单片机学习小组
直播中
龙慧
8年用户 151经验值
私信 关注
51单片机st7920并行方式驱动12864液晶程序分享
  • 模块名称:st7920 并行方式驱动12864液晶驱动
  • 功能概要:st7920显示驱动
  • CPU: stc89c58   主频:11.0592M
  • 液晶型号:       生产厂家:        驱动芯片:st7920
  • #include
  • #define uint  unsigned int
  • #define uchar unsigned char
  • #define x1    0x80
  • #define x2    0x88
  • #define y     0x80
  • #define comm  0
  • #define dat   1
  • ***it RS = P2^1;   //H=data; L=command;
  • ***it RW = P2^2;   //H=read; L=write;
  • ***it  E = P2^4;   //input enable;
  • ***it PSB= P2^5;   //H=并口; L=串口;
  • ***it RST= P2^3;   //Reset Signal 低电平有效
  • ***it busy=P0^7;   //lcd busy bit
  • void wr_lcd (uchar dat_comm,uchar content);
  • void chk_busy (void);
  • void delay (uint us);
  • uchar code tab1[]={
  • "本系列中文模块内"
  • "任意位置反白显示"
  • "置二级字库,可在"
  • "使用更方便更灵活"
  • uchar code tab31[]={
  • "金鹏科技有限公司"
  • "Golden Palm TECH"
  • uchar code tab32[]={
  • /*--  调入了一幅图像:F:梁画图HOCO12832.bmp  --*/
  • /*--  宽度x高度=128x32  --*/
  • 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  • 0x00,0x1E,0x00,0x00,0x00,0x00,0x00,0x07,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  • 0x00,0x7F,0x80,0x00,0x00,0x00,0x00,0x18,0x0C,0x00,0x00,0x01,0x00,0x00,0x00,0x00,
  • 0x01,0xFF,0x80,0x00,0x00,0x00,0x00,0x20,0x00,0x00,0x00,0x13,0x10,0x03,0xFE,0x00,
  • 0x03,0xFF,0xC0,0x00,0x00,0x00,0x00,0x58,0x00,0x00,0x00,0x3F,0x30,0x1F,0xFF,0xC0,
  • 0x03,0xFF,0xE0,0x00,0x00,0x00,0x00,0x8C,0x03,0xF0,0x00,0x7F,0xE0,0x7C,0x01,0xE0,
  • 0x03,0xFF,0xF0,0x00,0x00,0x00,0x01,0x36,0x06,0xC0,0x00,0x5F,0xC0,0xFF,0xFC,0x60,
  • 0x01,0xFF,0xF0,0x00,0x00,0x00,0x02,0x1B,0x0F,0x80,0x00,0xFF,0x01,0xFE,0x0F,0x30,
  • 0x00,0xEF,0xF0,0x00,0x00,0x00,0x02,0x6D,0x9F,0x00,0x00,0x3E,0x03,0xFF,0xF1,0x90,
  • 0x00,0xFF,0xF8,0x00,0x00,0x00,0x04,0x36,0xFE,0x00,0x01,0xFF,0x07,0xFF,0xFC,0x90,
  • 0x00,0xEF,0xFF,0xFF,0x80,0x00,0x04,0xDB,0x7E,0x00,0x03,0xFF,0x87,0xFF,0xFC,0xD0,
  • 0x00,0x0F,0xFF,0xFF,0xC0,0x00,0x04,0x6D,0xFC,0x00,0x07,0xFF,0x8F,0xFF,0xFE,0x50,
  • 0x00,0x0F,0xFF,0xFF,0xE0,0x00,0x04,0x36,0xFC,0x10,0x07,0xFF,0x8F,0xFF,0xFE,0x90,
  • 0x00,0x0F,0xFF,0xFF,0xE0,0x00,0x04,0x1B,0xF8,0x10,0x07,0xFF,0xCF,0xFF,0xFE,0x80,
  • 0x00,0x0F,0xFF,0xFF,0xF0,0x00,0x04,0x0F,0xF8,0x10,0x07,0xFF,0xFF,0xFF,0xFA,0x00,
  • 0x00,0x07,0xFF,0xFF,0xF0,0x00,0x04,0x07,0xF0,0x10,0x07,0xFF,0xFF,0xFF,0xFA,0x00,
  • 0x00,0xFF,0xFF,0xFF,0xF8,0x00,0x02,0x03,0xF0,0x20,0x07,0xFF,0xFF,0xFF,0xBA,0x00,
  • 0x00,0xFD,0xFF,0xFF,0xFC,0x00,0x02,0x03,0xF0,0x20,0x03,0xFF,0xFF,0xDF,0xB8,0x00,
  • 0x00,0xC1,0xC0,0x3F,0xFC,0x00,0x01,0x01,0xE0,0x40,0x00,0xFF,0xFF,0xDF,0xB0,0x00,
  • 0x00,0x81,0xC0,0x3F,0xCE,0x00,0x00,0x81,0xE0,0x80,0x00,0x7F,0xFF,0xDF,0xA0,0x00,
  • 0x00,0x81,0x80,0x1D,0xCF,0x00,0x00,0x41,0xE1,0x00,0x00,0x3F,0xFF,0x9B,0x00,0x00,
  • 0x01,0x83,0x80,0x1F,0xC7,0x80,0x00,0x21,0xE2,0x00,0x00,0x1F,0xFD,0xB6,0x00,0x00,
  • 0x01,0xC3,0x00,0x0E,0xE6,0x80,0x00,0x19,0xEC,0x00,0x00,0x07,0xFE,0x20,0x00,0x00,
  • 0x00,0xC3,0x00,0x07,0x67,0x40,0x00,0x07,0xF0,0x00,0x00,0x03,0x3E,0x00,0x00,0x00,
  • 0x00,0x02,0x00,0x03,0xE7,0xA0,0x00,0x00,0x00,0x00,0x00,0x02,0x8E,0x00,0x00,0x00,
  • 0x00,0x06,0x00,0x03,0x83,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x03,0x00,0x00,0x00,
  • 0x00,0x06,0x00,0x07,0x03,0x00,0x77,0x46,0x74,0x24,0x80,0x06,0x04,0x00,0x00,0x00,
  • 0x00,0x1C,0x00,0x06,0x00,0x00,0x55,0x45,0x54,0x57,0x80,0x00,0x00,0x00,0x00,0x00,
