问题: 用JLink无法下载程序到目标板 现象: 1、keil提示: JLink info: ------------ DLL: V4.50l, compiled Jul 9 2012 15:02:49 Firmware: J-Link ARM V8 compiled Jun 19 2012 11:29:30 Hardware: V8.00 S/N : 304230680 Feature(s) : RDI,FlashDL,FlashBP,JFlash,GDBFULL * JLink Info: Found SWD-DP with ID 0x0BB11477 * JLink Info: FPUnit: 4 code (BP) slots and 0 literal slots * JLink Info: Found Cortex-M0 r0p0, Little endian. ROMTableAddr = 0xE00FF003 * JLink Info: SYSRESETREQ has confused core. Trying to reconnect and use VECTRESET. * JLink Info: Found SWD-DP with ID 0x0BB11477 * JLink Info: FPUnit: 4 code (BP) slots and 0 literal slots * JLink Info: Found Cortex-M0 r0p0, Little endian. **JLink Warning: Could not set S_RESET_ST **JLink Warning: Could not set S_RESET_ST * JLink Info: Found SWD-DP with ID 0x0BB11477 * JLink Info: FPUnit: 4 code (BP) slots and 0 literal slots * JLink Info: Found Cortex-M0 r0p0, Little endian. * JLink Info: SYSRESETREQ has confused core. Trying to reconnect and use VECTRESET. * JLink Info: Found SWD-DP with ID 0x0BB11477 * JLink Info: FPUnit: 4 code (BP) slots and 0 literal slots * JLink Info: Found Cortex-M0 r0p0, Little endian. **JLink Warning: Could not set S_RESET_ST **JLink Warning: Could not set S_RESET_ST Target info: ------------ Device: Cortex-M0 VTarget = 3.313V State of Pins: TCK: 0, TDI: 0, TDO: 0, TMS: 1, TRES: 1, TRST: 0 Hardware-Breakpoints: 4 Software-Breakpoints: 8192 Watchpoints: 2 JTAG speed: 2000 kHz Cannot setup Breakpoint at Address Cannot setup Breakpoint at Address Erase Failed! 2、错误提示图如附件图片 用的工具:JLink v8 keil4.23 板子:无锡紫芯公司的板子 ![]() |
5个回答
Jlink下载失败一般有以下问题:
1.连接没有连好。 2. Debug设置中选择Jlink工具,同时还要检查一下程序烧录的地址是不是与linker file定义的一致。 |
可能是锁了吧,先解锁试试。
你应该是只选择了芯片没有把芯片相应的包下载下来。把芯片相关包下载下来后应该就没问题了.
1838个成员聚集在这个小组
36106 浏览 0 评论
4230 浏览 0 评论
5827 浏览 1 评论
6602 浏览 0 评论
4051 浏览 0 评论
492浏览 2评论
求助,S32G上Core M启动后如何让Core A在Flash指定位置加载uboot?
466浏览 2评论
ESP32-WROVER-IE + LAN8720以太网,GPIO0电压只有1.6v,无法正常进入spi flash boot模式如何解决?
466浏览 2评论
求分享适用于PN7160 Android的NFC工厂测试应用程序
552浏览 2评论
592浏览 2评论
GMT+8, 2024-8-30 04:20 , Processed in 0.873274 second(s), Total 56, Slave 48 queries .
