我现在需要做一个延时程序,就是按下一个键后,延时1秒后,对应的led再亮,但是我做的这个程序第一次按键后正常,但是之后键盘就不再扫描了,这是为什么呢,新手虚心求教~
#include #define uchar unsigned char #define uint unsigned int ***it sh=P3^0; ***it ds=P3^1; ***it st=P3^2; uint m=1331,n=0,i,a,b,c,x,y; uchar key,sudu,temp; uchar code h[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f}; uchar code j[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,0x87,0xff,0xef}; void saomiao() { P2=P2^0x50; switch(P2) { case 0xe7: key=1; break; case 0xeb: key=2; break; case 0xed: key=3; break; case 0xee: key=4; break; } P2=P2^0x30; switch(P2) { case 0xd7: key=5; break; case 0xdb: key=6; break; case 0xdd: key=7; break; case 0xde: key=8; break; } P2=P2^0x60; switch(P2) { case 0xb7: key=9; break; case 0xbb: key=10; break; case 0xbd: key=11; break; case 0xbe: key=12; break; } } void init(void) { P0=0xaa; P2=0xbf; P1=0; P3=0; } void main() { TMOD=0x11; TL0=(65536-m)%256; TH0=(65536-m)/256; EA=1; ET0=1; TR0=1; ET1=1; TR1=0; PT1=1; init(); while(1) { saomiao(); if(key==1) { TR1=1; temp=key; while(1) { saomiao; if(temp!=key) { break; } if(n==20) { n=0; P0_0=0; P0_1=1; TR1=0; break; } } } if(key==2) { TR1=1; temp=key; while(1) { saomiao; if(temp!=key) { break; } if(n==20) { n=0; P0_0=1; P0_1=0; TR1=0; break; } } } } } void timer0() interrupt 1 using 1 { TL0=(65536-m)%256; TH0=(65536-m)/256; P1_7=~P1_7; } void timer1() interrupt 3 using 2 { n++; TL1=(65536-46083)%256; TH1=(65536-46083)/256; }
1个回答
求助一下关于51系列单片机的Timer0的计时问题,TH0、TL0+1的时间是怎么算的?
195 浏览 0 评论
【RA-Eco-RA4E2-64PIN-V1.0开发板试用】开箱+Keil环境搭建+点灯+点亮OLED
172 浏览 0 评论
【敏矽微ME32G070开发板免费体验】使用coremark测试敏矽微ME32G070 跑分
453 浏览 0 评论
【敏矽微ME32G070开发板免费体验】开箱+点灯+点亮OLED
697 浏览 2 评论
602 浏览 0 评论
11977 浏览 31 评论
GMT+8, 2024-12-20 19:11 , Processed in 0.439530 second(s), Total 41, Slave 34 queries .
