FTP用户接口文件的实现
KEIL官网有提供FTP的接口文件,名为FTP_uif.c文件。我们就是在这个文件上修改。具体修改后的代码如下:
#include
#include
#include
* FTP Server File Access Functions
/*--------------------------- ftp_fopen -------------------------------------*/
void *ftp_fopen (U8 *fname, U8 *mode) {
/* Open file 'fname' for reading or writing. Return file handle. */
return (fopen ((const char *)fname, (const char *)mode));
/*--------------------------- ftp_fclose ------------------------------------*/
void ftp_fclose (void *file) {
/* Close the file opened for reading or writing. */
fclose (file);
/*--------------------------- ftp_fread -------------------------------------*/
U16 ftp_fread (void *file, U8 *buf, U16 len) {
/* Read 'len' bytes from file to buffer 'buf'. The file will be closed, */
/* when the number of bytes read is less than 'len'. */
return (fread (buf, 1, len, file));
/*--------------------------- ftp_fwrite ------------------------------------*/
U16 ftp_fwrite (void *file, U8 *buf, U16 len) {
/* Write 'len' bytes from buffer 'buf' to a file. */
return (fwrite (buf, 1, len, file));
/*--------------------------- ftp_fdelete -----------------------------------*/
BOOL ftp_fdelete (U8 *fname) {
/* Delete a file, return __TRUE on success. */
if (fdelete((char *)fname) == 0) {
return (__TRUE);
return (__FALSE);
/*--------------------------- ftp_frename -----------------------------------*/
BOOL ftp_frename (U8 *fname, U8 *newn) {
/* Rename a file, return __TRUE on success. */
if (frename((char *)fname, (char *)newn) == 0) {
return (__TRUE);
return (__FALSE);
/*--------------------------- ftp_ffind -------------------------------------*/
U16 ftp_ffind (U8 code, U8 *buf, U8 *mask, U16 buflen) {
/* This function is called by the FTP server to find file names and other */
/* file information. The output data is stored in ascii format to output */
/* buffer 'buf' Parameter 'code' specifies requested file information. */
/* Values for 'code': */
/* 0 - read file size */
/* 1 - read last-modified time of a file */
/* 2 - list file names only (first call) */
/* 3 - list file directory in extended format (first call) */
/* 4 - list file names only (repeated call) */
/* 5 - list file directory in extended format (repeated call) */
static FINFO info;
U32 rlen,v;
U8 *tp;
if (code < 4) {
/* First call to ffind, initialize the info. */
info.fileID = 0;
rlen = 0;
next:
if (ffind ((char *)mask, &info) == 0) {
/* File found, print file information. */
if (info.name[0] == '.') {
if ((info.name[1] == 0) || (info.name[1] == '.' && info.name[2] == 0)) {
/* Ignore the '.' and '..' folders. */
goto next;
switch (code) {
case 0:
/* Return file size as decimal number. */
rlen = sprintf ((char *)buf,"%drn", info.size);
break;
case 1:
/* Return last-modified time in format "YYYYMMDDhhmmss". */
rlen = sprintf ((char *)buf,"%04d%02d%02d",
info.time.year, info.time.mon, info.time.day);
rlen += sprintf ((char *)&buf[rlen],"%02d%02d%02drn",
info.time.hr, info.time.min, info.time.sec);
break;
case 2:
case 4:
/* List file names only. */
rlen = sprintf ((char *)buf,"%srn", info.name);
break;
case 3:
case 5:
/* List directory in extended format. */
rlen = sprintf ((char *)buf,"%02d-%02d-%02d",
info.time.mon, info.time.day, info.time.year%100);
/* Convert time to "AM/PM" format. */
v = info.time.hr % 12;
if (v == 0) v = 12;
if (info.time.hr < 12) tp = "AM";
else tp = "PM";
rlen += sprintf ((char *)&buf[rlen]," %02d:%02d%s",v,info.time.min,tp);
if (info.attrib & ATTR_DIRECTORY) {
rlen += sprintf ((char *)&buf[rlen],"%-21s"," ");
else {
rlen += sprintf ((char *)&buf[rlen],"%21d", info.size);
rlen += sprintf ((char *)&buf[rlen]," %srn", info.name);
break;
return (rlen);
/*--------------------------- ftp_accept_host -------------------------------*/
#if 0
BOOL ftp_accept_host (U8 *rem_ip, U16 rem_port) {
/* This function checks if a connection from remote host is accepted or */
/* not. If this function is missing, all remote hosts are accepted. */
if (rem_ip[0] == 192 &&
rem_ip[1] == 168 &&
rem_ip[2] == 1 &&
rem_ip[3] == 1) {
/* Accept a connection. */
return (__TRUE);
/* Deny a connection. */
return (__FALSE);
#endif
/*--------------------------- ftp_evt_notify --------------------------------*/
#if 0
void ftp_evt_notify (U8 evt) {
/* This function notifies the user application about events in FTP server.*/
switch (evt) {
case FTP_EVT_LOGIN:
/* User logged in, FTP session is busy. */
break;
case FTP_EVT_LOGOUT;
/* User logged out, session is idle. */
break;
case FTP_EVT_LOGFAIL:
/* User login failed (invalid credentials). */
break;
case FTP_EVT_DOWNLOAD:
/* File download ended. */
break;
case FTP_EVT_UPLOAD:
/* File upload ended. */
break;
case FTP_EVT_DELETE:
/* File deleted. */
break;
case FTP_EVT_RENAME:
/* File or directory renamed. */
break;
case FTP_EVT_MKDIR:
/* Directory created. */
break;
case FTP_EVT_RMDIR:
/* Directory removed. */
break;
case FTP_EVT_ERRLOCAL:
/* Local file operation error. */
break;
case FTP_EVT_DENIED:
/* Requested file operation denied. */
break;
case FTP_EVT_ERROR:
/* Generic file operation or protocol error. */
break;
#endif
* end of file
