可以读取下面三个内部信号。
可以参考SDK中的adcbufcontinuous和adcsinglechannel例程,按你的需求调整一下ADC channel就可以了。
* # Supported Internal Signals #
* Below is a table of internal signals that can be measured using the ADC.
* Since we are not connecting to a DIO, there is no DIO to internal signal mapping. The DIO field in the channel lookup table should be marked PIN_UNASSIGNED.
* This table can be used to create virtual channel entries in the ADCBufCC26XX_adcChannelLut table in the board file.
* | DIO | Internal Signal CompBInput |
* | PIN_UNASSIGNED | ADC_COMPB_IN_DCOUPL |
* | PIN_UNASSIGNED | ADC_COMPB_IN_VSS |
* | PIN_UNASSIGNED | ADC_COMPB_IN_VDDS |
可以读取下面三个内部信号。
举报
