如图所示:这是所设置的,选用的芯片是epcs64, 请问错误在哪呢? Error (169187): Following feature(s) of I/O pin epcs_sce has invalid setting(s) in the configuration scheme ACTIVE_SERIAL when the pin is placed at pin location D2 Info (169189): I/O feature 'Weak Pull Up' has an invalid setting. The setting should be ON. |
5个回答
什么意思,可以讲清楚一点吗? |
请问该怎么修改呢,一直进行不下去?
楼主解决了吗?请指教
楼主解决了吗,都困扰一晚上了,是在不知道是什么问题,如果解决了,麻烦告知一下
换了quartus 12.1之后编译成功了,之前用的13.0,真是bug啊。楼主解决了吗?不行就换12.1吧,别在这上面浪费时间了。
GMT+8, 2024-9-15 10:11 , Processed in 0.665031 second(s), Total 77, Slave 60 queries .
