序号 | 产品规格 | 阻值 | 尺寸 | 精度 | 温度系数 | 功率 | 规格书 SPEC | |
1 | AR03ATC 4R70 | 4.7Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
2 | AR03ATC 5R10 | 5.1Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
3 | AR03ATC 5R60 | 5.6Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
4 | AR03ATC 6R20 | 6.2Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
5 | AR03ATC 6R80 | 6.8Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
6 | AR03ATC 7R50 | 7.5Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
7 | AR03ATC 8R20 | 8.2Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
8 | AR03ATC 9R10 | 9.1Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
9 | AR03ATC 0100 | 10Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
10 | AR03ATC 10R2 | 10.2Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
11 | AR03ATC 10R5 | 10.5Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
12 | AR03ATC 10R7 | 10.7Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
13 | AR03ATC 0110 | 11Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
14 | AR03ATC 11R3 | 11.3Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
15 | AR03ATC 11R5 | 11.5Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
16 | AR03ATC 11R8 | 11.8Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
17 | AR03ATC 0120 | 12Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
18 | AR03ATC 12R1 | 12.1Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
19 | AR03ATC 12R4 | 12.4Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
20 | AR03ATC 12R7 | 12.7Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
21 | AR03ATC 0130 | 13Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
22 | AR03ATC 13R3 | 13.3Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
23 | AR03ATC 13R7 | 13.7Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
24 | AR03ATC 0140 | 14Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
25 | AR03ATC 14R3 | 14.3Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
26 | AR03ATC 14R7 | 14.7Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
27 | AR03ATC 0150 | 15Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
28 | AR03ATC 15R4 | 15.4Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
29 | AR03ATC 15R8 | 15.8Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
30 | AR03ATC 0160 | 16Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 |
更多回帖
