DSP论坛
直播中
Jackie
7年用户 4经验值
擅长:嵌入式技术 控制/MCU
私信 关注
头文件问题,文件可以build成功,但是debug的时候就会出错是为什么?
这是我自己定义的can.h头文件,把相关结构体变量都放在这里了并对他们进行了初始化,文件可以build成功,但是debug的时候就会出错,显示错误出现在下文红色字体处,错误提示如下图所示,哪位大神能帮忙解决一下,不胜感激!!!
#ifndef CAN_H
#define CAN_H
#ifdef _CAN_C_
   #define _CAN_EXT
#else
   #define _CAN_EXT extern
#endif
Definitions & Macros
#define CAN_DEFAULTS {           0,
                              0,
                          {0, 0, 0, 0, 0, 0, 0, 0},
                          1,
                                        (void (*)(long))can_TXData,
                                        (void (*)(long))can_RXData }
#define CAN_T_DEFAULTS { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
                         (void (*)(long))can_TXData}
#define CAN_R_DEFAULTS { 0, 0, 0, 0, 0, 0,
                                                 0,
TypeDefs & Structure defines (N/A)
typedef struct {  _iq  id;                       /* Input: phase-a stator variable  */
                                  _iq  length;                         /* Input: phase-b stator variable  */
                                  _iq  data[8];          /* Input: phase-c stator variable  */
                                  _iq  sta;
                                   void  (*TXData)();        /* Pointer to calculation function */
                                   void  (*RXData)();        /* Pointer to calculation function */
                                 } CAN;
typedef CAN *CAN_handle;
typedef struct        { _iq  M1Torque;
                                  _iq  M1Current;
                                  _iq  M1HeartBeat;
                                  _iq  M1State;
                                  _iq  M1Direction;
                                  _iq  M1Speed;
                                  _iq  M1InputVolt;
                                  _iq  M1Temp;
                                  _iq  M1IGBTTemp;
                                  _iq  M1DeltaAngle;
                                  _iq  M1TqLimit;
                                  _iq  M1FaultGrade;
                                  _iq  M1Fault;
                                  _iq  M2Torque;
                                  _iq  M2Current;
                                  _iq  M2HeartBeat;
                                  _iq  M2State;
                                  _iq  M2Direction;
                                  _iq  M2Speed;
                                  _iq  M2InputVolt;
                                  _iq  M2Temp;
                                  _iq  M2IGBTTemp;
                                  _iq  M2DeltaAngle;
                                  _iq  M2TqLimit;
                                  _iq  M2FaultGrade;
                                  _iq  M2Fault;
                                }CAN_T;
typedef CAN_T *CAN_tx;
typedef struct{        _iq M1Enable;
                                _iq M1Mode;
                                _iq M1Drive;
                                _iq M1TorqueSet;
                                _iq M1SpeedSet;
                                _iq M1SpeedLimit;
                                _iq M2Enable;
                                _iq M2Mode;
                                _iq M2Drive;
                                _iq M2TorqueSet;
                                _iq M2SpeedSet;
                                _iq M2SpeedLimit;
                                _iq MCU1HeartBeat;
                                }CAN_R;
typedef CAN_R *CAN_rx;
Exported Variables
#ifdef _CAN_C_
    _CAN_EXT CAN can = CAN_DEFAULTS;
    _CAN_EXT CAN_T tbuf  = CAN_T_DEFAULTS;
    _CAN_EXT CAN_R rbuf = CAN_R_DEFAULTS;
error:#20 identifier "can_RXData" is undefined        can.h
error:#45 expression must have pointer type        can.h
    _CAN_EXT Uint16 can_StartFlag = 0;
    _CAN_EXT Uint16 can_RunMode = 0;
    _CAN_EXT Uint16 can_RunDIR = 0;
    _CAN_EXT int16 can_IdCmd = 0;
    _CAN_EXT int16  can_IqCmd = 0;
    _CAN_EXT Uint16  can_TXFlag = 0;
#else
    _CAN_EXT CAN can;
    _CAN_EXT CAN_T tbuf;
    _CAN_EXT CAN_R rbuf;
    _CAN_EXT Uint16 can_StartFlag;
    _CAN_EXT Uint16 can_RunMode;
    _CAN_EXT Uint16 can_RunDIR;
    _CAN_EXT int16 can_IdCmd;
    _CAN_EXT int16 can_IqCmd;
    _CAN_EXT Uint16 can_TXFlag;
#endif
RAM ALLOCATION (N/A)
Exported Function Call Prototypes
    _CAN_EXT void can_TXData(CAN_tx);
    _CAN_EXT void can_RXData(CAN_rx);
    _CAN_EXT interrupt void CANA_Recv_ISR(void);
Local Function Call Prototypes (N/A)
Flag Define (N/A)
#endif
回帖(2)
陈星
2018-3-24 13:07:27
        数据类型未定义的错误
举报
2019-6-21 09:59:31
变量未定义,看看头文件所在的文件夹路径有没有包含进来,project-properties-build-include options右下方加路径
举报
更多回帖
