TI论坛
直播中
徐铭潞
7年用户 276经验值
私信 关注
请问TM4C1294 Flash写入数据失败是为什么?如何解决?
大家好:
         最近我发现我在BootLoader里面写入数据到程序的运行期间。发现写入全部失败。代码:
while(ui32FlashAddr > len + TFTP_BLOCK_SIZE)        [                ui32FlashAddr =                                ((g_ui32TFTPBlock - 1) * TFTP_BLOCK_SIZE) + APP_START_ADDRESS;                W25QXX_Read(pui8Packet,UPGRADE_FLASH_ADDR + TFTP_BLOCK_SIZE,TFTP_BLOCK_SIZE);                if(ui32FlashAddr < g_ui32FlashEnd)                        [                                //                                // If this is the first block and we have been provided with a start                                // hook function, call it here to indicate that we are about to begin                                // flashing a new image.                                //                #ifdef BL_START_FN_HOOK                                if(g_ui32TFTPBlock == 1)                                [                                        BL_START_FN_HOOK();                                ]                #endif                                //                                // Clear any flash error indicator.                                //                                BL_FLASH_CL_ERR_FN_HOOK();                                //                                // If this is the first data packet and code protection is enabled,                                // then erase the entire flash.                                //                #ifdef FLASH_CODE_PROTECTION                                if(g_ui32TFTPBlock == 1)                                [                                        //                                        // Loop through the pages in the flash, excluding the pages that                                        // contain the boot loader and the optional reserved space.                                        //                                        for(ui32Idx = APP_START_ADDRESS; ui32Idx < g_ui32FlashEnd;                                                ui32Idx += FLASH_PAGE_SIZE)                                        [                                                //                                                // Erase this block of the flash.                                                //                                                BL_FLASH_ERASE_FN_HOOK((ui32Idx);                                        ]                                ]                #else                                //                                // Flash code protection is not enabled, so see if the data in this                                // packet will be programmed to the beginning of a flash block.  We                                // assume that the flash block size is always a multiple of 1KB so,                                // since each TFTP packet is 512 bytes and that the start must always                                // be on a flash page boundary, we can be sure that we will hit the                                // start of each page as we receive packets.                                //                                if(!(ui32FlashAddr & (FLASH_PAGE_SIZE - 1)))                                [                                        //                                        // Erase this block of the flash.                                        //                                        BL_FLASH_ERASE_FN_HOOK(ui32FlashAddr);                                ]                #endif                                //                                // Decrypt the data if required.                                //                #ifdef BL_DECRYPT_FN_HOOK                                BL_DECRYPT_FN_HOOK(pui8Packet + 4, uip_len - 4);                #endif                                //                                // Program this block of data into flash.                                //                                BL_FLASH_PROGRAM_FN_HOOK(ui32FlashAddr, (pui8Packet),                                                TFTP_BLOCK_SIZE);                        ]                g_ui32TFTPBlock ++;        ]        ((void (*)(void))APP_START_ADDRESS)();
回帖(2)
韦明
2018-6-11 01:09:45
BootLoader里面写flash的时候校验了没有,是否写入成功呢?
举报
徐铭潞
2018-6-11 01:15:16
最外层的判断除了问题
举报
更多回帖
