hi,Jian Zhou
通过改变版本已经可以通过编译了,但是,我想把编译好的程序放到spi flash,指导书给出的步骤为:
This section describes how to flash a binary image to the SPI flash on ICE.
The pre-built CCS tool for SPI flash(isdk_spi_flasher.out) can be found in $(IA_SDK_HOME)toolsflashing toolsSPI_Flashpre_builtCCS_based.
- Make sure that USB cable is connected to PC from ICE
- Launch CCS
- Launch Target configuration for XDS100 emulator. See " Target Configuration" section for details.
- Load GEL file and execute "AM335x_EVM_Initialization" or "AM3359_ICE_Initialization" script(See "GEL File Loading" section for details), if not done.This is to initialize DDR and On-Chip RAM. GEL file can be found in $(IA_SDK_HOME)toolsgel
- Load pre-built $[IA_SDK_HOME]toolsflashing_toolsSPI_Flashpre_builtCCS_basedisdk_spi_flasher.out to the ICE EVM. See Launching and Debugging application section for details.
- Ensure that the binary image (e.g. MLO or ethercat_SPI.bin or profibus_slave_SPI.bin) to be flashed is present in the Windows Machine.
- Enter the board type when prompted as shown below.
Enter the board type [0-ICE, 1-IDK ]
- Enter the operation when prompted as shown below.
Enter Operation [1 - Flash ] [2 - Erase] : ......................但是步骤上说会有提示,但是我没有看到那里有提示。能否给与提示,谢谢。ps:板子通过jtag转u***的连接线到电脑上,看到电脑上有个串口,连接上之后,只会提示如下信息:TI EtherCAT Demo Application Build - 3.3.0 - running on ICE Ver 2
TI Industrial SDK Version : IASDK 2.1.2.2
Device name : AM335X
Chip Revision : AM335x [PG2.1]
ARM Clock rate : 600
Device Type : EtherCAT Device
best wishes
jason
hi,Jian Zhou
- Launch CCS
best wishes
jason
举报
