TI论坛
直播中
杨怡
7年用户 138经验值
私信 关注
请问deviation的频偏是根据什么来确定设置?
频偏对射频有什么影响?
回帖(5)
蒋美燕
2018-6-6 05:18:25
频偏会影响调频波的带宽,根据公式Rx BW > 2 * Deviation + 4 * Freq. Error,另外对灵敏度也有影响
举报
杨怡
2018-6-6 05:32:24
Freq. Error这个参数是什么意思,怎么知道
举报
庄当甜
2018-6-6 05:51:53
Measure the actual frequency on a spectrum analyzer and the delta from the expected frequency gives the frequency error.
Eg: if the measured frequency is 2437.3225 Mhz then the frequency error = 2437.3225 – 2437.3125 = 0.01Mhz (10 Khz). For accurate measurement set a low span in the spectrum analyzer , like 100Khz and RBW of 100Hz.
To convert this to ppm -> (Freq error/expected frequency) * 10^6 -> (0.01/2437.3125) * 10^6 = 4.1 ppm.
举报
李远恒
2018-6-6 06:00:12
您好,想向您请教一个频偏的问题:频谱仪测试CC2640的0信道单载波,频率偏低50KHz,然后如下程序,在发射一个单载波的情况下,无论我这么调整信道和SET_CCFG_MODE_CONF_XOSC_CAPARRAY_DELTA的值,信道可以在0-39切换,但是每次都偏低50KHz,即不能通过调整内部晶振来调整频偏,请问可能的原因和解决方法是?
C:tisimplelinkble_sdk_2_02_01_18examplescc2650emsimple_peripheral
static void SimpleBLEPeripheral_init(void)
HCI_EXT_SetTxPowerCmd(HCI_EXT_TX_POWER_5_DBM);                 //TX功率5dBm
HCI_EXT_ModemTestTxCmd(LL_EXT_TX_UNMODULATED_CARRIER,11);       // TX,非调制,0信道
C:titirtos_cc13xx_cc26xx_2_20_01_08productscc26xxware_2_24_02_17393startup_files
#ifndef SET_CCFG_MODE_CONF_XOSC_CAP_MOD
#define SET_CCFG_MODE_CONF_XOSC_CAP_MOD              0x0        // Apply cap-array delta
// #define SET_CCFG_MODE_CONF_XOSC_CAP_MOD                 0x1        // Don't apply cap-array delta
#endif
#ifndef SET_CCFG_MODE_CONF_XOSC_CAPARRAY_DELTA
#define SET_CCFG_MODE_CONF_XOSC_CAPARRAY_DELTA          0x06       // Signed 8-bit value, directly modifying trimmed XOSC cap-array value
#endif
举报
更多回帖
