134] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 156:2048, read 512 bytes
[    4.775020] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 157:0, read 64 bytes
[    4.787466] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 157:2048, read 512 bytes
[    4.800420] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 158:0, read 64 bytes
[    4.812862] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 158:2048, read 512 bytes
[    4.825755] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 159:0, read 64 bytes
[    4.838201] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 159:2048, read 512 bytes
[    4.851157] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 160:0, read 64 bytes
[    4.863595] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 160:2048, read 512 bytes
[    4.876486] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 161:0, read 64 bytes
[    4.888930] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 161:2048, read 512 bytes
[    4.901884] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 162:0, read 64 bytes
[    4.914322] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 162:2048, read 512 bytes
[    4.927216] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 163:0, read 64 bytes
[    4.939664] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 163:2048, read 512 bytes
[    4.952555] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 164:0, read 64 bytes
[    4.964998] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 164:2048, read 512 bytes
[    4.977893] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 165:0, read 64 bytes
[    4.990392] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 165:2048, read 512 bytes
[    5.003284] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 166:0, read 64 bytes
[    5.015730] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 166:2048, read 512 bytes
[    5.028625] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 167:0, read 64 bytes
[    5.041124] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 167:2048, read 512 bytes
[    5.054012] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 168:0, read 64 bytes
[    5.066456] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 168:2048, read 512 bytes
[    5.079347] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 169:0, read 64 bytes
[    5.091843] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 169:2048, read 512 bytes
[    5.104728] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 170:0, read 64 bytes
[    5.117173] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 170:2048, read 512 bytes
[    5.130131] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 171:0, read 64 bytes
[    5.142567] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 171:2048, read 512 bytes
[    5.155463] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 172:0, read 64 bytes
[    5.167907] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 172:2048, read 512 bytes
[    5.180861] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 173:0, read 64 bytes
[    5.193300] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 173:2048, read 512 bytes
[    5.206185] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 174:0, read 64 bytes
[    5.218632] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 174:2048, read 512 bytes
[    5.902054] UBI: max. sequence number:       9
[    5.961081] UBI warning: print_rsvd_warning: cannot reserve enough PEBs for bad PEB handling, reserved 2, need 3
[    5.973617] UBI: attached mtd3 to ubi0
[    5.977394] UBI: MTD device name:            "filesystem1"
[    5.983019] UBI: MTD device size:            40 MiB
[    5.987915] UBI: number of good PEBs:        320
[    5.992650] UBI: number of bad PEBs:         0
[    5.997110] UBI: number of corrupted PEBs:   0
[    6.001621] UBI: max. allowed volumes:       128
[    6.006251] UBI: wear-leveling threshold:    4096
[    6.011019] UBI: number of internal volumes: 1
[    6.015475] UBI: number of user volumes:     1
[    6.019922] UBI: available PEBs:             0
[    6.024414] UBI: total number of reserved PEBs: 320
[    6.029305] UBI: number of PEBs reserved for bad PEB handling: 2
[    6.035359] UBI: max/mean erase counter: 20/0
[    6.039727] UBI: image sequence number:  1352308876
[    6.044691] UBI: background thread "ubi_bgt0d" started, PID 426
[    6.054083] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 3:2048, read 512 bytes
[    6.110136] davinci_mdio davinci_mdio.0: davinci mdio revision 1.4
[    6.116353] davinci_mdio davinci_mdio.0: detected phy mask fffffffd
[    6.141516] davinci_mdio.0: probed
[    6.144966] davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver unknown
[    6.160776] i2c /dev entries driver
[    6.171814] Linux media interface: v0.10
[    6.180518] Linux video capture interface: v2.00
[    6.191926] vpbe-osd vpbe-osd: OSD sub device probe success
[    6.210403] vpbe-venc vpbe-venc: VENC sub device probe success
[    6.217075] vpbe-v4l2 vpbe-v4l2: vpbe v4l2 device registered
[    6.230355] Setting default output to Composite
[    6.234914] Setting default mode to ntsc
[    6.238933] vpbe-v4l2 vpbe-v4l2: Trying to register VPBE display device.