  • 0x00,0x1C,0x00,0x0E,0x00,0x00,0x45,0x45,0x74,0x57,0x80,0x08,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x1C,0x00,0x00,0x55,0x45,0x44,0x74,0x80,0xF0,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x38,0x00,0x00,0x77,0x76,0x47,0x54,0x80,0x00,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
  • uchar code tab5[]={
  • /*--  调入了一幅图像:F:梁画图COCK.bmp  --*/
  • /*--  宽度x高度=128x64  --*/
  • 0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x80,0x00,0x0F,0xFF,0x00,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x00,0x0C,0x43,0x01,0x80,0x00,0x7F,0xFF,0xF0,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x00,0x19,0xFF,0x07,0x00,0x07,0xFF,0xFF,0xFE,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x01,0x3F,0xFC,0x1E,0x00,0x1F,0xFF,0xFF,0xFF,0x80,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x01,0xBF,0xFF,0xFC,0x00,0x7F,0xFC,0x00,0x7F,0xC0,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x01,0xFF,0xFF,0xF0,0x00,0xFF,0xC0,0x00,0x0F,0xE0,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x01,0xFF,0xFF,0xE0,0x03,0xFF,0xFF,0xFC,0x01,0xF0,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x01,0xDF,0xFF,0xC0,0x07,0xFF,0xFF,0xFF,0x80,0xF0,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x03,0xFF,0xFF,0x00,0x0F,0xFF,0xFF,0xFF,0xE0,0x38,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x07,0xFF,0xF8,0x00,0x1F,0xFF,0xF0,0x03,0xF8,0x38,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x07,0xFF,0xE0,0x00,0x3F,0xFF,0xFF,0xC0,0x7C,0x18,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x04,0x7F,0xF0,0x00,0x3F,0xFF,0xFF,0xF8,0x1E,0x08,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x01,0xFF,0xF8,0x00,0x7F,0xFF,0xFF,0xFE,0x0F,0x08,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x0F,0xFF,0xFC,0x00,0xFF,0xFF,0xFF,0xFF,0x87,0x08,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x1F,0xFF,0xFE,0x00,0xFF,0xFF,0xFF,0xFF,0x83,0x88,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x3F,0xFF,0xFE,0x01,0xFF,0xFF,0xFF,0xFF,0xC3,0x88,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x7F,0xFF,0xFE,0x01,0xFF,0xFF,0xFF,0xFF,0xE1,0x88,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0xFF,0xFF,0xFE,0x03,0xFF,0xFF,0xFF,0xFF,0xE1,0x88,0x00,0x00,0x00,
  • 0x00,0x00,0x01,0xFF,0xFF,0xFE,0x03,0xFF,0xFF,0xFF,0xFF,0xF1,0x88,0x00,0x00,0x00,
  • 0x00,0x00,0x01,0xFF,0xFF,0xFE,0x03,0xFF,0xFF,0xFF,0xFF,0xF3,0x08,0x00,0x00,0x00,
  • 0x00,0x00,0x01,0xFF,0xFF,0xFF,0x07,0xFF,0xFF,0xFF,0xFF,0xF2,0x10,0x00,0x00,0x00,
  • 0x00,0x00,0x01,0xFF,0xFF,0xFF,0x8F,0xFF,0xFF,0xFF,0xFF,0xF0,0x20,0x00,0x00,0x00,
  • 0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x70,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFF,0x70,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0xFF,0x7F,0x20,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xBF,0xFF,0x7F,0x20,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xDF,0xFF,0x7E,0x20,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xDF,0xFF,0x3E,0x40,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xCF,0xFF,0x3C,0x40,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xCF,0xFE,0x38,0x40,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0x8F,0xFE,0x38,0x40,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0x8F,0xFE,0x30,0x40,