介绍一下手机电池电量检测算法SOC_BY_AUXADC的程序设计,SOC_BY_AUXADC即通过读取电池电压来估测电池电量值。 获取电池剩余电量值的函数入口: kal_int32 auxadc_algo_run(void) { kal_int32 val=0; gFG_voltage = battery_meter_get_battery_voltage(); val = fgauge_read_capacity_by_v(gFG_voltage); bm_print(BM_LOG_CRti, "[auxadc_algo_run] %d,%dn", gFG_voltage, val); return val; } 函数battery_meter_get_battery_voltage()负责获取电池当前电压,函数fgauge_read_capacity_by_v(gFG_voltage)通过插 值算法来估测电池剩余电量。 battery_meter_get_battery_voltage()函数定义: kal_int32 battery_meter_get_battery_voltage(void) { int ret=0; int val=5; val = 5; //set avg times ret = battery_meter_ctrl(BATTERY_METER_CMD_GET_ADC_V_BAT_SENSE, &val); g_sw_vbat_temp = val; return val; } 电池电压采集5次,然后返回电压平均值。 fgauge_read_capacity_by_v(gFG_voltage)函数定义: kal_int32 fgauge_read_capacity_by_v(kal_int32 voltage) { int i = 0, saddles = 0; BATTERY_PROFILE_STRUC_P profile_p; kal_int32 ret_percent = 0; profile_p = fgauge_get_profile(TEMPERATURE_T); if (profile_p == NULL) { bm_print(BM_LOG_CRTI, "[FGADC] fgauge get ZCV profile : fail !rn"); return 100; } saddles = fgauge_get_saddles(); if (voltage > (profile_p+0)->voltage) { return 100; // battery capacity, not dod } if (voltage < (profile_p+saddles-1)->voltage) { return 0; // battery capacity, not dod } for (i = 0; i < saddles - 1; i++) { if ((voltage <= (profile_p+i)->voltage) && (voltage >= (profile_p+i+1)->voltage)) { ret_percent = (profile_p+i)->percentage + ( ( ( ((profile_p+i)->voltage) - voltage ) * ( ((profile_p+i+1)->percentage) - ((profile_p + i)->percentage) ) ) / ( ((profile_p+i)->voltage) - ((profile_p+i+1)->voltage) ) ); break; } } ret_percent = 100 - ret_percent; return ret_percent; } 考虑到不同温度下电池电压和电量的对应关系会发生改变的情况,程序中函数fgauge_get_profile(TEMPERATURE_T)就是根据当前 的温度值TEMPERATURE_T查找到对应的电压电量值对应表。最后根据voltage搜索表中对应的电压区间,通过斜率换 算得到用掉的电量,通过ret_percent = 100 - ret_percent获取剩余电量。 BATTERY_PROFILE_STRUC_P fgauge_get_profile(kal_uint32 temperature) { switch (temperature) { case TEMPERATURE_T0: return &battery_profile_t0[0]; break; case TEMPERATURE_T1: return &battery_profile_t1[0]; break; case TEMPERATURE_T2: return &battery_profile_t2[0]; break; case TEMPERATURE_T3: return &battery_profile_t3[0]; break; case TEMPERATURE_T: return &battery_profile_temperature[0]; break; default: return NULL; break; } } // T2 25C BATTERY_PROFILE_STRUC battery_profile_t2[] = { {0 , 4176}, {1 , 4157}, {3 , 4143}, {4 , 4128}, {6 , 4114}, ...... {90 , 3692}, {92 , 3690}, {93 , 3685}, {95 , 3679}, {96 , 3646}, {98 , 3585}, {99 , 3499}, {100 , 3356}, {100 , 3307}, }; |
9862 浏览 19 评论
10282 浏览 0 评论
3937 浏览 0 评论
8871 浏览 8 评论
2486 浏览 1 评论
GMT+8, 2024-12-29 06:34 , Processed in 0.574744 second(s), Total 67, Slave 50 queries .
