我有一台带有K1板的戴尔R720,我正在Vmware View 6中测试vDGA。
我的K1只会给我两个选项中的一个,或者将所有GPU分配给PCIe passthrough或者不分配。 不确定这是不是这样。 但是我的问题在于,当我将PCIe直通视频卡分配给VM时,第一个将启动正常,并且所有后续VM将拒绝启动并显示错误:设备8:0.0已在使用中。 VM 1分配为7:0.0 VM2分配为8:0.0 我尝试将vm2移动到9:0.0和A:0.0,结果相同,在任何给定时间只能运行1 vm。 有没有其他人有这个问题,并能够阐明它? 以上来自于谷歌翻译 以下为原文 I have a Dell R720 with a K1 board in it that I am testing out vDGA in Vmware View 6. My K1 will only give me one of 2 options, either assign all GPUs to PCIe passthrough or none. Not sure if that is the way it is or not. However my problem lies in that when I assign the PCIe passthrough video cards to a VM, the first one will boot fine, and all subsequent VMs will refuse to start and display the error: Device 8:0.0 is already in use. VM 1 is assigned to 7:0.0 VM2 is assigned to 8:0.0 I have tried moving vm2 to 9:0.0 and A:0.0 with the same results, only 1 vm can operate at any given time. Has anyone else had this problem and able to shed some light on it? |
26个回答
你有2.4.3 BIOS试过6.0吗?
您可以在可以启动的VM的NVIDIA控制面板中看到vBIOS版本。 它位于系统信息(左下角)下,然后向下滚动到Video Bios版本。 以上来自于谷歌翻译 以下为原文 Have you tried 6.0 with the 2.4.3 BIOS? You can see the vBIOS version in the NVIDIA Control Panel of the VM you can boot. It's under System Information (bottom left corner) then scroll down to Video Bios Version. |
是的,我们也尝试过这个。
我们还尝试了2.2.2启用和禁用4 GB以上内存。 还是一样。 现在我已经在启动的vm上安装了一个Windows 10。 我无法从vSphere客户端打开Nvidia System Management。 所以我安装了View Connection Direct插件但是如果我通过零客户端连接我只会得到一个黑屏。 以上来自于谷歌翻译 以下为原文 Yes we have tried this too. We also tried 2.2.2 Memory above 4 GB setting enabled and disabled. Still the same. Now i have installed a windows 10 on the vm which is booting. I can't open the Nvidia System Management from vSphere client. So i installed the View Connection Direct Plugin but if i connect via zero client i only get a black screen. |
最后重启pcoip后工作。
https://picload.org/view/rggaclgr/unbenannt.png.html 以上来自于谷歌翻译 以下为原文 Finally after reboot pcoip works. https://picload.org/view/rggaclgr/unbenannt.png.html |
几分钟前,vmware打电话给我 - 他们不能为我们做更多的事情。
他们说nvidia必须联系他们。 有没有可能购买nvidia支持票? 我们真的需要我们的网卡,我们不能再等待。 以上来自于谷歌翻译 以下为原文 A few minutes ago vmware has called me - they can't do more for us. They say that nvidia has to contact them. Is there any possibility to buy a nvidia support ticket? We really need our grid cards and we cannot wait more time. |
对于Kepler系列卡,您的支持是通过您从中购买卡的OEM。
只有GRID 2.0才能引入直接支持。 以上来自于谷歌翻译 以下为原文 For Kepler series cards, your support is via the OEM you purchased the cards from. It's only with GRID 2.0 that direct support was introduced. |
虽然这是在论坛之外进行调查,但有一件事情浮现在脑海中。
随着vSphere 6上引入vGPU,我们(Nvidia)推出了K180Q和K280Q的1:1 vGPU配置文件,以简化管理。 如果应用程序不需要CUDA,则可能值得实施vGPU并使用K180Q配置文件代替passthrough,同时我们解决了vSphere 6上的直通K1问题。 以上来自于谷歌翻译 以下为原文 Whilst this is being investigated outside the forum one thing came to mind. With the introduction of vGPU on vSphere 6 we (Nvidia) introduced 1:1 vGPU profiles of K180Q and K280Q to simplify management. If the applications do not require CUDA, it may be worth implementing vGPU and using a K180Q profile in place of passthrough, whilst we resolve the issue with K1 in passthrough on vSphere 6. |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3125 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3531 浏览 4 评论
GMT+8, 2024-12-22 21:04 , Processed in 0.617255 second(s), Total 56, Slave 49 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
