这是我的程序(是
STM32F767+tm1638)。就是键值一直读不出来,不知是什么原因?
TM1638.c:
#include "delay.h"
#include "stm32f7xx_hal.h"
#include "TM1638.h"
void TM1638_GPIO_Init(void) //ÅäÖÃGPIO
GPIO_InitTypeDef GPIO_Initure;
__HAL_RCC_GPIOA_CLK_ENABLE(); //¿ªÆôGPIOAʱÖÓ
GPIO_Initure.Mode=GPIO_MODE_OUTPUT_PP ;
GPIO_Initure.Pull=GPIO_PULLUP;
GPIO_Initure.Speed=GPIO_SPEED_HIGH ;
GPIO_Initure.Pin=GPIO_PIN_4;
HAL_GPIO_Init(GPIOA,&GPIO_Initure);
GPIO_Initure.Pin=GPIO_PIN_5;
GPIO_Initure.Mode=GPIO_MODE_OUTPUT_OD ;
GPIO_Initure.Pin=GPIO_PIN_1;
void TM1638_Write(unsigned char DATA) //写数据函数
unsigned char i;
for(i=0;i<8;i++)
Reset_TM1638_CLK;
delay_us(1);
if(DATA&0X01){
Set_TM1638_DIO;
else{
Reset_TM1638_DIO;
DATA>>=1;
Set_TM1638_CLK ;
delay_us(1);
unsigned char TM1638_Read(void) //读数据函数
unsigned char i;
unsigned char temp=0;
Set_TM1638_DIO;
for(i=0;i<8;i++)
temp>>=1;
Reset_TM1638_CLK;
if(Get_tm1638_DIO)
temp|=0x80;
Set_TM1638_CLK;
delay_us(1);
return temp;
unsigned char Read_key(void) //读取按键值
unsigned char c[4],i,key_value=0;
Reset_TM1638_STB;
TM1638_Write(0x42);
delay_ms(10);
for(i=0;i<4;i++)
c
=TM1638_Read();
Set_TM1638_STB;
if(c[0]==0x04) key_value=1;
if(c[0]==0x40) key_value=2;
if(c[1]==0x04) key_value=3;
if(c[1]==0x40) key_value=4;
if(c[2]==0x04) key_value=5;
if(c[2]==0x40) key_value=6;
if(c[3]==0x04) key_value=7;
if(c[3]==0x40) key_value=8;
if(c[0]==0x02) key_value=9;
if(c[0]==0x20) key_value=10;
if(c[1]==0x02) key_value=11;
if(c[1]==0x20) key_value=12;
if(c[2]==0x02) key_value=13;
if(c[2]==0x20) key_value=14;
if(c[3]==0x02) key_value=15;
if(c[3]==0x20) key_value=16;
return key_value;
TM1638.h:
#ifndef __TM1638_H
#define __TM1638_H
#include "sys.h"
#define Set_TM1638_DIO HAL_GPIO_WritePin(GPIOA,GPIO_PIN_1,GPIO_PIN_SET)
#define Reset_TM1638_DIO HAL_GPIO_WritePin(GPIOA,GPIO_PIN_1,GPIO_PIN_RESET)
#define Set_TM1638_CLK HAL_GPIO_WritePin(GPIOA,GPIO_PIN_4,GPIO_PIN_SET)
#define Reset_TM1638_CLK HAL_GPIO_WritePin(GPIOA,GPIO_PIN_4,GPIO_PIN_RESET)
#define Set_TM1638_STB HAL_GPIO_WritePin(GPIOA,GPIO_PIN_5,GPIO_PIN_SET)
#define Reset_TM1638_STB HAL_GPIO_WritePin(GPIOA,GPIO_PIN_5,GPIO_PIN_RESET)
#define Get_tm1638_DIO HAL_GPIO_ReadPin(GPIOA,GPIO_PIN_1)
void RCC_Config(void);
void GPIO_Config(void);
void TM1638_Write(uint8_t byte);
unsigned char TM1638_Read(void) ;
unsigned char Read_key(void);
#endif
