序号 | 产品规格 | 阻值 | 尺寸 | 精度 | 温度系数 | 功率 | 规格书 SPEC | |
1 | AR03ATC16R2 | 16.2Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
2 | AR03ATC16R5 | 16.5Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
3 | AR03ATC16R9 | 16.9Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
4 | AR03ATC17R4 | 17.4Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
5 | AR03ATC17R8 | 17.8Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
6 | AR03ATC0180 | 18Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
7 | AR03ATC18R2 | 18.2Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
8 | AR03ATC18R7 | 18.7Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
9 | AR03ATC19R1 | 19.1Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
10 | AR03ATC19R6 | 19.6Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
11 | AR03ATC0200 | 20Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
12 | AR03ATC20R5 | 20.5Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
13 | AR03ATC0210 | 21Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
14 | AR03ATC21R5 | 21.5Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
15 | AR03ATC0220 | 22Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
16 | AR03ATC22R1 | 22.1Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
17 | AR03ATC22R6 | 22.6Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
18 | AR03ATC23R2 | 23.2Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
19 | AR03ATC23R7 | 23.7Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
20 | AR03ATC0240 | 24Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
21 | AR03ATC24R3 | 24.3Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
22 | AR03ATC24R7 | 24.7Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
23 | AR03ATC24R9 | 24.9Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
24 | AR03ATC25R5 | 25.5Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
25 | AR03ATC26R1 | 26.1Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
26 | AR03ATC26R7 | 26.7Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
27 | AR03ATC0270 | 27Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
28 | AR03ATC27R4 | 27.4Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
29 | AR03ATC0280 | 28Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
30 | AR03ATC28R7 | 28.7Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 |
更多回帖
