kingst 51开发板,自制红绿灯程序,在中断调用LedShow 和在主程序调用LedShow,效果不同,为什么?
STC59C52 --------------------------- 请大家帮我看看,下面的程序,在中断调用LedShow 和在主程序调用LedShow,效果不同,为什么? 在中断调用时:LED和发光二极管目测下,一闪一闪的。 在主程序调用时: 发光正常. 是因为调用LedShow时,LedShow 没有执行完毕,而产生新的中断吗? 我是菜鸟,庆大侠赐教 #include ***it ADDR0 = P1^0; ***it ADDR1 = P1^1; ***it ADDR2 = P1^2; ***it ADDR3 = P1^3; ***it ENLED = P1^4; void Configertimer0(unsigned int ms); static unsigned char timer = 0; static unsigned char LedBuff[]= { 0xFF,0xFF,0xFF }; unsigned char code LedChar[] = { 0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8, 0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e }; static unsigned char T0TH = 0; static unsigned char T0TL = 0; static unsigned int counter = 0; void LedShow(); void main() { unsigned char color = 0; EA = 1; ENLED = 0; ConfigerTimer0(1); while(1) { if(timer == 0) { switch(color) { case 0: timer = 9; color = 1; LedBuff[2] = 0x3F; break; case 1: timer = 15; color = 2; LedBuff[2] = 0xE7; break; case 2: timer = 5; color = 0; LedBuff[2] = 0xFC; break; default:break; } } LedBuff[0] = LedChar[timer%10]; LedBuff[1] = LedChar[timer/10]; LedShow(); }; } void ConfigerTimer0(unsigned int ms) { unsigned long tmp; tmp = 11059200/12; tmp = (tmp*ms)/1000; T0TH =(unsigned char)(tmp>>8); T0TL =(unsigned char)tmp; TMOD &= 0xF0; TMOD |= 0x01; ET0 = 1; TR0 = 1; } void LedShow() { static unsigned char i = 0; P0 = 0xFF; switch(i) { case 0: ADDR2 = 0;ADDR1 = 0;ADDR0 = 0; i++; P0 = LedBuff[0]; break; case 1: ADDR2 = 0;ADDR1 = 0;ADDR0 = 1; i++; P0 = LedBuff[1]; break; case 2: ADDR2 = 1;ADDR1 = 1;ADDR0 = 0; i=0;P0 = LedBuff[2]; break; default: break; } } void InterruptTimer0() interrupt 1 { TH0 = T0TH; TL0 = T0TL; counter++; if(counter>=20) { counter = 0; timer--; } } |
1个回答
顶下自己的问题
【敏矽微ME32G070开发板免费体验】使用coremark测试敏矽微ME32G070 跑分
250 浏览 0 评论
【敏矽微ME32G070开发板免费体验】开箱+点灯+点亮OLED
473 浏览 2 评论
571 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-内核编译之初次编译
260 浏览 0 评论
400 浏览 0 评论
11976 浏览 31 评论
GMT+8, 2024-12-20 08:57 , Processed in 0.743029 second(s), Total 73, Slave 55 queries .