[    6.260117] vpbe-v4l2 vpbe-v4l2: layer=c299e800,layer->video_dev=c299e8e8
[    6.280192] vpbe-v4l2 vpbe-v4l2: Trying to register VPBE display device.
[    6.286927] vpbe-v4l2 vpbe-v4l2: layer=c299e200,layer->video_dev=c299e2e8
[    6.311830] watchdog watchdog: heartbeat 60 sec
[    6.320174] UBI error: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 3:4096, read 126976 bytes
[    6.333474] Error: Driver 'davinci-mcbsp' is already registered, aborting...
[    6.341979] UBI warning: ubi_eba_copy_leb: error -74 while reading data from PEB 3
[    6.351620] asoc: cq93vc-hifi <-> davinci-vcif mapping ok
[    6.364263] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 4:2048, read 512 bytes
[    6.375883] ALSA device list:
[    6.378884]   #0: DaVinci DM365 EVM
[    6.383894] TCP cubic registered
[    6.387159] NET: Registered protocol family 17
[    6.412122] net eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:01, id=181b8b0)
[    6.450150] Sending DHCP requests .
[    6.557119] UBI error: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 4:4096, read 126976 bytes
[    6.568207] UBI warning: ubi_eba_copy_leb: error -74 while reading data from PEB 4
[    6.581971] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 5:2048, read 512 bytes
[    6.735575] UBI error: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 5:4096, read 126976 bytes
[    6.746486] UBI warning: ubi_eba_copy_leb: error -74 while reading data from PEB 5
[    6.760252] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 10:2048, read 512 bytes
[    6.913857] UBI error: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 10:4096, read 126976 bytes
[    6.924858] UBI warning: ubi_eba_copy_leb: error -74 while reading data from PEB 10
[    6.938587] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 13:2048, read 512 bytes
[    7.093051] UBI error: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 13:4096, read 126976 bytes
[    7.104049] UBI warning: ubi_eba_copy_leb: error -74 while reading data from PEB 13
[    7.117779] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 14:2048, read 512 bytes
[    7.272235] UBI error: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 14:4096, read 126976 bytes
[    7.283236] UBI warning: ubi_eba_copy_leb: error -74 while reading data from PEB 14
[    7.296971] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 15:2048, read 512 bytes
[    7.451571] UBI error: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 15:4096, read 126976 bytes
[    7.462575] UBI warning: ubi_eba_copy_leb: error -74 while reading data from PEB 15
[    7.476303] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 16:2048, read 512 bytes
[    7.630704] UBI error: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 16:4096, read 126976 bytes
[    7.641704] UBI warning: ubi_eba_copy_leb: error -74 while reading data from PEB 16
[    7.655369] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 17:2048, read 512 bytes
[    7.809702] UBI error: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 17:4096, read 126976 bytes
[    7.820701] UBI warning: ubi_eba_copy_leb: error -74 while reading data from PEB 17
[    7.834462] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 18:2048, read 512 bytes
[    7.988778] UBI error: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 18:4096, read 126976 bytes
[    7.999773] UBI warning: ubi_eba_copy_leb: error -74 while reading data from PEB 18
[    8.013611] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 19:2048, read 512 bytes
[    8.167992] UBI error: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 19:4096, read 126976 bytes
[    8.178993] UBI warning: ubi_eba_copy_leb: error -74 while reading data from PEB 19
[    8.192831] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 20:2048, read 512 bytes
[    8.347227] UBI error: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 20:4096, read 126976 bytes
