以最小系统面目出现的GD32F450
开发板,若不为它配上一个合适的显示器件用起来将是一个比较棘手的事。 起初是使用老套路将I2C接口的双色OLED屏点亮,尝试了许多次没如意,只得暂时放弃,看起来GD32F450与GD32F190相差还是比较大,无奈只好先改为LCD5110屏。
LCD5110屏还是比较好用的,且大家用的也比较多,具有实用价值。为了减少连线,这里采用的方式比较简便,就是直接将LCD5110屏插入开发板的插排上,以使LCD5110屏的引脚与GD32F450建立如下的连接:
2--GND--GND 3--SCE--PE2 4--RESET--PE5 5--D/C--PE6 6--SDIN--PE4
7--SCLK--PD0 8--LED--PD1
令人吐槽的是为什么宁愿空出一个引脚也不在该位置提供一个3.3V
的VDD,无奈只好飞一条电源线以使LCD5110工作,详见下图所示。 为使LCD5110正常运行,相应的引脚输出高、低电平的定义如下:
- #define sce_1 gpio_bit_set(GPIOE, GPIO_PIN_2);
- #define sce_0 gpio_bit_reset(GPIOE, GPIO_PIN_2);
- #define dc_1 gpio_bit_set(GPIOE, GPIO_PIN_6);
- #define dc_0 gpio_bit_reset(GPIOE, GPIO_PIN_6);
- #define RST_1 gpio_bit_set(GPIOE, GPIO_PIN_5);
- #define RST_0 gpio_bit_reset(GPIOE, GPIO_PIN_5);
- #define LCD_SCLK_1 gpio_bit_set(GPIOD, GPIO_PIN_0);
- #define LCD_SCLK_0 gpio_bit_reset(GPIOD, GPIO_PIN_0);
- #define LCD_SDIN_1 gpio_bit_set(GPIOE, GPIO_PIN_4);
- #define LCD_SDIN_0 gpio_bit_reset(GPIOE, GPIO_PIN_4);
对引脚的配置函数如下:
- void SPI_CONFIG()
- rcu_periph_clock_enable(RCU_GPIOE);
- gpio_mode_set (GPIOE, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE, GPIO_PIN_2| GPIO_PIN_5| GPIO_PIN_6| GPIO_PIN_4);
- gpio_output_options_set(GPIOE, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_2| GPIO_PIN_5| GPIO_PIN_6| GPIO_PIN_4);
- rcu_periph_clock_enable(RCU_GPIOD);
- gpio_mode_set (GPIOD, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE, GPIO_PIN_0| GPIO_PIN_1);
- gpio_output_options_set(GPIOD, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_0| GPIO_PIN_1);
- GPIO_BOP(GPIOD) = GPIO_PIN_1;
- RST_0;
- delay(100);
- RST_1;
- delay(100);
- RST_0;
- delay(100);
- RST_1;
- delay(100);
对应的初始化函数如下:
- void LCD_init(void)
- LCD_write_byte(0x21,0);
- LCD_write_byte(0xc3,0);
- LCD_write_byte(0x10, 0);
- LCD_write_byte(0x20,0);
- LCD_write_byte(0x0C,0);
- LCD_clear();
在字符库及相关函数的配合下,使用如下的主函数即可得到图示的显示效果。
- int main(void)
- SPI_CONFIG();
- LCD_init();
- LCD_write_english_string(0,0,"GD32 Colibri- ",0);
- LCD_write_english_string(0,1," - F450VE",0);
- LCD_write_english_string(0,3,"ARM Cortex-M4",0);
- LCD_write_english_string(0,5," 2017.4.20",0);
- LED_Init();
- rcu_periph_clock_enable(RCU_GPIOB);
- gpio_mode_set (GPIOB, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE, GPIO_PIN_4);
- gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_4); GPIO_BOP(GPIOB) = GPIO_PIN_4;
- while (1);
