1.说明
水经注离线谷歌卫星地图加载服务中间件可利用离线地图的.dat文件在本地建立服务端,并生成影像、标签、高程等服务地址,可以在Google API中直接调用该服务地址,并将请求到的服务资源显示在前端,当请求的地图资源不存在可通过网络直接下载缺失的地图,并储存在.dat文件中。 百度网盘下载:http://pan.baidu.com/s/1bnjZDZx 详情请咨询水经注QQ群 329081749 2.实现 2.1准备GoogleMapAPIV3 下载GoogleMapAPIV3.rar。 在其目录下新建一个html文件“RiverMapServerSample For Google API.html”,如下图。 利用记事本打开“RiverMapServerSample For Google API.html”并进行编辑,具体内容如下。 <title>RiverMapServerSample For Google API function tlen(len, mystr){ mystr = String(mystr); var num = len - mystr.length; for (var i = 0; i <= num; i++) { mystr = "0" + mystr; } return mystr; }; function CoordMapType(tileSize) { this.tileSize = tileSize; } CoordMapType.prototype.getTile = function(coord, zoom, ownerDocument) { var div = ownerDocument.createElement('DIV'); var ymax = 1 << zoom; var y = coord.y; y = tlen(5,y); var x = tlen(5,coord.x); zoom = tlen(1,zoom+1); div.innerHTML = y + "," + x + "," + zoom; div.style.width = this.tileSize.width + 'px'; div.style.height = this.tileSize.height + 'px'; div.style.fontSize = '10'; div.style.borderStyle = 'solid'; div.style.borderWidth = '1px'; div.style.borderColor = '#AAAAAA'; return div; }; function LocalMapType() {} LocalMapType.prototype.tileSize = new google.maps.Size(256, 256); LocalMapType.prototype.maxZoom = 20; LocalMapType.prototype.minZoom = 0; LocalMapType.prototype.name = "本地"; LocalMapType.prototype.alt = "显示本地地图"; LocalMapType.prototype.getTile = function(coord, zoom, ownerDocument) { var img = ownerDocument.createElement("img"); img.style.width = this.tileSize.width + "px"; img.style.height = this.tileSize.height + "px"; var ymax = 1 << zoom; var y = coord.y; y = tlen(5,y); var x = tlen(5,coord.x); zoom = tlen(1,zoom+1); var strURL = "http://127.0.0.1:1002/getDefinedImage?" + "x=" + x + "&y=" + y + "&z=" + zoom; img.src = strURL; return img; }; var localMapType = new LocalMapType(); function initialize() { var myLatlng = new google.maps.LatLng(30, 103); var myOptions = { center: myLatlng, zoom: 4, streetViewControl: false, mapTypeControlOptions: { mapTypeIds: ["local", google.maps.MapTypeId.ROADMAP] } }; var map = new google.maps.Map(document.getElementById("map_canvas"), myOptions); map.mapTypes.set('local', localMapType); map.setMapTypeId('local'); map.overlayMapTypes.insertAt(0, new CoordMapType(new google.maps.Size(256, 256))); } 其中【strURL=”http://localhost:1002/getDefinedImage?”】