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0x1F,0x7C,0x20,0x40,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFE,0x1E,0x78,0x00,0x40,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x00,0x3F,0xFF,0xFF,0xFE,0x1E,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x00,0x1F,0xFF,0xFF,0xDA,0x3C,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x00,0x07,0xFF,0xFF,0xF2,0x30,0x80,0x00,0x00,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x00,0x01,0xFF,0xFF,0xF1,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x00,0x00,0xFE,0x7F,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x00,0x00,0x7C,0x3F,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x00,0x00,0x78,0x1F,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x00,0x00,0x72,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x00,0x00,0x70,0x00,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x00,0x00,0x60,0x00,0x78,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x00,0x00,0x60,0x00,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x00,0x00,0xC0,0x03,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x00,0x01,0x40,0x04,0xD8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x00,0x01,0x00,0x01,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x00,0x02,0x0C,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x00,0x02,0x40,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x00,0x0C,0x48,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x00,0x38,0x41,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x0F,0xE2,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  • 0x00,0x00,0x00,0x00,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  • * 函数名称    :
  • * 功能描述    :
  • * 参数        :  参数名称:    输入/输出?  类型      描述
  • * 返回值      :
  • * 作者        :
  • * 创建日期    :2006-12-19
  • * 全局变量    :
  • * 全局静态变量:
  • * 局部静态变量:
  • *----------------------------------------修改历史------------------------------------------
  • * 当前版本    :              修改人:                  修改日期:
  • * 修改说明    :
  • void init_lcd (void)
  •     RST = 1;
  •     PSB = 1;
  •     wr_lcd(comm,0x30);  /*30---基本指令动作*/
  •     wr_lcd(comm,0x01);  /*清屏,地址指针指向00H*/
  •     wr_lcd(comm,0x06);  /*光标的移动方向*/
  •     wr_lcd(comm,0x0c);  /*开显示,关游标*/
  • * 函数名称    :chn_disp
  • * 功能描述    : 显示汉字或字符
  • * 返回值      :
  • * 作者        :
  • * 全局变量    :
  • * 全局静态变量:
  • * 局部静态变量:
  • * 修改说明    :
  • void chn_disp(uchar code *chn)
  •     uchar i,j;
  •     wr_lcd(comm,0x80);
  •     for(j=0;j<4;j++)
  •         for(i=0;i<16;i++)
  •         wr_lcd(dat,chn[j*16+i]);
  • * 函数名称    :chn_disp1
  • * 功能描述    : 上半屏显示汉字或字符
  • * 返回值      :
  • * 作者        :
  • * 全局变量    :
  • * 全局静态变量:
  • * 局部静态变量:
  • * 修改说明    :
  • void chn_disp1(uchar code *chn)
  •     uchar i,j;
  •     j=0;
  •     for(i=0;i<16;i++)
  •     wr_lcd(comm,0x90);
  •     j=1;
  •     for(i=0;i<16;i++)
  • * 函数名称    :img_disp
  • * 功能描述    : 显示图形
  • * 返回值      :
  • * 作者        :
  • * 全局变量    :
  • * 全局静态变量:
  • * 局部静态变量:
  • * 修改说明    :
  • void img_disp(uchar code *img)
  •     uchar i,j;
  •     for(j=0;j<32;j++)
  •         for(i=0;i<8;i++)
  •         wr_lcd(comm,0x34);
  •         wr_lcd(comm,y+j);
  •         wr_lcd(comm,x1+i);
  •         wr_lcd(dat,img[j*16+i*2]);
  •         wr_lcd(dat,img[j*16+i*2+1]);
  •     for(j=32;j<64;j++)