[    8.358223] UBI warning: ubi_eba_copy_leb: error -74 while reading data from PEB 20
[    8.420449] PHY: 0:01 - Link is Up - 100/Full
[    8.521040] UBI error: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 21:4096, read 126976 bytes
[    8.532041] UBI warning: ubi_eba_copy_leb: error -74 while reading data from PEB 21
[    8.545698] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 22:2048, read 512 bytes
[    8.640103] ., OK
[    8.690153] IP-Config: Got DHCP answer from 0.0.0.0, my address is 192.168.1.119
[    8.698281] IP-Config: Complete:
[    8.710127]      device=eth0, addr=192.168.1.119, mask=255.255.255.0, gw=192.168.1.254,
[    8.718117]      host=192.168.1.119, domain=, nis-domain=(none)
[    8.728190] UBI error: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 22:4096, read 126976 bytes
[    8.739330] ,
[    8.739345]      bootserver=0.0.0.0
[    8.744313] UBI warning: ubi_eba_copy_leb: error -74 while reading data from PEB 22
[    8.752227] , rootserver=0.0.0.0, rootpath=, mtu=1460
[    8.764515] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 23:2048, read 512 bytes
[    8.930138] UBI error: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 3:4096, read 126976 bytes
[    9.090133] UBI error: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 23:4096, read 126976 bytes
[    9.110116] UBI warning: ubi_eba_copy_leb: error -74 while reading data from PEB 23
[    9.247001] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 24:2048, read 512 bytes
[    9.257494] UBI error: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 4:4096, read 126976 bytes
[    9.269754] UBIFS: recovery needed
[    9.420215] UBI error: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 24:4096, read 126976 bytes
[    9.435082] UBI error: ubi_io_read: error -74 (ECC error) while reading 11 bytes from PEB 10:4985, read 11 bytes
[    9.445404] UBI warning: ubi_eba_copy_leb: error -74 while reading data from PEB 24
[    9.459615] UBI error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 25:2048, read 512 bytes
[    9.490382] VFS: Cannot open root device "ubi0:rootfs" or unknown-block(0,0)
[    9.497457] Please append a correct "root=" boot option; here are the available partitions:
[    9.520188] 1f00            3072 mtdblock0  (driver?)
[    9.525293] 1f01            2048 mtdblock1  (driver?)
[    9.540156] 1f02            4096 mtdblock2  (driver?)
[    9.545252] 1f03           40960 mtdblock3  (driver?)
[    9.560147] 1f04            2048 mtdblock4  (driver?)
[    9.565243] 1f05           40960 mtdblock5  (driver?)
[    9.580139] 1f06           37888 mtdblock6  (driver?)
[    9.585230] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[    9.593571] Backtrace:
[    9.596048] Function entered at [] from []
[    9.601940]  r7:00008000 r6:c2813000 r5:c0023638 r4:c03b2920
[    9.607656] Function entered at [] from []
[    9.613541] Function entered at [] from []
[    9.619387]  r3:00000000 r2:00000000 r1:c2825f78 r0:c0331dde
[    9.625137] Function entered at [] from []
[    9.631023] Function entered at [] from []
[    9.636867]  r5:c0022dd4 r4:c03b21d8
[    9.640509] Function entered at [] from []
[    9.646352]  r5:c00083a4 r4:00000000
举报
李雨充
2018-7-27 09:32:17
引用: uweuewyfydsf 发表于 2018-7-27 09:16
附件内容如下:
####UBIFS制作####
问题已经解决了,我把nand的ECC给去除了,就好了
举报
陈蓓萤
2018-7-27 09:52:06
怎么去除呢,可以给个方向吗,谢谢!!!
举报
李雨充
2018-7-27 10:06:10
引用: am3x2k 发表于 2018-7-27 09:52
怎么去除呢,可以给个方向吗,谢谢!!!
你好:
       我是在内核中去除掉的,在board-dm368-ipnc.c文件中:
static struct davinci_nand_pdata davinci_nand_data = [
        .parts                  = davinci_nand_partitions,
        .nr_parts               = ARRAY_SIZE(davinci_nand_partitions),
        //.ecc_mode             = NAND_ECC_HW,
        .ecc_mode               = NAND_ECC_NONE,
        .options                = NAND_USE_FLASH_BBT,
        .ecc_bits               = 4,
举报
更多回帖