表示请求的是影像、地图、地形、标签、影像+标签、影像+地图、影像+地形或Dem。具体根据RiverMapServer的启动配置参数来确定。 例如:RiverMapServer.exe “1002” “Image_Label” “c:testtile” “c:testlabel”表示此应用输出合并底图(可以为影像、地图、地形任意一种)和标签两个地图瓦片。RiverMapServer.exe “1002” “Image” “c:testtile” 表示此应用输出地图底图(可以为影像、地图、地形任意一种) 2.2启动RiverMapServer 启动RiverMapServer有两种方式都可以正常运行。 2.2.1直接运行RiverMapServer 通过config.ini文件配置参数,如下图。 PORT=1002 表示端口为1002;GetFileType=Image_Label表示此应用输出合并底图(可以为影像、地图、地形任意一种)和标签两个地图瓦片,后面必须跟两个瓦片工程文件目录;TileDir=..dattile表示影像数据路径;LabelDir=..datlabel 表示标签数据路径;DemDir=..datdem 表示高程数据路径。 2.2.2 通过cmd.exe输入启动参数运行 新建一个bat文件,设置配置参数,如下图。 双击.bat启动服 务。运行效果和直接运行RiverMapServer效果一致。 3.运行结果 浏览器打开RiverMapServerSample For Google API.html效果,如下图。 附录: 启动参数说明 1.瓦片文件类型:Image_Lable 表示此应用输出合并底图(可以为影像、地图、地形任意一种)和标签两个地图瓦片,后面必须跟两个瓦片工程文件目录) 例子:RiverMapServer.exe “1002” “Image_Label” “c:testtile” “c:testlabel” 2.瓦片文件类型:Image 表示此应用输出地图底图(可以为影像、地图、地形任意一种) 后面必须只需一个瓦片工程文件目录 例子:RiverMapServer.exe “1002” “Image” “c:testtile” 3.瓦片文件类型:Label表示此应用输出地图标签 后面必须只需一个瓦片工程文件目录 例子:RiverMapServer.exe “1002” “Label” “c:testlabel” 4.(待)瓦片文件类型:dem表示此应用输出地图位置高程 后面必须只需一个地图位置高程工程文件目录 例子:RiverMapServer.exe “1002” “dem” “c:testdem” 输入参数大小写不敏感,启动时需检查瓦片文件类型与工程文件是否匹配 请求接口说明 根据启动参数输出相应类型图片(影像、地图、地形、标签、影像+标签、影像+地图、影像+地形、Dem) http://localhost:1002/getDefinedImage?x=1&y=1&z=1 输出地图底图(影像、地图、地形任意一种) http://localhost:1002/getTileImage?x=1&y=1&z=1 输出标签 http://localhost:1002/getLabelImage?x=1&y=1&z=1 输出高程 http://localhost:1002/getDemImage?x=1&y=1&z=1 删除地图地图(影像、地图、地形任意一种) http://localhost:1002/delTileImage?x=1&y=1&z=1 地图服务启动日志输出 1.服务启动时需要检测输入参数的数据是否正确: @@INPUT:OK 输入参数正确 @@INPUT:PortError 端口错误 @@INPUT:TypeError 瓦片类型错误 @@INPUT:DataFileError:瓦片工程文件 瓦片工程文件错误 2 .服务正常启动与运行输出: @@RUN:WAITING 正常启动后和服务空闲时每分钟输出 @@RUN:Exception:异常消息(不能有回车换上等控制字符)服务启动异常后输出 服务正常启动后建立与瓦片工程文件数据源的连接 @@DSCOK:瓦片工程文件 连接正常 @@DSCFAIL:瓦片工程文件 连接失败 @@PORT:端口 3 .瓦片输出 @@TileOK:X=1&y=1&z=1 底图瓦片下载成功(已下载正常输出瓦片不输出日志) @@LabelOK:X=1&y=1&z=1 标签瓦片下载成功(已下载正常输出瓦片不输出日志) @@TileNoExists:X=1&y=1&z=1 底图瓦片不存在 @@LabelNoExists:X=1&y=1&z=1 标签瓦片不存在 @@TileOverRange:X=1&y=1&z=1 底图瓦片超出工程文件覆盖范围 @@LabelOverRange:X=1&y=1&z=1 标签瓦片超出工程文件覆盖范围 |
970 浏览 0 评论
328 浏览 0 评论
在只有一个电子负载仪的情况下,如何持续监控并记录太阳能充电板的全程充电电流?
2181 浏览 1 评论
6484 浏览 1 评论
9727 浏览 1 评论
GMT+8, 2024-12-21 11:34 , Processed in 0.618997 second(s), Total 69, Slave 52 queries .