  •         for(i=0;i<8;i++)
  •         wr_lcd(comm,y+j-32);
  •         wr_lcd(comm,x2+i);
  •     wr_lcd (comm,0x36);
  • * 函数名称    :img_disp1
  • * 功能描述    : 下半屏显示图形
  • * 返回值      :
  • * 作者        :
  • * 全局变量    :
  • * 全局静态变量:
  • * 局部静态变量:
  • * 修改说明    :
  • void img_disp1(uchar code *img)
  •     uchar i,j;
  •     for(j=0;j<32;j++)
  •         for(i=0;i<8;i++)
  •         wr_lcd(comm,y+j);
  •     wr_lcd(comm,0x36);
  • * 函数名称    :lat_disp
  • * 功能描述    : 显示点阵
  • * 返回值      :
  • * 作者        :
  • * 全局变量    :
  • * 全局静态变量:
  • * 局部静态变量:
  • * 修改说明    :
  • void lat_disp(uchar data1,uchar data2)
  •     uchar i,j,k,x;
  •     x=x1;
  •     for(k=0;k<2;k++)
  •         for(j=0;j<16;j++)
  •         for(i=0;i<8;i++)
  •             wr_lcd(comm,y+j*2);
  •             wr_lcd(comm,x+i);
  •             wr_lcd(dat,data1);
  •         for(i=0;i<8;i++)
  •             wr_lcd(comm,y+j*2+1);
  •             wr_lcd(comm,x+i);
  •             wr_lcd(dat,data2);
  •         x=x2;
  • * 函数名称    :con_disp
  • * 功能描述    : 当data1=0xff,data2=0xff时,在x0,y0处反白显示16xl*yl
  • * 返回值      :
  • * 作者        :
  • * 全局变量    :
  • * 全局静态变量:
  • * 局部静态变量:
  • * 修改说明    :
  • void con_disp(uchar data1,uchar data2,uchar x0,uchar y0,uchar xl,uchar yl)
  •     uchar i,j;
  •     for(j=0;j    {
  •         for(i=0;i        {
  •         wr_lcd(comm,y0+j);
  •         wr_lcd(comm,x0+i);
  • * 函数名称    :clrram
  • * 功能描述    : 清DDRAM
  • * 返回值      :
  • * 作者        :
  • * 全局变量    :
  • * 全局静态变量:
  • * 局部静态变量:
  • * 修改说明    :
  • void clrram(void)
  • * 函数名称    :wr_lcd
  • * 功能描述    :
  • * 返回值      :
  • * 作者        :
  • * 全局变量    :
  • * 全局静态变量:
  • * 局部静态变量:
  • * 修改说明    :
  • void wr_lcd(uchar dat_comm,uchar content)
  •     chk_busy ();
  •     if(dat_comm)
  •         RS = 1;   //data
  •         RW = 0;   //write
  •     else
  •         RS = 0;   //command
  •         RW = 0;   //write
  •     P0=content;   //output data or comm
  •     E = 1;
  •     E = 0;
  • * 函数名称    :chk_busy
  • * 功能描述    :
  • * 返回值      :
  • * 作者        :
  • * 全局变量    :
  • * 全局静态变量:
  • * 局部静态变量:
  • * 修改说明    :
  • void chk_busy(void)
  •     P0 = 0xff;
  •     RS = 0;
  •     RW = 1;
  •     E = 1;
  •     while(busy==1);
  •     E = 0;
  • * 函数名称    :
  • * 功能描述    :
  • * 返回值      :
  • * 作者        :
  • * 全局变量    :
  • * 全局静态变量:
  • * 局部静态变量:
  • * 修改说明    :
  • void delay(uint us)   //delay time
  •     while(us--);
  • * 函数名称    :
  • * 功能描述    :
  • * 返回值      :
  • * 作者        :
  • * 全局变量    :
  • * 全局静态变量:
  • * 局部静态变量:
  • * 修改说明    :
  • void delay1(uint ms)
  •     uint i,j;
  •     for(i=0;i    for(j=0;j<15;j++)
  •     delay(1);
  • * 函数名称    :
  • * 功能描述    :
  • * 返回值      :
  • * 作者        :
  • * 全局变量    :
  • * 全局静态变量:
  • * 局部静态变量:
  • * 修改说明    :
  • void main()
  •     SP=0x5f;
  •     init_lcd();
  •     while(1)
  •         lat_disp(0x00,0x00);
  •         chn_disp(tab1);
  •         con_disp(0xff,0xff,0x8c,0x80,2,16);
  •         delay1(8000);
  •         clrram();
  •         lat_disp(0xcc,0xcc);
  •         delay1(8000);
  •         chn_disp1(tab31);
  •         img_disp1(tab32);
  •         delay1 (8000);
  •         clrram();
  •         lat_disp (0xff,0x00);
  •         delay1(8000);
  •         img_disp(tab5);
  •         delay1(8000);
更多回帖
