【OK210试用体验】3.1 裸机驱动的编写---UART篇 - 在线问答 - 电子技术论坛 - 最好最受欢迎电子论坛!
中科院 ( 楼主 ) 2015-9-18 17:19:02  只看该作者 倒序浏览
uart程序完成的功能是将你的发送的字符传回
  1. #define GPH2CON                (*(volatile unsigned long *)0xE0200C40)
  2. #define GPH2DAT                (*(volatile unsigned long *)0xE0200C44)
  3. #define GPD0CON          (*(volatile unsigned long *)0xE02000A0)
  4. #define GPD0DAT                (*(volatile unsigned long *)0xE02000A4)
  5. #define GPA0CON         (*(volatile unsigned long *)0xE0200000)
  6. #define GPA1CON         (*(volatile unsigned long *)0xE0200020)
  7. // clock
  8. #define APLL_LOCK         (*(volatile unsigned long *)0xE0100000)
  9. #define MPLL_LOCK         (*(volatile unsigned long *)0xE0100008)
  10. #define APLL_CON0         (*(volatile unsigned long *)0xE0100100)
  11. #define APLL_CON1         (*(volatile unsigned long *)0xE0100104)
  12. #define MPLL_CON         (*(volatile unsigned long *)0xE0100108)
  13. #define CLK_SRC0         (*(volatile unsigned long *)0xE0100200)
  14. #define CLK_SRC1         (*(volatile unsigned long *)0xE0100204)
  15. #define CLK_SRC2         (*(volatile unsigned long *)0xE0100208)
  16. #define CLK_SRC3         (*(volatile unsigned long *)0xE010020c)
  17. #define CLK_SRC4         (*(volatile unsigned long *)0xE0100210)
  18. #define CLK_SRC5         (*(volatile unsigned long *)0xE0100214)
  19. #define CLK_SRC6         (*(volatile unsigned long *)0xE0100218)
  20. #define CLK_SRC_MASK0         (*(volatile unsigned long *)0xE0100280)
  21. #define CLK_SRC_MASK1         (*(volatile unsigned long *)0xE0100284)
  22. #define CLK_DIV0         (*(volatile unsigned long *)0xE0100300)
  23. #define CLK_DIV1         (*(volatile unsigned long *)0xE0100304)
  24. #define CLK_DIV2         (*(volatile unsigned long *)0xE0100308)
  25. #define CLK_DIV3         (*(volatile unsigned long *)0xE010030c)
  26. #define CLK_DIV4         (*(volatile unsigned long *)0xE0100310)
  27. #define CLK_DIV5         (*(volatile unsigned long *)0xE0100314)
  28. #define CLK_DIV6         (*(volatile unsigned long *)0xE0100318)
  29. #define CLK_DIV7         (*(volatile unsigned long *)0xE010031c)
  30. #define CLK_DIV0_MASK        0x7fffffff
  31. #define APLL_MDIV       0x7d
  32. #define APLL_PDIV       0x3
  33. #define APLL_SDIV              0x1
  34. #define MPLL_MDIV        0x29b
  35. #define MPLL_PDIV        0xc
  36. #define MPLL_SDIV        0x1
  37. #define set_pll(mdiv, pdiv, sdiv)        (1<<31 | mdiv<<16 | pdiv<<8 | sdiv)
  38. #define APLL_VAL                set_pll(APLL_MDIV,APLL_PDIV,APLL_SDIV)
  39. #define MPLL_VAL                set_pll(MPLL_MDIV,MPLL_PDIV,MPLL_SDIV)
  40. //#define PLL_OFF
  41. // UART
  42. #define ULCON3                         (*(volatile unsigned long *)0xE2900C00)
  43. #define UCON3                        (*(volatile unsigned long *)0xE2900C04)
  44. #define UFCON3                        (*(volatile unsigned long *)0xE2900C08)
  45. #define UMCON3                        (*(volatile unsigned long *)0xE2900C0C)
  46. #define UFSTAT3                 (*(volatile unsigned long *)0xE2900C18)
  47. #define UBRDIV3                 (*(volatile unsigned long *)0xE2900C28)
  48. #define UDIVSLOT3                 (*(volatile unsigned long *)0xE2900C2C)
  49. #define UTXH3                         (*(volatile unsigned long *)0xE2900C20)
  50. #define URXH3                         (*(volatile unsigned long *)0xE2900C24)
  51. #define UTRSTAT3                 (*(volatile unsigned long *)0xE2900C10)
  52. void clock_init(void)
  53. {
  54.     CLK_SRC0 = 0x0;// close PLL
  55.     APLL_LOCK= 0x0000FFFF;
  56.     MPLL_LOCK = 0x0000FFFF;
  57.     APLL_CON0 =APLL_VAL; //FOUT= MDIV * FIN / (PDIV*2^(SDIV-1)) = 0x7d*24/(0x3*2^(1-1))=1000 MHz
  58.     MPLL_CON = MPLL_VAL;// FOUT = MDIV*FIN/(PDIV*2^SDIV)=0x29b*24/(0xc*2^1)= 667 MHz
  59.     CLK_SRC0= 0x10001111;// FOUT = MDIV*FIN/(PDIV*2^SDIV)=0x29b*24/(0xc*2^1)= 667 MHz
  60. }
  61. void uart_init()
  62. {
  63.     GPA0CON= 0x22222222;
  64.     GPA1CON= 0x2222;//配置引脚为RX/TX功能
  65.     UFCON3= 0x1;//使能FIFO
  66.     UMCON3= 0x0;//无流控
  67.     ULCON3= 0x3;//数据位8,无校验,停止位1
  68.     UCON3= 0x5; //时钟为PCLK,禁止中断,使能UART收 发
  69.     UBRDIV3= 35;//设置波特率
  70.     UDIVSLOT3= 0x1;
  71. }
  72. static void Delay(long count)
  73. {
  74.             volatile int i, j = 0;
  75.             volatile static int loop = 800000000/10000;
  76.             for(;count > 0;count--)
  77.                 for(i=0;i < loop; i++) { j++; }
  78. }
  79. void main(void)
  80. {
  81.             GPD0CON &=~(0xF << 0);
  82.             GPH2CON         = 0x00000000;
  83.             clock_init();
  84.             uart_init();
  85.             while(1)
  86.             {
  87.                 while (!(UFSTAT3 & 0xFF)==0)
  88.                 {
  89.                         UTXH3= URXH3;
  90.                 }
  91.             }
  92. }
复制代码
1个回复
825843374 发表于 2015-9-29 13:40:24
学习了,感谢楼主
回复
举报 使用道具
您需要登录后才可以回帖 登录 | 注册
本版积分规则
关闭
站长推荐上一条 /9 下一条
小黑屋|手机版|Archiver|电子发烧友 ( 湘ICP备2023018690号 )
GMT+8, 2025-12-2 06:06 , Processed in 1.845121 second(s), Total 67, Slave 46 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
微信扫描
快速回复 返回顶部 返回列表
